    Capacitive Sensor
    1.8k
    • Rudy2Aundefined
      Rudy2A
      I would like to test with a 12mm NO capacitive sensor.
      I have a Duet3D 2 and RRF 3.1.1 card, do we have to put a diode on the Z_Probe?
      Thank you.
      • theruttmeisterundefined
        theruttmeister
        You shouldn't need one no.
        (IIRC when its triggered, a NO NPN device will be connecting the black wire to the ground.)
        I'm running the same type of device, just the inductive sensor version.
        Isolate, substitute, verify.
        Rudy2Aundefined 1 Reply Last reply Reply Quote 0
        • Vetiundefined
          Veti @Rudy2A
          @Rudy2A said in Capacitive Sensor:
          are you sure its npn and non pnp?
          do you have a duet wif v1.04?
          • fcwiltundefined
            fcwilt
            I tried one on my printer because of problems with an inductive sensor interacting with my magnetic build surface.
            The problem with the capacitive one was it's slow response time. It has a 50 Hz switching frequency.
            The inductive ones I tried ranged from 800 Hz to 3000 Hz.
            Let us know how it works.
            • Rudy2Aundefined
              Rudy2A
              Yes.
              RepRapFirmware for Duet 2 WiFi/Ethernet version 3.1.1 running on Duet WiFi 1.02 or later
              • Vetiundefined
                Veti @Rudy2A
                not the firmware but the hardware revision.
                see https://duet3d.dozuki.com/Wiki/Connecting_a_Z_probe
                Duet 3, Duet 2 Maestro, or revision 1.04 or later of Duet 2 WiFi or Duet 2 Ethernet: you can connect the output of the sensor directly to the Z-probe IN pin.
                on 1.04 you dont need the diode
                • Rudy2Aundefined
                  Rudy2A @theruttmeister
                  @theruttmeister said in Capacitive Sensor:
                  What result do you get? Are you satisfied?
                  theruttmeisterundefined 1 Reply Last reply Reply Quote 0
                  • Rudy2Aundefined
                    Rudy2A @Veti
                    @Veti
                    So for me, I need one ... I'm Duet WiFi 1.02 if I understand correctly?
                    Vetiundefined 1 Reply Last reply Reply Quote 1
                    • Vetiundefined
                      Veti @Rudy2A
                      no you look up the writing on the board.
                      the firmware can not tell the difference between 1.02, 1.03 and 1.04
                      • Rudy2Aundefined
                        Rudy2A @Veti
                        @Veti said in Capacitive Sensor:
                        ok, on my packaging box is written . V1.04b
                        • Vetiundefined
                          Veti @Rudy2A
                          just to be sure check under the 2 thermistors plugs
                          see https://www.duet3d.com/image/cache/catalog/v104/Wifi_v1.04_above_wb_small-800x800.png
                          where it says duet2 V1.04
                          • Rudy2Aundefined
                            Rudy2A @Veti
                            Thank you, that's it ... duet2 v1.04
                              theruttmeister @Rudy2A
                              Yes.
                              But I'm using a relatively expensive sensor (from IFM), and with printers that have either steel beds or steel flex-plate type surfaces.
                              There was a bunch of testing done a few years ago, we looked at most types of proximity sensors... we found that while inductive are not the most accurate, they are much more consistent than the other options. We found that capacitive sensors vary a lot with ambient temperature, for example. Optical could vary wildly if you use glue on your build surface.
                              They are not perfect, but good enough that I don't worry about finding something better.
                              • Vetiundefined
                                Veti
                                there is a video from tom about it
                                https://www.youtube.com/watch?v=il9bNWn66BY
                                • Rudy2Aundefined
                                  Rudy2A
                                  Return to the installation.
                                  The wiring is very simple and the adjustment of the probe in Config.g too.
                                  Where it goes wrong is with the mesh of the bed ... impossible to have a complete mesh. The nozzle only probes the 2 ends of the front of the deck and stops ... yet normally it should probe all 4 corners as configured.
                                  Tired of searching, I will put back my mini IR probe which for me is not exceptional either (I expected to be frank to be more precise).
                                  Vetiundefined 2 Replies Last reply Reply Quote 0
                                  • Vetiundefined
                                    Veti @Rudy2A
                                    this is most likely because you did not take the probe offset into consideration.
                                    post your config.g
                                    • Rudy2Aundefined
                                      Rudy2A @Veti
                                      @Veti
                                      Exactly, I thought about taking the offset of my probe ... the G32 work good.
                                      ; generated by RepRapFirmware Configuration Tool v3.1.4 on Mon Oct 26 2020 11:25:15 GMT+0100 (CET)
                                      M550 P"My Printer+" ; set printer name
                                      M669 K1 ; select CoreXY mode
                                      M552 S1 ; enable network
                                      M586 P0 S1 ; enable HTTP
                                      M586 P1 S0 ; disable FTP
                                      M586 P2 S0 ; disable Telnet
                                      M569 P1 S0 ; physical drive 1 goes forwards
                                      M569 P3 S0 ; physical drive 3 goes forwards
                                      M569 P4 S0
                                      M584 X0 Y1 Z2:4 E3 ; set drive mapping
                                      M671 X-58:317 Y132:132 S10 ; vis à plomb à gauche (connectées à Z) et à droite (connectées à E1) de repère X
                                      M92 X80.00 Y80.00 Z1600.00 E830.00 ; set steps per mm
                                      M566 X600.00 Y600.00 Z60.00 E2400.00 ; set maximum instantaneous speed changes (mm/min)
                                      M203 X11639 Y11639 Z200 E600 ; set maximum speeds (mm/min)
                                      M201 X800.00 Y800.00 Z40.00 E300.00 ; set accelerations (mm/s^2)
                                      M906 X950 Y950 Z950 E1120 I20 ; set motor currents (mA) and motor idle factor in per cent
                                      M84 S30 ; Set idle timeout
                                      M208 X0 Y0 Z-0.5 S1 ; set axis minima
                                      M208 X270 Y270 Z245 S0 ; set axis maxima
                                      M574 X1 S1 P"xstop" ; configure active-high endstop for high end on X via pin xstop
                                      M574 Y1 S1 P"ystop" ; configure active-high endstop for high end on Y via pin ystop
                                      ;M574 Z1 S2 P"io2.in" ; Axe Z avec deux moteurs, butées min.
                                      M558 P5 C"zprobe.in" H5 F120 T6000 ; set Z probe type to unmodulated and the dive height + speeds
                                      G31 P500 X0 Y-43 Z1.30 ; set Z probe trigger value, offset and trigger height
                                      M557 X11:250 Y11:252 S20 ; define mesh grid
                                      M308 S0 P"bedtemp" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 0 as thermistor on pin bedtemp
                                      M307 H0 A435.0 C388.3 D7.8 B0 S0.8 V13.4
                                      ;M307 H0 B0 S1.00 ; disable bang-bang mode for the bed heater and set PWM limit
                                      M308 S1 P"e0temp" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 1 as thermistor on pin e0temp
                                      M307 H1 A650.7 C221.3 D4.8 B0 S1 V13.3
                                      ;M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit
                                      • Vetiundefined
                                        Veti @Rudy2A
                                        G32 does not create a mesh. G29 does
                                        G32 does true bed leveling.
                                        post your bed.g
                                        • Rudy2Aundefined
                                          Rudy2A @Veti
                                          @Veti
                                          I have known this for a little while and thanks to this forum that there is a difference between G32 and G29. It was just a tip in case ... 😉
                                          ; bed.g
                                          G28 ; Home all Axes
                                          M561 ; Efface la correction de plan
                                          M290 R0 S0 ; Efface Baby-stepping
                                          ; Bed levelling (G32)
                                          G30 P0 X0.0 Y132 Z-99999; sonde près d'une vis sans fin, à mi-chemin le long de l'axe Y
                                          G30 P1 X260 Y132 Z-99999 S2; sonde près d'une vis et calibrez 2 moteurs
                                          • Vetiundefined
                                            Veti @Rudy2A
                                            @Rudy2A
                                            that only has 2 probe point. why do you think it should probe 4 points?
