    Resume from power outage, really only with 24V?
    5.2k
      A Former User @arhi
      @arhi said in Resume from power outage, really only with 24V?:
      10000uF is not hard nor expensive .. get something like this for e.g. even the PRC copy will have at least 10k ... you do not need some high ESR for this purpose...
      the BTR mini ups linked previously is 5x2.7V 5F in series so 13.5V 1F that's even better for 12V Vin. If you want to use it for 24V get two of them and connect in series, you will get 27V 0.5F so still more than enough
      I myself attm use some el cheapo ups devices for every printer and I plan in future to make (or purchase) a DC UPS with 24V lipo packs (6 or 7cell) or 2x sealed lead batteries
      but even a so big capacitor could be mounted in parallel without any resistor?
        A Former User @dc42
        @dc42 said in Resume from power outage, really only with 24V?:
        Yes I did mean 10,000uF.
        ok, i ordered 10 1000uF, could be the same a parallel of 10 of them?
        • arhiundefined
          arhi @A Former User
          @the_dragonlord easy, these big caps have huge ESR so they take a while to charge, for e.g. the one on the picture is 0.5 - 0.8 ohm. Also those 5F ones to make 1F higher voltage one are also huge ESR so they all take a while to charge so they will not kill the PSU.
          you ordered 10x1000uF, that is 10x lower ESR than a single 1000uF. Depending on what 1000uF you purchased (if you got some high quality low ESR ones, especially) they can have low esr, and when you divide it by 10 it will get even lower and in that case they can pull A LOT of current from the PSU and trigger overcurrent protection (or PSU will just die) so in that case you need a slow start circuit (basically a time relay and resistor, for few seconds you charge the caps trough resistor and then after few seconds relay shorts the resistor and you don't waste any more power heating the resistor) ... or if you don't know how to make a slow start circuit and have an old dead PC PSU, you can get PTC from the old PC PSU and use that for current limiting
          e.g. this is 80mR ESR
          this is 50mR ESR:
          so if you for e.g.
          • get that 22000uF
            it will have 15A inrush current
          • get that gloria 10000uF
            it will pull from the 12V rail 140A
          • get that gloria 3300uF
            it will pull from the 12V rail 240A
          • if you put 3 of those 3300uF in parallel to get 10000uF
            it will pull from the 12V rail over 700A inrush current
          will your psu survive any of those I can't say, the e.g. crappy psu that came with ender5 survives the 15A when you connect the 22000uF but does not survive any of the other ones..
            A Former User @arhi
            this is 50mR ESR:
            so if you for e.g.
            • get that 22000uF
            so your hint is to buy a single "great one"
            • arhiundefined
              arhi @A Former User
              @the_dragonlord said in Resume from power outage, really only with 24V?:
              I'd rather go with something like this, if there is no option to add slow start circuit:
              or like this
              but ideally:
              • arhiundefined
                arhi @A Former User
                you already ordered 10x1000uF, just get 50W 1R resistor and add to them so you will add 1R to their ESR making them "low esr" caps 😄 and it should work ok for what you need.
                  A Former User @arhi
                  in your opinion how many of them should I use in parallel? With 1 Ohm resistor about, depending from total capacity, what would be the peak current?
                  • arhiundefined
                    arhi @A Former User
                    how many you have 😄
                    with 1R resistor (note you need 50W, not the 1/8W one 😄 ) the peak current will be, assuming you put enough caps in parallel their total R is 0, so worse case scenario: I = U/R so 12V/1R = 12A
                    get 2 of those 1R resistors and see if 1R is too much, you can connect 2 in parallel to get 0.5R doubling that to 24A of max current that's acceptable by most psu's
                      If the capacitor is connected directly to the PSU, then the slow-start behaviour of the PSU will generally limit the inrush current to a reasonable value.
                      A Former User? arhiundefined 2 Replies Last reply Reply Quote 0
                        A Former User @arhi
                        how many you have 😄
                        I can put even all 10 of them in parallel, I haven't problem about the space to place them... 12A is acceptable, I have a 650W ATX power supply... i think the current peak will last few milliseconds, right? .... so 10 capacitor in parallel with 1 Ohm 50W like in your schematic and I will be fine, right?
                        • arhiundefined
                          arhi
                          wrt those 50W 1R ... you can see 2 50W resistors here on this 220VAC slow start, they are different value but it's the "physical size / case" you are interested in ...
                            A Former User @dc42
                            yes, it will be connected in parallel
                            • arhiundefined
                              arhi @A Former User
                              yes, even 20 or 30 will be ok, the 1R might be too much for 10 caps, you might want to put 2x1R in parallel to get 0.5R to allow for bit faster charging (and later discharging)
                              A Former User? 2 Replies Last reply Reply Quote 0
                              • arhiundefined
                                arhi @dc42
                                it depends heavily on the PSU, bunch of high quality PSU's will not output anything till 12V is stable and pulling 240A from them will trigger overcurrent immediately.
                                the low quality ones will rise the output voltage from the 0 so the caps on the output will only slow down the time it takes to reach full 12V so no res would be necesary
                                  A Former User @arhi
                                  well, it depend how much the resistors are... in my opinion shouldn't be better to make the capacitors to discharge as slowest it's possible to give the board the needed time to save the position and raise a little the Z?
                                    A Former User @arhi
                                    with 1R you mean 1 Ohm, right?
                                    • arhiundefined
                                      arhi @A Former User
                                      well, it depend how much they are...
                                      0.5-5$ depends on availability, quantity..
                                      https://www.digikey.com/en/products/detail/ohmite/TWW20J1R0E/11689204
                                      https://www.ebay.com/itm/5W-10W-20W-Cement-Resistor-0-1R-0-25R-0-47R-0-5R-1R-2R-5R-10R-1K-10K-20K-100K/123783599457?hash=item1cd213d561:g:KT4AAOSwkRtc6L8s
                                      https://www.amazon.com/10PCS-Cement-Resistor-Resistance-resistors/dp/B0789MHZDS/ref=sr_1_1?dchild=1&keywords=1R+20W+resistor&qid=1604164054&sr=8-1
                                      no as if they cannot deliver enough current voltage will drop before you use up the energy from the caps and duet will shutdown sooner than you would like ... you need to allow duet to pull as much current from them as it needs, ideally you only limit inrush current, that's while slow start circuit is best option
                                      • arhiundefined
                                        arhi @A Former User
                                        yes.
                                        btw, depending on the quality of the PSU, it might work without any res, so try first (no need to connect duet, just connect those caps in parallel on the output of the psu), if the psu shuts down you need res, if it works ok you don't need it
                                          A Former User @arhi
                                          yes.
                                          well if it only shut down it will be ok, i didn't want to burn it
                                          • arhiundefined
                                            arhi @A Former User
                                            any half decent PSU will have overcurrent protection .. IMHO if it burns from adding 10x1000uF on the output you should not have bin using it in the first place 😄 ... anyhow you can minimize the chances of a death by
                                            • power with only 1, poweroff
                                            • power with 2 in parallel, poweroff
                                            • power with all 10 in parallel, power off
