    calibration IR probe RRF3
    Firmware installation
    1.2k
      It can be helpful to send M98 P"config.g" to see if you have any syntax errors.
      Also very helpful to compare to the output of the online configuration tool.
      Rudy2Aundefined 1 Reply Last reply Reply Quote 0
      • Rudy2Aundefined
        Rudy2A @Phaedrux
        @Phaedrux said in calibration IR probe RRF3:
        M98 P "config.g"
        I don’t understand, this is my answer with M98 P "config.g" ????
        M98 P "config.g"
        Warning: Macro file "config.g" not found
        • Vetiundefined
          Veti @Rudy2A
          @Rudy2A said in calibration IR probe RRF3:
          M98 P "config.g"
          no space after P
          • Rudy2Aundefined
            Rudy2A
            thank's 👍
            M98 P"config.g"
            HTTP is enabled on port 80
            FTP is disabled
            TELNET is disabled
            Error: Invalid use of P parameter
            Warning: Heater 0 appears to be over-powered. If left on at full power, its temperature is predicted to reach 460C
            Warning: Heater 1 appears to be over-powered. If left on at full power, its temperature is predicted to reach 675C
            • Vetiundefined
              Veti @Rudy2A
              you have one invalid command. execute each line separately until you find it.
              M584 X0 Y1 Z2:4 E3 ; set drive mapping
              M671 X-58: 317 Y132: 132 S10 ; vis à plomb à gauche (connectées à Z) et à droite (connectées à E1) de l'axe X
              M350 X16 Y16 Z16 U16 E16 I1 ; configure microstepping with interpolation
              M92 X80 Y80 Z1600 U1600 E830 ; set steps per mm
              M566 X600 Y600 Z60 U60 E2400 ; set maximum instantaneous speed changes (mm/min)
              M203 X11639 Y11639 Z200 U200 E600 ; set maximum speeds (mm/min)
              M201 X800.00 Y800.00 Z40.00 U40.00 E300.00 ; set accelerations (mm/s^2)
              M906 X950 Y950 Z950 U950 E1120 I20 ; set motor currents (mA) and motor idle factor in per cent
              M84 S30 ; Set idle timeout
              You dont declare a U axis, but configure it afterwards.
              • Rudy2Aundefined
                Rudy2A
                Honestly, I think I have to reinstall everything!
                The more I change settings, the more errors I get.
                And the problem is, I'm not sure what to declare in the configuration tool ... I'm not talking about the basics like the dimensions of my machine, the size of my bed, the steps of my motors. But how do I declare a double Z, (Z + U) my heating thermistors
 other?
                • Vetiundefined
                  Veti @Rudy2A
                  @Rudy2A
                  double z see
                  https://duet3d.dozuki.com/Wiki/Bed_levelling_using_multiple_independent_Z_motors
                  • Rudy2Aundefined
                    Rudy2A
                    I redid and redone my files again ... And nothing helps, nothing changes, worse I'm drowning completely.
                    Someone with good intention to configure me (bass) my printer with the configuration tool. This would be a bass config file with the declared double Z (Z + U). I'm not asking you to do the work for me, I just want to compare files to understand and then be able to reproduce ... It's the only way for me, I know everything is detailed in procedure, but frankly as you can understand, this It's not easy to assimilate everything technically when it is not written in your mother tongue, a period, a comma, a bad translation and find yourself off topic. Thank you for your help.
                    Sincerely the file comparison method is working for me. it's not to just copy and paste stupidly, it's to be able to continue to understand the RRF3 logic.
                    • Vetiundefined
                      Veti @Rudy2A
                      @Rudy2A
                      the reason to go with the configurator is that it generates a config that saves you from small pitfalls.
                      like order dependency of the commands etc.
                      in your case changing of the M574 for z probe and changing the homing files no to use the endstops.
                      • Rudy2Aundefined
                        Rudy2A @Veti
                        @Veti
                        I understand that the configuration tool is there to help me (I do not disagree) and what I ask is that they explain it to me or that they give me a little help to configure it, because it is not easy for me (for lack of fluency in English) to understand everything he asks, it may seem stupid, but I assure you that it is indeed the reality ... with the translation, he gives me a bunch of words that I I have to put things back in order to try to make a solution that is necessarily not always the right one.
                        The proof, just a simple request for help is already a problem between us, I think the translator does not exactly reproduce my request and makes us go around in circles ... Thank you anyway.
                        • Vetiundefined
                          Veti
                          ask specific questions where you are unsure in the configurator.
                          then we can hopefully clarify them.
                          maybe this helps a bit.
                          https://duet3d.dozuki.com/Guide/Ender+3+Pro+and+Duet+Maestro+Guide+Part+2:+Configuration/38
                          • Rudy2Aundefined
                            Rudy2A
                            I assure you that I am not having a bad time. It's like, I wanted to convince you that I made the best wine from home in Corsica by explaining it to you in my written language
 I'm sure you'll be more convinced if I gave it to you!
                            Here are the different stages where I am not comfortable. What should I put for all of these pages?
                            Mini IR Probe
                            Genuine E3D V6
                            Genuine E3D 300X300 bed (Semitec 104GT) 220V
                            thank's
                            • Vetiundefined
                              Veti
                              check: Select the first tool on Start-up.
                              That is helpful for testing.
                              Modulation Pin is not required for the ir probe, as there is no back channel. so set that do not assigned
                              z enstop to not assigned is ok as well, since you want to use the ir sensor.
                              for the e3d. in the the heater window. click on the beta field. and select semitec for both bed and hotend.
                              Add these lines
                              M307 H0 A435.0 C388.3 D7.8 B0 S0.8 V13.4
                              M307 H1 A650.7 C221.3 D4.8 B0 S1 V13.3 ; disable bang-bang mode for heater and set PWM limit
                              to Custom Settings for config.g: on the last page
                              • Rudy2Aundefined
                                Rudy2A
                                Frankly, even installing my original backup file which used to work fine before
 I end up with new errors. It's nothing to understand ... I'm sure too stupid. A function that would be nice to add to the configuration tool would be, from the first step. A button checked which would tell us: if you are a big moron, check this box and the answer would be: since you checked this box, take an interest in Marlin (noisier, cheaper, but configurable without any problem). Two years that I was shooting with RRF2 and no problem, easy configuration and good result. Thanks to RRF3, I think my printer will take some distance with me, by propelling it from the 5th floor, I would have created the first flying 3D printer.
                                  @Rudy2A come now, don't despair. We will get you there eventually, but only if you don't give up.
                                  Can you post your current config.g please?
                                  Double Z/U axis is not needed in RRF3 if you intend to do leveling with two endstops. You only need a U axis if you want manual control of both Z motors.
                                  M574 Z1 S2 P"io2.in + io3.in";
                                  In your config above you have these pins define, but those are pin names for the Duet 3. The rest of your pin names for for Duet 2. I think this may be the cause of the invalid use of P parameter.
                                  Can you restate the current problem?
                                  • Rudy2Aundefined
                                    Rudy2A
                                    First of all, I want to say that I have absolutely nothing against this forum and the people who make it live ... I blame myself and especially not the community for doing its best.
                                    You should also know that I do not speak English and it is very difficult to make yourself understood or to understand you in your answers.
                                    My issue is the following :
                                    I am using a Duet 2 under RRF3.1.1. I absolutely cannot get my Double Z (Z and U) to work independently to level my bed. One of the Z motors is connected to Drive 2 and the other to Drive 4.
                                    When I do a G32, I see the axes (M671) which restore my possible inclination, it works without any problem. On the other hand, for the future with the M557 which runs my two motors, but symmetrically so they do not correct anything since they move equally. I think my whole configuration is corrupted now by dint of modification.
                                    Config.
                                    ; generated by RepRapFirmware Configuration Tool v3.1.4 on Mon Oct 26 2020 11:25:15 GMT+0100 (CET)
                                    M550 P"My Printer+" ; set printer name
                                    M669 K1 ; select CoreXY mode
                                    M552 S1 ; enable network
                                    M586 P0 S1 ; enable HTTP
                                    M586 P1 S0 ; disable FTP
                                    M586 P2 S0 ; disable Telnet
                                    M569 P1 S0 ; physical drive 1 goes forwards
                                    M569 P3 S0 ; physical drive 3 goes forwards
                                    M569 P4 S0
                                    M584 X0 Y1 Z2:4 U4 E3 P3 ; set drive mapping
                                    M671 X-58: 317 Y132: 132 S10; vis à plomb à gauche (connectées à Z) et à droite (connectées à E1) de repÚre X
                                    M92 X80.00 Y80.00 Z1600.00 U1600.00 E830.00 ; set steps per mm
                                    M566 X600.00 Y600.00 Z60.00 U60.00 E2400.00 ; set maximum instantaneous speed changes (mm/min)
                                    M208 X0 Y0 Z-0.5 U0-0.5 S1 ; set axis minima
                                    M208 X270 Y270 Z245 U245 S0 ; set axis maxima
                                    M574 X1 S1 P"xstop" ; configure active-high endstop for high end on X via pin xstop
                                    M574 Y1 S1 P"ystop" ; configure active-high endstop for high end on Y via pin ystop
                                    M574 Z1 S2 P"io2.in" ; Axe Z avec deux moteurs, butées min.
                                    M558 P1 C"zprobe.in+zprobe.mod" H5 F120 T6000 ; set Z probe type to unmodulated and the dive height + speeds
                                    G31 P500 X-19 Y6 Z2.58 ; set Z probe trigger value, offset and trigger height
                                    M557 X11:250 Y11:252 S20 ; define mesh grid
                                    M308 S0 P"bedtemp" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 0 as thermistor on pin bedtemp
                                    ;M307 H0 B0 S1.00 ; disable bang-bang mode for the bed heater and set PWM limit
                                    M308 S1 P"e0temp" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 1 as thermistor on pin e0temp
                                    ;M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit
                                    Bed.g
                                    ; bed.g
                                    G28 ; Home all Axes
                                    M561 ; Efface la correction de plan
                                    M290 R0 S0 ; Efface Baby-stepping
                                    ; Bed levelling (G32)
                                    G30 P0 X0.0 Y132 Z-99999; sonde prĂšs d'une vis sans fin, Ă  mi-chemin le long de l'axe Y
                                    G30 P1 X260 Y132 Z-99999 S2; sonde prĂšs d'une vis et calibrez 2 moteurs
                                    ; Espace de sondage
                                    M557 X11:250 Y11:252 P2 ; Définir la grille maillée
                                    ; Compensation de maillage (G29)
                                    G29 S0
                                    homeall.g
                                    G91 ; relative positioning
                                    G1 H2 Z2 F6000 ;
                                    G1 H1 X-275 Y-275 F1000 ; se dĂ©placer rapidement vers la butĂ©e X ou Y et s'arrĂȘter lĂ  (premier passage)
                                    G1 H1 X-275 ; home X axis
                                    G1 H1 Y-275 ; home Y axis
                                    G1 X4 Y4 F600 ; retour légerement en AR (calage)mm
                                    G1 H1 X-10 ; déplacement lent vers le fin de course de l'axe X
                                    G1 H1 Y-10 ; déplacement lent vers le fin de course de l'axe Y
                                    G90 ; absolute positioning
                                    G1 X129 Y132 F6000 ; Sonde le Z0
                                    G30
                                    homez.g
                                    G91 ; Relative mode
                                    G1 Z250 U250 F2000 S1 ; Move up to 250mm in the +Z direction. S1 to stop if endstop is triggered
                                    G1 Z-2 U-2 F600 S2 ; Move 2mm in the -Z direction - (I'm not sure what S2 is for?)
                                    G1 Z3 U3 F100 S1 ; Move slowly 3mm in the +Z direction, stopping at the homing switch
                                    M584 Z2:4 ; Join U to Z again (pay attention to drive numbers used)
                                    G1 Z-5 F3000 ; Move back again 5mm in the -Z direction
                                    G90 ; Back to absolute mode
                                      Phaedrux Moderator @Rudy2A
                                      You do not need this. io2.in does not exist on your duet 2. and you don't need to define a z axis endstop if you're using the probe.
                                      Double Z (Z and U)
                                      You do not need a U axis at all to do leveling using G32/bed.g as you have now.
                                      homez.g
                                      G91 ; Relative mode
                                      This is unnecessary if you are using bed.g to do the leveling.
                                      Remove the U4 and all references to the U axis in M92, M350, M566, M203, M201, M906, M208. Remove the P3 as well. You don't need it.
                                      M671 X-58: 317 Y132: 132 S10 Remove the space after :
                                      Once you have done all of that, G28 should home all axis, and then G32 should perform tilt correction.
                                      • Rudy2Aundefined
                                        Rudy2A @Phaedrux
                                        Apparently, it seems to be out of order (to watch out for) ...
                                        I still have a slight problem calibrating my probe (mini IR).
                                        When it raises its value.=>>
                                        "Nozzle in the center of the bed (usual temperature)
                                        Put the nozzle in contact with the tray (or the sheet of paper)
                                        G92 Z0 (Z = 0)
                                        Lift the 5mm nozzle (G92 Z5)
                                        G30 S-1
                                        Read the z value
                                        G31 Z xxx"
                                        I get a height of 2.74 and if I indicate this value G31 Z2.72 my first layer is too crushed ... On the other hand if I go down to 2.62 in manual G31 Z2.62, it is good. Is such a Delta normal?
                                        I am in doubt about my order for the probe, does this seem correct to you?
                                        G31 P500 X-19 Y6 Z2.62
                                        Thank you one more for your help!
                                        • Vetiundefined
                                          Veti @Rudy2A
                                          yes, the first step is just to get a close value.
                                          fine adjustment should always be made afterwards.
                                          • Rudy2Aundefined
                                            Rudy2A @Veti
                                            Thank's @Veti
                                            A small clarification on my values.
                                            If I adjust my leveling on 2 points, my first coat is impeccable. (probe at the four corners of the bed) M557 X11: 250 Y11: 252 P2
                                            If I adjust my leveling on 3 points, my first layer is much too high (probe at the four corners and in the center) M557 X11: 250 Y11: 252 P3
                                            Please note that this is the same part that I am printing and no changes have been made.
