    Retrieve duration of Finished Print when reconnecting
    Duet Web Control wishlist
    • r123undefined
      r123
      I run prints overnight and when return laptop will Webcontrol will inevitably have to reconnect (laptop sleep).
      It would be GREAT (and give a much better impression of a fully integrated system) if at that point Webcontrol could retrieve the duration of the print that just finished. That's invariably something I'd like to know!
      Would also be nice to have print end time (a real time) just as we are all hoping for "estimated finish time" to make it's way back in to webcontrol!
      Stephen6309undefined 1 Reply Last reply Reply Quote 2
      • Stephen6309undefined
        Stephen6309 @r123
        @r123 When a print is finished, the time it took is in the Console in DWC.
          Phaedrux Moderator @Stephen6309
          @Stephen6309 said in Retrieve duration of Finished Print when reconnecting:
          Only if DWC was open when it finishes. His laptop is going to sleep and it's not getting collected.
          @r123 I think this could be solved by the addition of writting the total print time to the gcode file itself, which is on the list.
          Stephen6309undefined 1 Reply Last reply Reply Quote 0
            Stephen6309 @Phaedrux
            @Phaedrux
            @r123
            Do a similation before printing to get the close to correct print time added to the gcode.
              If you enable logging using M929 then the start and finish times will be written to the log file.
              • achrnundefined
                achrn
                If you connect to http://<ip address>/machine/status you get the machine model, and that has an entry 'job' 'lastDuration' which looks to me to be duration in seconds of the last print job. (At least, it does on mine - MB6HX + Pi firmware 3.1.1 - I don't know what combinations of hardware are needed for this to be true.)
