Question M671 coordinates ?
ok !
and how i cann level my bed ?
i have only setup G29
if you want i can post my config
@lui2004 Ender levels the bed using screws below the table. It is manual process.
@BoA i know they are leveling screws to level but how i dont know
This post is deleted! -
OK, After some reading - there is some support for manual bed leveling. To check the coordinates of bed leveling screws just home the machine, and move the head manually (using paneldue or DWC, not hands
) to get the nozzle over the screw - and current head position is the number You need. But:
For machines without multiple independently-driven Z leadscrews, this command can also be used to define the positions of the bed levelling screws instead. Then bed probing can be used to calculate and display the adjustment required to each screw to level the bed. The thread pitch (P parameter) is used to translate the height adjustment needed to the number of turns of the levelling screws.
This still would require some bed probe installed to measure current bed position.
i use the bltouch
@lui2004 OK Then, so just move the nozzle over the screw and Your current X Y coordinates are the screw coordinates
@lui2004 said in Question M671 coordinates ?:
G30 P0 X28.8 Y24 Z-99999 ; hinten rechts G30 P2 X198.8 Y24 Z-99999 ; hinten links G30 P3 X198 Y194 Z-99999 ; vorne links G30 P4 X28.8 Y194 Z-99999 S4 ; vorne rechts and report adjustments needed
this are my x and y over the screws
G30 P0 X28.8 Y24 Z-99999 ; rear right
G30 P1 X198.8 Y24 Z-99999 ; rearr left
G30 P2 X198 Y194 Z-99999 ; front left
G30 P3 X28.8 Y194 Z-99999 S4 ; front right and report adjustments neededhow i make with this coordinates a M671 ?
sorry for all my stupid questions
@lui2004 I would go with something like:
M671 X28.8:198.8:198:28.8 Y24:24:194:194
Example
M671 X-15.0:100.0:215.0 Y220.0:-20.0:220.0 ; Z leadscrews are at (-15,220), (100,-20) and (215,220)
ok i will test it
thanks for your pacienc
my bed.g in first post is correct ?
@lui2004 I would remove G29 from it, or move it AFTER leveling, or use G29 S2. Also from what I remember, if You have bltouch configured, there is no need to deploy/retract M codes
ok,so i delete deployprobe.g and retractprobe.g from sys
i got this error:
G32 Error: Bed calibration : 4 factor calibration requested but only 1 points provided -
G30 P0 X28.8 Y24 Z-99999 ; hinten rechts G30 P1 X198.8 Y24 Z-99999 ; hinten links G30 P2 X198 Y194 Z-99999 ; vorne links G30 P3 X28.8 Y194 Z-99999 S4 ; vorne rechts and report adjustments needed You missed P1
