Macros, general help
Hi Duet folks, wonder if I can get some assistance please, I'm totally new to duet and have received a Chiron with a duet Wi-Fi rig but no onboard SD, everything is done via the web console. I think I've got the basics but cant figure out a few things and as there isn't a tech support to speak to so I was hoping someone could point me in the right direction? I've looked at some of the online info but as I said, total noob with this stuff and I don't want to break anything!
The things I cant figure out are(images below with error messages and Duet version) :
1 - how to load/unload filament
2 - Filaments - I've tried to create filament profiles but it keeps coming back with an error
3 - Macros - I thought I may need to create macros to load/unload filament but also got error message(i copied a macro I found online as I don't know the commands but it said it was to long)
4 - I have a thumb drive with the config files in case I crash and burn the rig but also not sure how to update the Duet firmware? I tried the RepRap![alt text](image url) config tool but wasn't sure if I had configured it correctly!
5 - Is the data transfer sending a job to the Chiron usually as slow as mine? it sends at around 40b/s over Wi-Fi and can take up to 13mins to send a job, I've got regular fibre broadband
Thanks in advance to any replies and much appreciated!!
Anthony
![alt text](![image url](![image url](![image url](![image url](image url)))))
@Atraedes said in Macros, general help:
2 - Filaments - I've tried to create filament profiles but it keeps coming back with an errorremove the sd card and create the filements folder manually
or update to the latest firmware4 - I have a thumb drive with the config files in case I crash and burn the rig but also not sure how to update the Duet firmware?
please read
https://duet3d.dozuki.com/Wiki/Installing_and_Updating_Firmware5 - Is the data transfer sending a job to the Chiron usually as slow as mine? it sends at around 40b/s over Wi-Fi and can take up to 13mins to send a job, I've got regular fibre broadband
you internet connection is irrelevant. the wifi antenna is weak on the duet wifi. so it should be close to the access point.
Your SD card needs a
Filaments
folder created in the root as it appears to be missing. That should get rid of some of the error messages.Loading and unloading filaments can be as easy as you manually heating the extruder and manually pushing and pulling the filament into place. Alternatively, you can use the filaments function in DWC to create custom macros for different filaments.
See here:
https://duet3d.dozuki.com/Wiki/Filaments
https://duet3d.dozuki.com/Wiki/Duet_Web_Control_Manual#Section_FilamentsUpdating the firmware is pretty easy. It looks like you have DWC 2.0.7 installed, and your firmware is version 2.05. But your wifi server version is out of date. This may explain part of the slow upload problem.
Please send M122 in the gcode console and copy and paste the entire results here so we can get some more detailed information. Also post the contents of your config.g file.
The transfer speed sounds pretty slow. Is the Duet Wifi inside of a metal box? The wifi antenna is small and needs to have a clear opening to get a good signal strength. When you post the results of M122 we will see what signal strength is like.
Download this zip file and upload it as is to the system tab in the web interface. Don't extract it, just upload the whole zip file.
This will update the firmware, DWC, and wifi server version to the latest for RRF2.
@Phaedrux - Thank you so much for your comprehensive info, please see the info requested below, here are some images also of the rig, its a 3d printed enclosure, and around 3mtrs from the AP. Also a screen shot of SD card screen as i cant see a slot for an SD so i assumed it was enclosed but this looks like there isn't one? Thanks again for your patience!
M122
RepRapFirmware for Duet 2 WiFi/Ethernet version 2.05 running on Duet WiFi 1.02 or later
Board ID: 08DJM-9178L-L2MS8-6JKFL-3SD6N-KVGQN
Used output buffers: 3 of 24 (8 max)
Static ram: 25712
Dynamic ram: 93176 of which 0 recycled
Exception stack ram used: 320
Never used ram: 11864
Tasks: NETWORK(ready,676) HEAT(blocked,1176) MAIN(running,3736) IDLE(ready,160)
Owned mutexes:
Last reset 00:22:34 ago, cause: power up
Last software reset time unknown, reason: User, spinning module GCodes, available RAM 11956 bytes (slot 2)
Error status: 0
Free file entries: 10
MCU temperature: min 16.4, current 25.8, max 26.1
Supply voltage: min 26.3, current 26.4, max 26.5, under voltage events: 0, over voltage events: 0, power good: yes
Date/time: 2020-10-22 10:00:28
Cache data hit count 4134551131
Slowest loop: 3.97ms; fastest: 0.07ms
Hiccups: 0, FreeDm: 160, MinFreeDm: 160, MaxWait: 0ms
=== DDARing ===
Heater 1 is on, I-accum = 0.0
Segments left: 0
Movement lock held by null
http is idle in state(s) 0
telnet is idle in state(s) 0
file is idle in state(s) 0
serial is idle in state(s) 0
aux is idle in state(s) 0
daemon is idle in state(s) 0
queue is idle in state(s) 0
Code queue is empty.
=== Network ===
Slowest loop: 13.96ms; fastest: 0.01ms
HTTP sessions: 1 of 8- WiFi -
Network state is running
WiFi firmware version 1.21
WiFi MAC address cc:50:e3:e3:ad:08
WiFi Vcc 3.40, reset reason Turned on by main processor
WiFi flash size 4194304, free heap 16864
WiFi IP address 192.168.0.76
WiFi signal strength -68dBm, reconnections 0, sleep mode modem
- WiFi -
@Phaedrux Ok firmware has been updated and here are the new results for M122 after firmware upgrade if you need it:
M122
RepRapFirmware for Duet 2 WiFi/Ethernet version 2.05.1 running on Duet WiFi 1.02 or later
Static ram: 25712
Exception stack ram used: 416
Never used ram: 11768
Tasks: NETWORK(ready,628) HEAT(blocked,1176) MAIN(running,3736) IDLE(ready,160)
Owned mutexes:
Last reset 00:16:43 ago, cause: software
Error status: 0
MCU temperature: min 25.6, current 26.0, max 27.1
Driver 0: standstill, SG min/max 0/84
Driver 1: standstill, SG min/max 122/307
Driver 2: standstill, SG min/max 42/143
Driver 3: standstill, SG min/max 0/138
Date/time: 2020-10-22 10:47:57
Cache data hit count 3048049299
Slowest loop: 6.99ms; fastest: 0.06ms
Hiccups: 0, FreeDm: 160, MinFreeDm: 155, MaxWait: 977447ms
=== DDARing ===
Scheduled moves: 9, completed moves: 9, StepErrors: 0, LaErrors: 0, Underruns: 0, 0
Segments left: 0
=== Network ===
Slowest loop: 15.58ms; fastest: 0.00ms
WiFi firmware version 1.23
WiFi flash size 4194304, free heap 25528
- WiFi -
There is an SD card slot on the Duet board which is SD slot 0 which contains your configuration files, the web interface files, macros, and any gcode files you upload through the web interface. This is also where firmware files get uploaded before they get flashed to the board itself.
There is an SD card on the PanelDue as well which can be used as a secondary SD card to load gcode files. However to use it, the PanelDue must be connected with a 10 pin cable which has a length limitation. It looks like your PanelDue is connected via the 4 wire option which allows for greater distance from the duet.
With the ability to upload gcode files to the duet via the network and web interface and even straight from most slicers it's pretty rare to actually use an SD card with the Duet to load gcode files.
It looks like you got the firmware updated, so that's good.
Your photos show the paneldue, but where is the Duet board itself? The signal strength shown is quite poor.
which may explain your poor upload speeds. Can you post a photo showing where the duet is actually mounted? -
@Phaedrux sorry for the delay, I've checked and can only imagine its under the machine in either one of these housings and metal, so probably the cause then
Yeah that case is going to be problematic. It may be possible, depending on how the board is oriented inside the case, to open up a slot in the side of the panel to give the antenna some clearance, but would need to open it up and you'd need to be comfortable with some metal hacking. A less invasive approach might be to get a separate wifi extender and place it close by.
Conversion of the Duet WiFi to external antenna is another possibility, but it's not for the faint-hearted.
hehe i guess i will give that a miss then. How do i create a filaments folder in the root of the sd please? i tried to do it but not sure if i did it right, also i dont suppose there is a list of comonly used macros i can just cut and paste perhaps? i know nothing about g-code...yet
Thanks in advance -
You may need to pull the SD card from the Duet and create the folder on your PC. I'm not sure if you can create it from the web interface. There's also the option of FTP if that's easier for you.
For example config and macros you can see here:
https://github.com/Duet3D/RRF-machine-config-files/tree/master/DBotCoreXY/x0r-wifi-RRF2
It's difficult to use other peoples macros and configs because every machine is different, so you need to be careful. But looking through them should give you an idea of what's possible and looking up each gcode being used will help you learn as well.
you have been amazing, thanks you very much for your guidance! i will check it out and start making some macros, thanks again. By the way, what's FTP?
FTP is File Transfer Protocol. It's a way of editing a file system over a network basically. It requires a piece of software called an FTP client that lets you connect to an FTP server, in this case, the duet.
@Phaedrux For info, FTP also stands for Federal Test Procedure which define how vehicle emission tests are carried out (among other things). Back in the 80s, that caused no end of problems and confusion when software engineers and vehicle emission engineers got together and started to develop computer controlled test equipment.
