    How to use a LED Strip with Duet 2 WiFI?
    4.4k
    • Chrissundefined
      Chriss @Phaedrux
      @Phaedrux
      I have a question here too. 🙂
      I use that code to configure my LED strip:
      M950 F3 C"0.out6" Q500
      M106 P3 S0
      (And I have two macros to turn in on and off via the web or display than.)
      So the "controller" is called "Fan 3" on the Display. Is there a way to rename the object? Like I can rename a tool? (563 S"BlaBla")
      Cheers, Chriss
        Phaedrux Moderator @Chriss
        @Chriss Yes, M106 C"LEDs" would give it the name LEDs.
        https://duet3d.dozuki.com/Wiki/Gcode#Section_M106_Fan_On
        Chrissundefined 1 Reply Last reply Reply Quote 0
        • Chrissundefined
          Chriss @Phaedrux
          @Phaedrux
          Thanks! Workes as expected. 🙂 I expected that in the "M950" because that is the configuration of the object to me and "M106" the "on/off" only. So I did not looked into the docu of M106.
          Anyway: Thank you very much for the fast answer.
          Cheers, Chriss
            A Former User @ericlmccormick
            @ericlmccormick said in How to use a LED Strip with Duet 2 WiFI?:
            In config. g
            ;LED Strip
            M950 P2 C"e1heat"
            M307 P2 A-1 C-1 D-1
            Then add the following to change power output
            M42 P2 Sxxx
            Done! When I boot the board the pin is setted "high" and the LED stripe is immediately turned on with the maximum pulse width. How can I set to let the pin low when the board starts?
            • ericlmccormickundefined
              ericlmccormick
              Make sure the M42 code is in the slicer startup code and NOT in config.g
              I put M32 in my slicer start code which calls beg.g and M0 in my slicer end code which runs stop.g
              Then I have M42 P2 S255 in my bed.g and M42 P2 S0 in stop.g and cancel.g
                already done but the stripe turns on when I boot the board even without m42
                ericlmccormickundefined 1 Reply Last reply Reply Quote 0
                  ericlmccormick @A Former User
                  @the_dragonlord can you share your config.g file?
                    here it is:
                    ; generated by RepRapFirmware Configuration Tool v3.1.4 on Mon Oct 26 2020 18:43:35 GMT+0100 (Ora standard dell’Europa centrale)
                    M550 P"DragonCore" ; set printer name
                    M669 K1 ; select CoreXY mode
                    M552 S1 ; enable network
                    M586 P0 S1 ; enable HTTP
                    M586 P1 S1 ; enable FTP
                    M586 P2 S1 ; enable Telnet
                    M569 P0 S0 ; physical drive 0 goes backwards
                    M569 P2 S0 ; physical drive 2 goes backwards
                    M92 X160.00 Y160.00 Z1200.00 E420.00 ; set steps per mm
                    M84 S30 ; Set idle timeout
                    M208 X330 Y330 Z400 S0 ; set axis maxima
                    M950 S0 C"exp.heater3" ; create servo pin 0 for BLTouch
                    M558 P9 C"^zprobe.in" H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
                    G31 P500 X0 Y0 Z0.474 ; set Z probe trigger value, offset and trigger height
                    M557 X15:315 Y15:315 S20 ; define mesh grid
                    M308 S0 P"bedtemp" Y"thermistor" T100000 B4092 ; configure sensor 0 as thermistor on pin bedtemp
                    M308 S1 P"e0temp" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 1 as thermistor on pin e0temp
                    M106 P1 S1 H1 T50 ; set fan 1 value. Thermostatic control is turned on
                    M950 F2 C"fan2" Q500 ; create fan 2 on pin fan2 and set its frequency
                    M106 P2 S1 H-1 ; set fan 2 value. Thermostatic control is turned off
                    M563 P0 S"E3DVolcano" D0 H1 F0 ; define tool 0
                    M501
                    uh, I forgot to say that I'm using a PWM fan not an heater.....sorry....
                    Phaedruxundefined ericlmccormickundefined 3 Replies Last reply Reply Quote 0
                      Phaedrux Moderator @A Former User
                      @the_dragonlord said in How to use a LED Strip with Duet 2 WiFI?:
                      Which fan header and where is the gcode defining the pin?
                        @the_dragonlord your problem is you have m106 P2 S1 H-1 and you should have m106 P2 S0 H-1
                          @the_dragonlord but I recommend you use a heater and not a fan
                            i can't use a heater because I have to trigger a mosfet to drive the stripe and overriding a heater pin it gives a level of tension not enough for the mosfet to switch. Ay niw I'm using the Fan 2
                              excellent, thanks!
                                @the_dragonlord I'm driving the LEDs directly from the board so that I can control the brightness. But if you are driving a MOSFET, then the fan is a better option I guess.
                                  yes it is, thanks
