    Mesh calibration always outside printbed
    mesh area compensation mesh compensation mesh leveling print move
    800
    • Vetiundefined
      Veti @vcaldas
      @vcaldas
      the rest of the config file would help
      if you go to X0 Y0 is the nozzle on the bottom left corner of the bed?
      is your prove 35 milimeter to the right of the nozzle and 35mm behind?
      • vcaldasundefined
        vcaldas
        @Veti
        Adding the config fileconfig (2).g
        If I go to X0 Y0, the nozzle is exactly at the corner of the printbed and the probe is out of the printbed.
        If I go to X35 Y35 , then both are where they should be.
        • Vetiundefined
          Veti @vcaldas
          @vcaldas
          M208 X220 Y220 Z210 S0 ; set axis maxima
          G31 P500 X35 Y35 Z0.1 ; set Z probe trigger value, offset and trigger height
          M557 X35:200 Y35:200 S55 ; define mesh grid
          There is your problem 200+35 = 235
          that is larger than your bed.
          • vcaldasundefined
            vcaldas
            @Veti Thanks for the suggestion.
            I changed to X50:150 S50 So it is now for sure smaller than the bed and is still having the same issue.
            It's not zeroing on X50 for mesh levelling, but on X0 Y0
            • Vetiundefined
              Veti @vcaldas
              @vcaldas said in Mesh calibration always outside printbed:
              what do you mean by zeroing?
              • vcaldasundefined
                vcaldas
                Sorry for lack of clarification.
                Zeroing was the first point to be probed.
                I would expect the probe starts at X50 Y50 but it is going again to X0 Y0
                • Vetiundefined
                  Veti @vcaldas
                  @vcaldas
                  did you change y as well. it has the same problem as x
                  did you restart after the changes?
                  • vcaldasundefined
                    vcaldas
                    Yes. Both X and Y and giving the same error.
                    I restarted the machine, Checked the files, all is updated.
                    I even put the printer and X40 Y40 and I would expect to be on X50 Y50... it went directly to X0 Y50...
                    Not sure what to do...
                    • Vetiundefined
                      Veti @vcaldas
                      @vcaldas
                      post your changed config
                      vcaldasundefined 1 Reply Last reply Reply Quote 0
                      • vcaldasundefined
                        vcaldas @Veti
                        @Veti Found the issue!
                        I was adding the offsets for X and Y as well and they should be 0
                        The new line becomes
                        G31 P500 X0 Y0 Z0.1 ; set Z probe trigger value, offset and trigger height
                        Problem solved!
                        Thanks for the patience and help!
                        • Vetiundefined
                          Veti @vcaldas
                          no this is incorrect for a bltouch. this means that the nozzle would be the probing point. this will give you an incorrect mesh.
                          • vcaldasundefined
                            vcaldas
                            @Veti that's a very good point.
                            Fixing it to the correct values, there is no more error.
                            G31 P500 X-22 Y0 Z0.1
                            Thanks for pointing that out!
