Strange fan problem
    RogerL
    I Duet wifi and I supply it with 24v
    I have a E3D v6 24v setup and corresponding e3D fan for hotend.
    All has been running great until the fan stopped, I have tested another fan and cables with no luck.
    The I took a multimeter and measured voltage on FAN1, it shows 12v.. I have not changed anything.. It should read 24v, right. FAN0 gives 24v..
    Can someone explain if Im being stupid or if something changed.. To make it even odder I tested with another Duet Wifi but with same config card.. same result 12 v on FAN1
      Veti
      are you sure that the multimeter is working?
      have you measured the voltage of the powers supply with that multimeter?
      undefined 1 Reply Last reply 28 Oct 2020, 15:53 Reply Quote 0
        RogerL @Veti
        @Veti
        Yes I did, its working.
        Just because I wrote this post it now turns again.
        Whatever fixes the problem is good 😀
        undefined 1 Reply Last reply 28 Oct 2020, 15:55 Reply Quote 0
          Veti @RogerL
          @RogerL
          i would suggest you check the wiring.
          maybe there is bare wiring, or the wire is not making good contact
          2 out of 4
