    PanelDue extend the wire
    PanelDue
    1.3k
      dc42 administrators @FBG
      @FBG, the maximum recommended resistance per conductor is 0.1 ohms. However, lower than that may allow higher baud rates.
      FBGundefined 1 Reply Last reply Reply Quote 0
      • FBGundefined
        FBG @dc42
        @dc42 My actual wire say: Max conductor resistance 79 ohms/km
        The new wire 1mm say: Max conductor resistance 19.5 ohms/km
        What do you think?
          @FBG said in PanelDue extend the wire:
          What do you think?
          0.079 ohms/m * 3 is about 0.24 ohms, well above the recommended 0.1 ohms maximum. The new wire will be about 0.06 ohms, so well within range.
          • wilrikerundefined
            wilriker @FBG
            @Veti PanelDue 7i version3.2.0, Duet2Ethernet with 3.1.1
            Note that PanelDueFirmware 3.2 will have some minor issues with RepRapFirmware below 3.2. You are using RRF 3.1.1. The expected issues do NOT contain the "Bad command" errors you posted (these are actually more related to your wiring) but once you have sorted them you will still possibly encounter some issues like slower update rates.
            Manuel
            My Tool Collection
            • FBGundefined
              FBG
              @wilriker @Veti @dc42
              Now testing in 1.24PanelDue and 3.1.1Duet2Ethernet.
              Same errors.
              With wire 1mm and 0.06 is worse, only show temperature one time and is as no update nothing...
              I am desperate, i don't know that do...
              • FBGundefined
                FBG @FBG
                @FBG Tested always with all baud rates possibles
                • Vetiundefined
                  Veti @FBG
                  @FBG
                  for testing can you use the 10 pin connector that came with the panel?
                  • FBGundefined
                    FBG @Veti
                    @Veti With this everything is perfect
                    FBGundefined Vetiundefined 2 Replies Last reply Reply Quote 0
                    • FBGundefined
                      FBG @FBG
                      @FBG Sorry, i confused you.
                      I mean that with the original wire 4 pin is perfect.
                      What do you refer with the 10pin??
                      Remember this is PanelDue 7i
                      • Vetiundefined
                        Veti @FBG
                        @FBG
                        and the provided 4 pin cable? is that working as well?
                        • Vetiundefined
                          Veti @FBG
                          i mean the black connector here
                          https://www.duet3d.com/image/cache/catalog/PD7i-03-Back-800x800.jpg
                          but if the original cable works, then we know the its not a problem of the paneldue, but the wiring.
                          how did you crimp your cable?
                          • FBGundefined
                            FBG
                            I can`t understand what do you mean with crimp?
                            I use the same connectors that send with the duet2ethernet
                            • Vetiundefined
                              Veti @FBG
                              @FBG
                              the metal parts at the end of the wire
                              if they dont make good contact that could be a cause of the bad connection.
                              • FBGundefined
                                FBG
                                I use the metal parts that send with duet2ethernet board.
                                I do several times, but this crimped is perfect.
                                I have a lot experience in this because is the same for the another connectors in duet
