Duet3+SBC random restart while printing "AssertionFailed"
654
    I've brought it to @DC42's attention, so we'll have to wait for his reply. I've never seen that one either.
      Marco Bona
      @Phaedrux , ok, thanks
        @Marco-Bona, were you using M701 or M702? There's a known issue in 3.2beta that causes assertion failures if you use those commands. It's fixed in the forthcoming 3.2beta3.
          Marco Bona
          @dc42, I was using Rrf3.2b1. After formatting sd card I switched to stable firmware version Rrf3.1.1 which gave me the same error. I am not using M701 / M702 commands. Could you please give me a more detailed description regarding the meaning of the error? I can't find any explanation in the documentation.
            Marco Bona
            @Phaedrux , I tried to send M98 P"config.g". Everything seems ok
              An issue has recently been found with the SBC interface that may explain those errors. That issue has now been fixed, so it will be included in 3.2beta3.
                Marco Bona
                @dc42, thanks.
                When do you think you can release the next update? Is there anything I can do in the meantime to fix the problem?
                undefined 1 Reply Last reply 26 Oct 2020, 19:31 Reply Quote 0
                  dc42 administrators @Marco Bona
                  @Marco-Bona said in Duet3+SBC random restart while printing "AssertionFailed":
                  @dc42, thanks.
                  Very soon I hope, I'm just waiting for @chrishamm to confirm whether DSF and DWC 3.2 are ready.
                    Marco Bona
                    @dc42, can you confirm that the restart caused by "assertion failed" also occurs with firmware version RRF3.1.1?
                    I had never had these problems before.
                    I read in another thread that RRF3.2 b3 will be released next week, is there any solution to fix this problem currently?
                    Thanks
                    Marco
                      "Assertion failed" means that an internal check on the correct operation of the firmware failed. This usually indicates a firmware bug, but it can also be caused by a hardware fault.
                        Marco Bona
                        @dc42, if it was a hardware error how can i run a diagnostic to correct the error?
                        I'm not convinced it's a firmware issue. Yesterday I tried to format the sd card and after reinstalling firmware, it worked correctly, instead today the problem occurred.
                          Marco Bona
                          @dc42,I'm having another problem, I wanted to test with a newer firmware version, but I can't get the updates with "sudo apt-get update \ sudo apt-get upgrade". Do you have any idea?
                          undefined 1 Reply Last reply 31 Oct 2020, 15:37 Reply Quote 0
                            @chrishamm is the expert on that area.
                              Marco Bona
                              @dc42, @chrishamm, I update the situation:
                              -I managed to install the 3.2 beta2 package (sorry but I missed a key point in the guide) and the problem occurred again.
                              -I ran firmware in standalone mode and printer works surprisingly well indeed I dare say it works better than with SBC connected. The printer seems to respond better to the gcode and I noticed that all messages are displayed on paneldue that were not present with the SBC connected.
                              Not to argue and also seeing the problems that other users encounter the question that arises is are you sure that duet3 + SBC works as it should?
                              Are you sure that no changes have been made to what is currently the 3.1.1 revision that was not problematic before?
                              I am now doing a test print in standalone mode and it seems the printer is working fine.
                              I will keep you updated if the problem occurs again even in this condition.
                              18 out of 22
