    Duex4 v0.2a (with Duet 0.6)
    603
    • sylvaindcundefined
      sylvaindc
      Hi All,
      I managed to get my @DC42 inspired large Delta up and running using my Duet 0.6 board (running Firmware: RepRapFirmware for Duet 1.26.1 (2020-02-09b1))
      Now when I ordered the Duet 0.6 back in 2015, I added the Duex4 expansion with it and would like to add that to do the following:
      • Add a 2nd extruder
      • Add 2 parts fan (or perhaps 2)
      Sounds easy, but I quickly ran into the following issues by just looking at the specs on http://blog.think3dprint3d.com/2015/04/duex4-v02a-minor-updates.html
      1. I have @dc42's IR leveling meter hooked up to my Duet 0.6, using a pin on the expansion header https://miscsolutions.files.wordpress.com/2015/05/duet0-6-brd_0-781.png (Pin AD12 if I'm not mistaken). Does that just loop through to AD12 on the J7 EXPANSION1 header of the Duex4?, or should I find an other solution?
      2. Is it possible to connect a FAN for the 2nd extruder, or should I just use one fan connector for both extruders?
      3. Is it possible to use one of the drivers or EXPANSION1 pins to hook up a parts fan?
      I did some googling, but I starting to think I own the only Duex4 still around 🙂
      many thanks for your help!
      Nxt-1undefined dc42undefined 2 Replies Last reply Reply Quote 0
      • Nxt-1undefined
        Nxt-1 @sylvaindc
        @sylvaindc I have one around, we're buddies now 🙂 I have never used it though, never really needed it and the pinout in 1-1 with the Duet2 I use. I will follow this thread though.
        Duet3D and delta printer enthousiast. Buildlog
        Looking for Duet3D configuration support, check out Nxt-3D
        sylvaindcundefined 1 Reply Last reply Reply Quote 1
          dc42 administrators @sylvaindc
          @sylvaindc said in Duex4 v0.2a (with Duet 0.6):
          AFAIR, it just loops through.
          With firmware 1.26.1 I think it should be possible to connect fans to spare heater outputs on the DueX4, but it's probably never been tested.
          sylvaindcundefined 2 Replies Last reply Reply Quote 0
            sylvaindc @Nxt-1
            @Nxt-1 Duex4 buddies for life!
              sylvaindc @dc42
              @dc42 said in Duex4 v0.2a (with Duet 0.6):
              That sounds like good fun to try @dc42!
              So lets see how to do this:
              step 1: See if the IR probe still works when I loop it through (I'll try that tomorrow)
              Step 2: Hook up a fan to a heater output. Minor problem is that I'm very sure I dont know what I'm doing :). How would I hook this up (just connect it I guess, does the heater PWM?) and how do I update the configs? Any hints you can give me?
                Using firmware 1.26.1 you can use the A parameter of the M106 command to specify a heater port that the fan is connected to.
                sylvaindcundefined 1 Reply Last reply Reply Quote 0
                  sylvaindc @dc42
                  Ok, that sounds like a plan, but how do I find out which logical pin e.g. the E4 heater is connected to?
                    See anything helpful in here?
                    https://reprap.org/wiki/Duet_Wiring#Duet_0.6
                    How bout here?
                    https://reprapltd.com/documentation/fisher-build-instructions/duet-0-6-electronics/
                    Or here?
                    https://reprap.org/wiki/Duex4
                    Maybe this?
                    That's about as good as I can google.
                      There is a list of logical pin numbers at https://duet3d.dozuki.com/Wiki/Using_servos_and_controlling_unused_IO_pins.
                        sylvaindc
                        Thanks @Phaedrux and @dc42!
                        I'll be having some fun with these documents. I'll document my findings here in case some archeologist ever stumbles over the 3rd known Duex4 🙂
                        Quick question that remains is a hardware one, can I just hook up the 24v fan to the heater pins, or do I need to add a cap in parallel or something to ensure proper PWM?
                        droftartsundefined dc42undefined 2 Replies Last reply Reply Quote 0
                          droftarts administrators @sylvaindc
                          Ha! Think a Duex4 is rare? How about a 'Duet Shield'! There is some documentation: http://reprapltd.com/reprappro/documentation/multi-materials/electronics/index.html and an old post on the RepRap forums where @dc42 posted the schematic https://reprap.org/forum/read.php?4,822811 and board files here https://github.com/reprappro/Duet/tree/dev/Archive_Files/Shield-0.3 (the 0.3 version was the production version, I think, the 0.4 version never made it into production). Posted here for the same archaeologists...
                          I'm not sure how many multimaterial upgrades RepRapPro sold, but I don't think it was many. But I have a Duet Shield! Found it yesterday when wiring up a Duet06 to see if RRF1.22.6 works with DWC 3.2beta2 (it does! However, DWC 3.2 will be the last version that will work with non-Object Model versions of RRF, ie everything before RRF 3.0).
                            sylvaindc
                            Ok, small update.
                              • I localized the pins I should use: Pin: 23, Label: PC21, DuePin: D9, RepRapFirmwareUsage: heat[5] / E4_PWM.
                            • From: https://duet3d.dozuki.com/Wiki/Using_servos_and_controlling_unused_IO_pins#Section_Logical_pin_numbers
                              • Although it doesnt mention Duex4 explicitly, the info on Duex2 and Duex5 I guess E4_PWM is logical pin number 6:
                                • 3-7 seem to be available for heaters on expansion board
                                • this is the 4th one (so 3 + (4 -1) = 6)
                            Does this make sense ?
                              Just hook it up.
                                sylvaindc @dc42
                                Update: according to http://blog.think3dprint3d.com/2015/04/duex4-v02a-minor-updates.html AD12 does not loop through ( I guess it used to on the previous board). It is now exposed via the J16, which is the same jumper as we connect the ground wire to.
                                I can confirm that the IR sensor works as it should via the Duex4 board.
                                  sylvaindc @dc42
                                  Just hook it up.
                                  Sadly the 24v fans are still in the mail, but I went ahead and set it up in config.g:
                                  M106 P0 T45 H1 S255 L1.0	; Existing fan on main Duet0.6 board
                                  M307 H6 A-1 C-1 D-1	        ; Disable Heater 6
                                  M106 P1 H1 S255 L0 A6	        ; Reuse Pin: 23, Label: PC21, DuePin: D9, RepRapFirmwareUsage: heat[5] / E4_PWM as Fan
                                  Sadly I dont see any change to the web frontend. I can only see one fan, and only if I select Tool 0.
                                  Is there a way to see all fans in the web front-end?
                                    You won't see thermostatically controlled fans on the web interface.
                                      sylvaindc @Phaedrux
                                      @Phaedrux said in Duex4 v0.2a (with Duet 0.6):
                                      Cool, that explains it!
                                        sylvaindc
                                        The plot thickens...
                                        I hooked up the Duex4, IR probe work, but the Stepper on E1 doesnt.
                                        So I decided to do a M115:
                                        m115
                                        FIRMWARE_NAME: RepRapFirmware for Duet FIRMWARE_VERSION: 1.26.1 ELECTRONICS: Duet 0.6 FIRMWARE_DATE: 2020-02-09b1
                                        My Google-fu showed a few people who had the same issue, but I cant find a solution... Does anyone have an idea, am I doing something wrong, or is the Duex4 just no longer supported in 1.26?
                                          Can you pos the results of M122?
                                            sylvaindc @Phaedrux
                                            Sure thing!
                                            M122
                                            RepRapFirmware for Duet version 1.26.1 running on Duet 0.6
                                            Used output buffers: 1 of 16 (16 max)
                                            === System ===
                                            Static ram: 44212
                                            Dynamic ram: 42732 of which 3168 recycled
                                            Stack ram used: 1080 current, 2564 maximum
                                            Never used ram: 5628
                                            Last reset 00:09:12 ago, cause: power up
                                            Last software reset at 2020-10-22 23:03, reason: User, spinning module GCodes, available RAM 5004 bytes (slot 0)
                                            Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00000000 BFAR 0xe000ed38 SP 0xffffffff
                                            Error status: 4
                                            Free file entries: 10
                                            SD card 0 detected, interface speed: 21.0MBytes/sec
                                            SD card longest block write time: 12.3ms, max retries 0
                                            MCU temperature: min 10.0, current 26.8, max 27.3
                                            Date/time: 2020-10-22 23:23:27
                                            Slowest loop: 69.21ms; fastest: 0.10ms
                                            Hiccups: 0, FreeDm: 100, MinFreeDm: 100, MaxWait: 0ms
                                            === DDARing ===
                                            Bed heaters = 0, chamberHeaters = -1 -1
                                            Segments left: 0
                                            Movement lock held by null
                                            http is ready with "M122 " in state(s) 0
                                            telnet is idle in state(s) 0
                                            file is idle in state(s) 0
                                            serial is idle in state(s) 0
                                            aux is idle in state(s) 0
                                            daemon is idle in state(s) 0
                                            queue is idle in state(s) 0
                                            Code queue is empty.
                                            === Network ===
                                            Free connections: 15 of 16
                                            Free transactions: 23 of 24
                                            Locked: 0, state: 4, listening: 20071bf4, 0, 20071bd8
