    How to use a LED Strip with Duet 2 WiFI?
    4.4k
      A Former User @ericlmccormick
      @ericlmccormick said in How to use a LED Strip with Duet 2 WiFI?:
      In config. g
      ;LED Strip
      M950 P2 C"e1heat"
      M307 P2 A-1 C-1 D-1
      Then add the following to change power output
      M42 P2 Sxxx
      Done! When I boot the board the pin is setted "high" and the LED stripe is immediately turned on with the maximum pulse width. How can I set to let the pin low when the board starts?
      • ericlmccormickundefined
        ericlmccormick
        Make sure the M42 code is in the slicer startup code and NOT in config.g
        I put M32 in my slicer start code which calls beg.g and M0 in my slicer end code which runs stop.g
        Then I have M42 P2 S255 in my bed.g and M42 P2 S0 in stop.g and cancel.g
          already done but the stripe turns on when I boot the board even without m42
          ericlmccormickundefined 1 Reply Last reply Reply Quote 0
            ericlmccormick @A Former User
            @the_dragonlord can you share your config.g file?
              here it is:
              ; generated by RepRapFirmware Configuration Tool v3.1.4 on Mon Oct 26 2020 18:43:35 GMT+0100 (Ora standard dell’Europa centrale)
              M550 P"DragonCore" ; set printer name
              M669 K1 ; select CoreXY mode
              M552 S1 ; enable network
              M586 P0 S1 ; enable HTTP
              M586 P1 S1 ; enable FTP
              M586 P2 S1 ; enable Telnet
              M569 P0 S0 ; physical drive 0 goes backwards
              M569 P2 S0 ; physical drive 2 goes backwards
              M92 X160.00 Y160.00 Z1200.00 E420.00 ; set steps per mm
              M84 S30 ; Set idle timeout
              M208 X330 Y330 Z400 S0 ; set axis maxima
              M950 S0 C"exp.heater3" ; create servo pin 0 for BLTouch
              M558 P9 C"^zprobe.in" H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
              G31 P500 X0 Y0 Z0.474 ; set Z probe trigger value, offset and trigger height
              M557 X15:315 Y15:315 S20 ; define mesh grid
              M308 S0 P"bedtemp" Y"thermistor" T100000 B4092 ; configure sensor 0 as thermistor on pin bedtemp
              M308 S1 P"e0temp" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 1 as thermistor on pin e0temp
              M106 P1 S1 H1 T50 ; set fan 1 value. Thermostatic control is turned on
              M950 F2 C"fan2" Q500 ; create fan 2 on pin fan2 and set its frequency
              M106 P2 S1 H-1 ; set fan 2 value. Thermostatic control is turned off
              M563 P0 S"E3DVolcano" D0 H1 F0 ; define tool 0
              M501
              uh, I forgot to say that I'm using a PWM fan not an heater.....sorry....
              Phaedruxundefined ericlmccormickundefined 3 Replies Last reply Reply Quote 0
                Phaedrux Moderator @A Former User
                @the_dragonlord said in How to use a LED Strip with Duet 2 WiFI?:
                Which fan header and where is the gcode defining the pin?
                  @the_dragonlord your problem is you have m106 P2 S1 H-1 and you should have m106 P2 S0 H-1
                    @the_dragonlord but I recommend you use a heater and not a fan
                      i can't use a heater because I have to trigger a mosfet to drive the stripe and overriding a heater pin it gives a level of tension not enough for the mosfet to switch. Ay niw I'm using the Fan 2
                        excellent, thanks!
                          @the_dragonlord I'm driving the LEDs directly from the board so that I can control the brightness. But if you are driving a MOSFET, then the fan is a better option I guess.
                            yes it is, thanks
