Problems with Using the manual bed levelling assistant
@the_dragonlord
it doesnt. it probes at 40 just the nozzle is at 0
@Veti said in Problems with Using the manual bed levelling assistant:
@the_dragonlord
but when it arrives there then it goes to Z=0 and the nozzle crashes the bed because the bltouch is outside
you have to take the probe offset into account when you specify the mesh.
I did do (I suppose):
M557 X40:290 Y10:320 S20 ; define mesh grid -
@the_dragonlord
so you bed has a length of 360 ?
@the_dragonlord
no 330, how have you calculated 360? What a massive mistake have I made?
post your config.g
post your config.g
here it is:
DragonCore
Send code...
Status
Idle
Mode: FFF
Tool Position
X
0.0
Y
0.0
Z
0.00
Extruder Drives
Drive 0
0.0
Speeds
Requested Speed
0 mm/s
Top Speed
0 mm/s
Sensors
Vin
12.1 V
MCU Temperature
26.6 C
Z-Probe
0
Tools
Extra
Control All
Tool Heater Current Active Standby
E3DVolcano
T0 - Load Filament Heater 1
off 24.0 C
0
0
Bed Heater 0
off 23.8 C
0
0
Temperature Chart
System Directory
0:/sys/config.g
; generated by RepRapFirmware Configuration Tool v3.1.4 on Sun Nov 01 2020 08:34:36 GMT+0100 (Ora standard dell’Europa centrale); General preferences
M550 P"DragonCore" ; set printer name
M669 K1 ; select CoreXY mode; Network
M551 P"khiraa090971" ; set password
M552 S1 ; enable network
M586 P0 S1 ; enable HTTP
M586 P1 S1 ; enable FTP
M586 P2 S1 ; enable Telnet; Drives
M569 P0 S0 ; physical drive 0 goes backwards
M569 P2 S0 ; physical drive 2 goes backwards
M350 E16 I0 ; configure microstepping without interpolation
M350 X16 Y16 Z16 I1 ; configure microstepping with interpolation
M92 X159.6 Y159.6 Z1188.11 E411.88 ; set steps per mm
M208 X330 Y330 Z400 S0 ; set axis maxima; Endstops
M574 Z1 S2 ; configure Z-probe endstop for low end on Z; Z-Probe
M950 S0 C"exp.heater3" ; create servo pin 0 for BLTouch
M558 P9 C"^zprobe.in" H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
G31 P500 X39 Y0 Z1.538 ; set Z probe trigger value, offset and trigger height
M557 X40:290 Y10:320 S20 ; define mesh grid; Heaters
M308 S0 P"bedtemp" Y"thermistor" T100000 B4092 ; configure sensor 0 as thermistor on pin bedtemp
M308 S1 P"e0temp" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 1 as thermistor on pin e0temp
M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit; Fans
M106 P1 S1 H1 T50 ; set fan 1 value. Thermostatic control is turned on
M950 F2 C"fan2" Q500 ; create fan 2 on pin fan2 and set its frequency
M106 P2 S0 H-1 ; set fan 2 value. Thermostatic control is turned off; Tools
M563 P0 S"E3DVolcano" D0 H1 F0 ; define tool 0
M501 ; load saved parameters from non-volatile memory; =========================================================
; = D R A G O N C O R E =
; =========================================================M671 X5:165:325:325:165:5 Y325:325:325:5:5:5 P0.5 ; point1 (40,320), point2 (165,320), point3 (290,320), point4 (290,10), point5 (165,10), point6 (10,10)
@the_dragonlord said in Problems with Using the manual bed levelling assistant:
you specified that your probe is to the right of the nozzle, but the picture shows its on the left
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAHHHH I had to write -39?
@the_dragonlord
yes
please read
https://duet3d.dozuki.com/Wiki/Connecting_a_Z_probe#Section_Software_setup_Duet_2_WiFi_Ethernet_running_RepRapFirmware_Num_2 -
@the_dragonlord
yes
please read
https://duet3d.dozuki.com/Wiki/Connecting_a_Z_probe#Section_Software_setup_Duet_2_WiFi_Ethernet_running_RepRapFirmware_Num_2Yes yes, sorry, I didn't mind to type an "?" but an "!".....thanks
@the_dragonlord
yes
please read
https://duet3d.dozuki.com/Wiki/Connecting_a_Z_probe#Section_Software_setup_Duet_2_WiFi_Ethernet_running_RepRapFirmware_Num_2now the probing go fine but in the end I see the error:
M98 P"0:/macros/Bel leveling assistant"
Error: Calibration failed, computed corrections: nan nan nan nan nan nanM98 maybe because I've made a Macro but if I send G32 directly the result is the same
G32
Error: Calibration failed, computed corrections: nan nan nan nan nan nan -
@the_dragonlord
execute each statement manually and see which one fails
@the_dragonlord
none of them:
1/11/2020, 17:48:12 G30 P5 X5 Y5 Z-99999
1/11/2020, 17:47:58 G30 P4 X165 Y5 Z-99999
1/11/2020, 17:47:47 G30 P3 X300 Y5 Z-99999
1/11/2020, 17:47:31 G30 P2 X300 Y320 Z-99999
1/11/2020, 17:47:17 G30 P1 X165 Y320 Z-99999
1/11/2020, 17:46:59 G30 P0 X5 Y320 Z-99999Can be the S6 after the last G30 in the bed.g?
what are you actually trying to do?
I've lunched the G30 manually one by one and none of them gave me the error but when I run G32 it appears the error
@the_dragonlord
no why are you running the G32?
@the_dragonlord
to have an idea on how to adjust the 6 screws.....wouldn't be this the purpose of G32?
@the_dragonlord
as wrote here: https://forum.duet3d.com/topic/12356/error-calibration-failed-computed-corrections-nan-nan-nan-nan/2
In the last G30 I've changed S6 with S-1 and I get:
G32 bed probe heights: -0.634 -0.719 -0.818 -0.339 -0.068 0.045, mean -0.422, deviation from mean 0.327
