    calibration IR probe RRF3
    Firmware installation
    1.2k
    • Vetiundefined
      Veti @Rudy2A
      post your config
      Rudy2Aundefined 1 Reply Last reply Reply Quote 0
      • Vetiundefined
        Veti @Rudy2A
        @Rudy2A said in calibration IR probe RRF3:
        On the other hand, if I play with BabyStepping or if I adjust the height of my Z in my slicer… does it work? An idea ?
        if you can get a good layer with babystepping adjust the offset by the amount you babystepped.
        • Rudy2Aundefined
          Rudy2A @Veti
          @Veti
          ; generated by RepRapFirmware Configuration Tool v3.1.4 on Thu Oct 22 2020 08:00:14 GMT+0200 (heure d’été d’Europe centrale)
          M550 P"Bunch3D+" ; set printer name
          M669 K1 ; select CoreXY mode
          M552 S1 ; enable network
          M586 P0 S1 ; enable HTTP
          M586 P1 S0 ; disable FTP
          M586 P2 S0 ; disable Telnet
          M569 P0 S0 ; moteur 0 X
          M569 P1 S0 ; moteur 1 Y
          M569 P2 S0 ; moteur 2 ZA
          M569 P3 S0 ; moteur extrudeur
          M569 P4 S0 ; moteur 4 ZB
          M584 X0 Y1 Z2:4 E3 ; set drive mapping
          M671 X-58: 317 Y132: 132 S10 ; vis à plomb à gauche (connectées à Z) et à droite (connectées à E1) de l'axe X
          M350 X16 Y16 Z16 U16 E16 I1 ; configure microstepping with interpolation
          M92 X80 Y80 Z1600 U1600 E830 ; set steps per mm
          M566 X600 Y600 Z60 U60 E2400 ; set maximum instantaneous speed changes (mm/min)
          M203 X11639 Y11639 Z200 U200 E600 ; set maximum speeds (mm/min)
          M201 X800.00 Y800.00 Z40.00 U40.00 E300.00 ; set accelerations (mm/s^2)
          M906 X950 Y950 Z950 U950 E1120 I20 ; set motor currents (mA) and motor idle factor in per cent
          M84 S30 ; Set idle timeout
          M208 X0 Y0 Z-0.5 U-0.5 S1 ; set axis minima
          M208 X270 Y2700 Z240 U240 S0 ; set axis maxima
          M574 Z1 S2 P"io2.in + io3.in"; Axe Z avec deux moteurs, butées min.
          M558 P1 C"zprobe.in+zprobe.mod" H5 F120 T6000
          G31 P500 X-19 Y6 Z2.58 ; set Z probe trigger value, offset and trigger height
          M307 H0 A435.0 C388.3 D7.8 B0 S0.8 V13.4
          M307 H1 A650.7 C221.3 D4.8 B0 S1 V13.3 ; disable bang-bang mode for heater and set PWM limit
          M143 H1 S245
          G10 P0 X0 Y0 Z0 U0 ; set tool 0 axis offsets
          • Rudy2Aundefined
            Rudy2A @Veti
            @Veti
            Déjà fait justement… quand j’obtiens un bon résultat avec les BabyStepping si je veux reporter et ajuster le décalage obtenu, ça ne fait rien… C’est comme si mon G31 Z xxx ne fonctionnait pas. ???
            • Vetiundefined
              Veti @Rudy2A
              if you did not change this to z probe, did you change your homing files?
              i would suggest that you make the changes in the configurator and upload the new config.
              your thermistor settings are incorrect, look up the correct beta value for your thermistor in its documentation
              • Rudy2Aundefined
                Rudy2A
                Thank you for your answers, I don't use Config Tools, I absolutely don't like it ... For my thermistors. Right now, I don't have a problem with that, I can heat up to ready degrees, I'll check it out when I fix my probe problem… Thanks again.
                • Vetiundefined
                  Veti @Rudy2A
                  i was not doubting that. the thermistor has no influence on the heating part. its responsible for displaying the correct temperature.
                  i dont understand, your config has been created by the config tool
                  • Rudy2Aundefined
                    Rudy2A
                    Yes, I used the tool to create the first file to spot where the changes were compared to RRF2. But afterwards, all my changes are done live and without the tool. When I say that I don't like this tool, I should rather say that it is not for me ...
                    • Vetiundefined
                      Veti
                      ok you can still do the changes manually.
                      just loo at the differences in all the files when you select a z probe in the configurator.
                        It can be helpful to send M98 P"config.g" to see if you have any syntax errors.
                        Also very helpful to compare to the output of the online configuration tool.
                        • Rudy2Aundefined
                          Rudy2A @Phaedrux
                          @Phaedrux said in calibration IR probe RRF3:
                          M98 P "config.g"
                          I don’t understand, this is my answer with M98 P "config.g" ????
                          M98 P "config.g"
                          Warning: Macro file "config.g" not found
                          • Vetiundefined
                            Veti @Rudy2A
                            M98 P "config.g"
                            no space after P
                            • Rudy2Aundefined
                              Rudy2A
                              thank's 👍
                              M98 P"config.g"
                              HTTP is enabled on port 80
                              FTP is disabled
                              TELNET is disabled
                              Error: Invalid use of P parameter
                              Warning: Heater 0 appears to be over-powered. If left on at full power, its temperature is predicted to reach 460C
                              Warning: Heater 1 appears to be over-powered. If left on at full power, its temperature is predicted to reach 675C
                              • Vetiundefined
                                Veti @Rudy2A
                                you have one invalid command. execute each line separately until you find it.
                                You dont declare a U axis, but configure it afterwards.
                                • Rudy2Aundefined
                                  Rudy2A
                                  Honestly, I think I have to reinstall everything!
                                  The more I change settings, the more errors I get.
                                  And the problem is, I'm not sure what to declare in the configuration tool ... I'm not talking about the basics like the dimensions of my machine, the size of my bed, the steps of my motors. But how do I declare a double Z, (Z + U) my heating thermistors… other?
                                  • Vetiundefined
                                    Veti @Rudy2A
                                    @Rudy2A
                                    double z see
                                    https://duet3d.dozuki.com/Wiki/Bed_levelling_using_multiple_independent_Z_motors
                                    • Rudy2Aundefined
                                      Rudy2A
                                      I redid and redone my files again ... And nothing helps, nothing changes, worse I'm drowning completely.
                                      Someone with good intention to configure me (bass) my printer with the configuration tool. This would be a bass config file with the declared double Z (Z + U). I'm not asking you to do the work for me, I just want to compare files to understand and then be able to reproduce ... It's the only way for me, I know everything is detailed in procedure, but frankly as you can understand, this It's not easy to assimilate everything technically when it is not written in your mother tongue, a period, a comma, a bad translation and find yourself off topic. Thank you for your help.
                                      Sincerely the file comparison method is working for me. it's not to just copy and paste stupidly, it's to be able to continue to understand the RRF3 logic.
                                      • Vetiundefined
                                        Veti @Rudy2A
                                        @Rudy2A
                                        the reason to go with the configurator is that it generates a config that saves you from small pitfalls.
                                        like order dependency of the commands etc.
                                        in your case changing of the M574 for z probe and changing the homing files no to use the endstops.
                                        • Rudy2Aundefined
                                          Rudy2A @Veti
                                          @Veti
                                          I understand that the configuration tool is there to help me (I do not disagree) and what I ask is that they explain it to me or that they give me a little help to configure it, because it is not easy for me (for lack of fluency in English) to understand everything he asks, it may seem stupid, but I assure you that it is indeed the reality ... with the translation, he gives me a bunch of words that I I have to put things back in order to try to make a solution that is necessarily not always the right one.
                                          The proof, just a simple request for help is already a problem between us, I think the translator does not exactly reproduce my request and makes us go around in circles ... Thank you anyway.
                                          • Vetiundefined
                                            Veti
                                            ask specific questions where you are unsure in the configurator.
                                            then we can hopefully clarify them.
                                            maybe this helps a bit.
                                            https://duet3d.dozuki.com/Guide/Ender+3+Pro+and+Duet+Maestro+Guide+Part+2:+Configuration/38
