Duet Web control is not available at time of printing
Duet Web Control
825
    DronBroks
    Good afternoon!
    I have a printer based on the Duet 2 Maestro board. The board is connected to the router with a cable, it is assigned a permanent IP address. In addition, the Duet Panel is connected to the board 5 inches.
    When printing, access to Duet Web Control is lost. Access appears only after rebooting the board. The printer address is pinged. The printer is controlled from the panel. Only Web Control falls off.
    The board is flashed with firmware 3.1.1 and the Web Control version is taken from there.
    What might not work like that?
      Veti
      there was a post a few weeks back where a user was reporting similar issue.
      this was due to electrical interference from the stepper wires.
      undefined 1 Reply Last reply 21 Oct 2020, 12:39 Reply Quote 0
        DronBroks @Veti
        @Veti Thanks!
        I read this post. Home test this version. But I have a cable to the router passes the signal wires stepper motors.
          Please post the results of M122 and double check that DWC is version 3.1.1
          How are you permanently assigning an IP address?
          Post your config.g
          undefined 1 Reply Last reply 22 Oct 2020, 06:04 Reply Quote 0
            DronBroks @Phaedrux
            @Phaedrux
            M122
            RepRapFirmware for Duet 2 Maestro version 3.1.1 running on Duet Maestro 1.0
            Board ID: 08DJM-956DU-LL3SW-6JTDG-3SJ6S-1UHLR
            Used output buffers: 3 of 24 (12 max)
            Static ram: 21924
            Dynamic ram: 89580 of which 44 recycled
            Exception stack ram used: 408
            Never used ram: 19116
            Tasks: NETWORK(ready,432) HEAT(blocked,1316) MAIN(running,1996) IDLE(ready,84)
            Owned mutexes:
            Last reset 05:56:42 ago, cause: power up
            Last software reset at 2020-10-21 20:26, reason: User, spinning module GCodes, available RAM 19300 bytes (slot 3)
            Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0400f000 BFAR 0xe000ed38 SP 0xffffffff Task MAIN
            Error status: 0
            MCU temperature: min 25.5, current 34.8, max 38.4
            Supply voltage: min 0.0, current 12.6, max 12.8, under voltage events: 0, over voltage events: 0, power good: yes
            Driver 0: ok, read errors 0, write errors 0, ifcount 9, reads 2347, timeouts 0
            Driver 1: standstill, read errors 0, write errors 0, ifcount 9, reads 2347, timeouts 0
            Driver 2: standstill, read errors 0, write errors 0, ifcount 9, reads 2347, timeouts 0
            Driver 3: ok, read errors 0, write errors 0, ifcount 9, reads 2339, timeouts 8
            Driver 4: standstill, read errors 0, write errors 0, ifcount 6, reads 2350, timeouts 0
            Driver 5: ok, read errors 0, write errors 0, ifcount 0, reads 0, timeouts 2356
            Driver 6: ok, read errors 0, write errors 0, ifcount 0, reads 0, timeouts 2355
            Date/time: 2020-10-22 08:59:13
            Slowest loop: 48.15ms; fastest: 0.12ms
            === Storage ===
            Free file entries: 9
            SD card 0 detected, interface speed: 15.0MBytes/sec
            SD card longest read time 22.0ms, write time 0.0ms, max retries 0
            Hiccups: 0(0), FreeDm: 165, MinFreeDm: 109, MaxWait: 361770ms
            === MainDDARing ===
            Scheduled moves: 209242, completed moves: 209223, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: 3
            === AuxDDARing ===
            Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1
            Bed heaters = 0 -1, chamberHeaters = -1 -1
            Heater 0 is on, I-accum = 0.3
            Heater 1 is on, I-accum = 0.2
            Segments left: 1
            Movement lock held by null
            HTTP is idle in state(s) 0
            Telnet is idle in state(s) 0
            File is doing "G1 X182.914 Y233.246 E0.36015" in state(s) 0
            USB is idle in state(s) 0
            Aux is idle in state(s) 0
            Trigger is idle in state(s) 0
            Queue is idle in state(s) 0
            LCD is idle in state(s) 0
            Daemon is idle in state(s) 0
            Code queue is empty.
            === Network ===
            Slowest loop: 8.95ms; fastest: 0.02ms
            HTTP sessions: 1 of 8
            Interface state active, link 100Mbps full duplex
            === Filament sensors ===
            Extruder 0 sensor: ok
            A static IP address is assigned by the router.
            Config
            ; Configuration file for Duet Maestro (firmware version 3)
            ; generated by RepRapFirmware Configuration Tool v3.1.4 on Wed Sep 23 2020 13:34:11 GMT+0300 (Москва, стандартное время)
            M80
            M550 P"Dron Printer" ; set printer name
            M669 K1 ; select CoreXY mode
            M551 P"XXXXXXXXX" ; set password
            M552 PXXX.XXX.XXX.XXX S1 ; enable network and acquire
            M586 P0 S1 ; enable HTTP
            M586 P1 S0 ; disable FTP
            M586 P2 S0 ; disable Telnet
            M569 P0 S1 D3 ; physical drive 0 goes forwards stealthChop2
            M569 P1 S1 D3 ; physical drive 1 goes forwards stealthChop2
            M569 P2 S1 D3 ; physical drive 2 goes forwards stealthChop2
            M569 P3 S0 D3 ; physical drive 3 goes forwards stealthChop2
            M350 X64 Y64 Z64 E32 I0 ; configure microstepping without interpolation
            M92 X320.00 Y320.00 Z3219.50 E1000.00 ; set steps per mm
            M566 X900.00 Y900.00 Z12.00 E120.00 ; set maximum instantaneous speed changes (mm/min) Jerk
            M201 X1000.00 Y1000.00 Z100.00 E2000.00 ; set accelerations (mm/s^2)
            M204 P1000 T5000 ; Maximum printing acceleration 1000.0, maximum travel acceleration 5000.0
            M906 X800 Y800 Z800 E600 I30 ; set motor currents (mA) and motor idle factor in per cent
            M84 S30 ; Set idle timeout
            M208 X300 Y300 Z240 S0 ; set axis maxima
            M574 X1 S1 P"!xstop" ; configure active-low endstop for low(min) end on X via pin xstop
            M574 Y2 S1 P"!ystop" ; configure active-low endstop for high(max) end on Y via pin ystop
            M574 Z1 S2 ; configure Z-probe endstop for low(min) end on Z
            M591 D0 P7 C"e0_stop" L7 R50:250 E22 S1 ; BTT sensor for extruder drive 0, connected to endstop input 3 (E0), tolerance 50 to 250%, 7mm/pulse, measure every 22 sek, enabled
            M558 P9 C"zprobe.in" H5 F120 T3000 ; BLTouch set Z probe type to unmodulated and the dive height + speeds
            M950 S0 C"zprobe.mod" ; BLTouch servo/gpio 0 is Z probe MOD pin
            M280 P0 S10 ; BLTouch send control signal to BLTouch through servo/gpio 0
            M280 P0 S90 ; Send PWM channel 0 the S90 (angle) command
            G31 P25 X-2.7 Y-50.6 Z2.45 ; BLTouch set Z probe trigger value, offset and trigger height
            M557 X10:290 Y10:290 S20 ; probe from X=10 to 290, Y=10 to 250mm with a mesh spacing of 20mm
            M308 S0 P"bedtemp" Y"thermistor" R2200 T100000 B3950 A"Stol-Temp" ; configure sensor 0 as thermistor on pin bedtemp
            M307 H0 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit
            M143 H0 S130 ; set temperature limit for heater 0 to 130C
            M308 S1 P"e0temp" Y"thermistor" R2200 T100000 B3950 A"Nozl_0-Temp" ; configure sensor 1 as thermistor on pin e0temp
            M308 S2 P"ctemp" Y"thermistor" R2200 T100000 B3950 A"Drivers-Temp" ; configure sensor 2 as thermistor on pin сtemp
            M308 S3 Y"mcu-temp" A"MCU-Temp" ;
            M950 F2 C"fan2" Q1000 ; create fan 2 on pin fan2 and set its frequency
            M106 P2 S1 H2 T40 ; set fan 2 value. Thermostatic control is turned on
            M501
            M200 D1.75 ; set all extruder filament diameters to 1.75mm
              Veti
              @DronBroks said in Duet Web control is not available at time of printing:
              first why are you not using interpolation?
              can you just for testing go down to x16 for all?
              undefined 1 Reply Last reply 22 Oct 2020, 07:19 Reply Quote 0
                DronBroks @Veti
                @Veti
                I'm still testing a printer. Daylight interpolation supposed to do in the near future
                undefined 1 Reply Last reply 22 Oct 2020, 07:20 Reply Quote 0
                  Veti @DronBroks
                  i dont know what you mean by that
                  undefined 1 Reply Last reply 22 Oct 2020, 07:26 Reply Quote 0
                    DronBroks @Veti
                    @Veti
                    I plan to enable interpolation later
                      Veti
                      actually you can send
                      M350 X64 Y64 Z64 E32 I1
                      during the print.
                      i think you can even send
                      M350 X16 Y16 Z16 E16 I1 during the print as it adjusts steps as well (but i have not tried that)
                      but if its an important print you might not want to risk it.
                      undefined 1 Reply Last reply 22 Oct 2020, 07:53 Reply Quote 0
                        DronBroks @Veti
                        @Veti
                        I sent the first command while printing. Printing was interrupted, now only after work I can start printing again. In essence, the main question - after transferring the Ethernet cable outside the printer case, the Web server does not hang up yet.
                          With the high microstepping it's possible that you're saturating the CPU and it's not able to service the web interface requests quickly enough during a print.
                          Please test with x16 microsteps and interpolation enabled.
                          undefined 2 Replies Last reply 23 Oct 2020, 06:39 Reply Quote 1
                            DronBroks @Phaedrux
                            @Phaedrux
                            Good. After the work is checked.
                              DronBroks @Phaedrux
                              @Phaedrux
                              After the transfer of the Ethernet cable from the printer body, hovering stopped interface (tested on a daily print interface can be accessed at any time)
                              undefined 1 Reply Last reply 31 Oct 2020, 14:02 Reply Quote 0
                                jovo0911 @DronBroks
                                @Phaedrux
                                Any new infos here? I have also a problem with network connection. Sometimes I lost connection (mostly after upload a file - bigger then 10 mb)
                                undefined 1 Reply Last reply 31 Oct 2020, 16:27 Reply Quote 0
                                  Phaedrux Moderator @jovo0911
                                  @jovo0911 Might want to start a new thread with your specific details.
                                    DronBroks
                                    Good afternoon!
                                    Problems continued, but less frequently. Most often, the problem appears when you create a folder on the memory card, or transfer to the card volumetric files. Sometimes the interface freezes during long-term work. And it is such that when downloading files pauses printing for a split second.
                                    undefined 1 Reply Last reply 5 Nov 2020, 15:46 Reply Quote 0
                                      @DronBroks Can you confirm that you have switched to x16 microstepping?
                                      Do you have a new SD card to test with?
                                      undefined 2 Replies Last reply 3 Nov 2020, 06:12 Reply Quote 0
                                        DronBroks @Phaedrux
                                        @Phaedrux Yes, I switched to 1x16 microsteps. Perhaps the reason is actually in the memory card. I’m not very fast. Today I will buy a new one and check with a new card
                                        undefined 1 Reply Last reply 3 Nov 2020, 06:40 Reply Quote 1
                                          DronBroks @Phaedrux
                                          @Phaedrux
                                          M80
                                          M551 P"" ; set password
                                          M552 P192.ххх.ххх.ххх S1 ; enable network and acquire
                                          M350 X16 Y16 Z16 E32 I1 ; configure microstepping interpolation
                                          M92 X80.00 Y80.00 Z804.875 E1001 ; set steps per mm
                                          ; Jerk
                                          ; Maximum Speeds
                                          ; Accelerations
                                          M201 X1000.00 Y1000.00 Z100.00 E250.00 ; set accelerations (mm/s^2)
                                          M906 X900 Y900 Z900 E600 I30 ; set motor currents (mA) and motor idle factor in per cent
                                          M591 D0 P5 C"e0_stop" R50:140 E4.0 S0 ; Duet3D laser sensor for extruder drive 0, connected to endstop input 3 (E0), tolerance 40 to 120%, 7mm comparison length, enabled
                                          G31 P25 X-2.7 Y-50.6 Z1.54 ; BLTouch set Z probe trigger value, offset and trigger height
                                          ; M308 S1 P"e0temp" Y"pt1000" R2200 A"Nozl_0-Temp" ; configure sensor 1 as thermistor on pin e0temp
                                          M501
