    Purge and prime nozzle
    • Rudy2Aundefined
      Rudy2A
      I'm desperately looking for a way to start all my prints with a light purge and prime my nozzle.
      I would like the front right of my bed to a place where the impression is not possible (I know my X&Y) that my nozzle purges a small amount of material then a light rubbing over a small distance to clean .
      To be included in the slicer startup G-Code or as a file? Do you have an idea, or are you using something extra? Thank you
        I use this for a nozzle prime and it works quite well.
        ;M98 P"0:/sys/PrimeNozzle.g"
        G90 			; Absolute positioning
        G1 X1 Y270 F6000 	; Move to back left corner
        M400 			; clear movement buffer
        M116 			; Wait for temps
        G1 Z0.3 F100		; Move Z to prime height
        G91 			; Relative positioning
        M83 			; Relative extrusion
        G1 E5 F300 ; pre-prime nozzle
        G1 X40 E10 F300 	; Prime line
        G10			; Retract
        G1 Y-1 X1 F10000 	; Wipe nozzle
        M400
        Obviously you'd need to make adjustments for your printer. In my case the print head is homed to the back left corner so that's where the nozzle prime occurs at the start of the print. The amount extruded is based on a 0.6mm nozzle.
        The end result is a small tab of filament that is easy to remove from the bed and leaves the nozzle very clean before the print starts.
        Rudy2Aundefined 2 Replies Last reply Reply Quote 0
        • Rudy2Aundefined
          Rudy2A @Phaedrux
          @Phaedrux said in Purge and prime nozzle:
          Je l'utilise pour une buse d'amorçage et cela fonctionne assez bien.
          Perfect, I'll look into it as soon as I have some time ... Thank you
          • Rudy2Aundefined
            Rudy2A @Phaedrux
            Le résultat final est une petite languette de filament qui est facile à retirer du lit et laisse la buse très propre avant le début de l'impression.
            I have modified some values ​​to adapt them to my configuration, and it works very well ... Thank you
