About bed leveling & C
@the_dragonlord said in About bed leveling & C:
Tronxy X5S
It's hard to tell from looking at a picture of one but is the bed plate thick enough to be supported by only 3 screws?
As you likely know 3 points define a plane. If the plate is nice and flat 3 screws are all that is needed to level it.
the tronxy 5s is know to be not very stable in itself and needs reinforcement.
the bed wont be much better than any other standard china bed. -
@fcwilt said in About bed leveling & C:
Tronxy X5S
I said 6 not 3....
@Veti said in About bed leveling & C:
the bed wont be much better than any other standard china bed.Infact I reinforced the whole structure a lot
I said 6 not 3....
Yes I know but 3 are less work to get level.
How thick is the metal plate on your printer?
I said 6 not 3....
the metal plate/sheet itself I think is about 1mm thick but between it and the bed there's the magnetic/adhesive layer wich is about 2mm thick, so in total about 3mm of thickness
Sorry I wasn't clear in what I asked.
On my printer there is a metal plate 6mm thick.
The heater is adhered to the bottom of that plate.
The BuildTak piece with all the magnets is adhered to the top of that plate.
Then the flexible BuildTax piece naturally sticks to the piece with the magnets.
So do you have some sort of metal plate under the piece with the magnets?
If so how thick is it?
uh yes, yes of course I have...it's an alluminum plate about 3mm tick I suppose...(I can't find my caliper at now so I can't be more precise)
If it is about 3mm that would explain why you need 6 adjustment screws rather than 3.
All is now clear.
Thanks very much.
All is now clear.
Thanks very much.
you're welcome
