    Warning: Controller has been rest
    496
      How are you powering the Pi4?
      Ideally you'd be powering the Pi4 from it's own power supply rather than through the Duet. You can get away with that using the Pi3, but the pi4 draws more power, especially with usb peripherals connected.
      A lot of times issues can be resolved by powering the duet and pi independently.
      https://duet3d.dozuki.com/Wiki/Duet_3_Mainboard_6HC_Hardware_Overview#Section_5V
      TBN3DMakerundefined 1 Reply Last reply Reply Quote 0
      • TBN3DMakerundefined
        TBN3DMaker @Phaedrux
        @Phaedrux i just knew it was something i forgot to mention, even tho i was as thorough as i could.. 🙂
        of course i run the rpi4 from a rpi certified external power brick.. cant live with all the low power warnings i would have gotten in the debain interface if not.. 🙂
        So i'm pretty sure that's not the case..
          TBN3DMaker @TBN3DMaker
          Nov 03 04:07:07 duet3 DuetControlServer[884]: [info] Starting macro file deployprobe.g on channel File
          Nov 03 04:07:07 duet3 DuetControlServer[884]: [info] Finished macro file deployprobe.g
          Nov 03 04:07:08 duet3 DuetControlServer[884]: [info] Starting macro file retractprobe.g on channel File
          Nov 03 04:07:08 duet3 DuetControlServer[884]: [info] Finished macro file retractprobe.g
          Nov 03 04:07:09 duet3 DuetControlServer[884]: [info] Finished macro file homeall.g
          Nov 03 04:07:09 duet3 DuetControlServer[884]: [info] Height map loaded from file heightmap.csv
          Nov 03 04:09:22 duet3 DuetControlServer[884]: [warn] Restarting transfer because a bad data response was received (0x00000003)
          Nov 03 04:09:25 duet3 DuetControlServer[884]: [warn] Bad data checksum (expected 0xbf76, got 0xf115)
          Nov 03 04:11:46 duet3 DuetControlServer[884]: [warn] Bad data checksum (expected 0xb1da, got 0x3148)
          Nov 03 04:16:06 duet3 DuetControlServer[884]: [warn] Bad data checksum (expected 0x1285, got 0xeaa8)
          Nov 03 04:16:06 duet3 DuetControlServer[884]: [warn] Note: RepRapFirmware didn't receive valid data either (code 0x00000003)
          Nov 03 04:16:06 duet3 DuetControlServer[884]: [warn] Bad data checksum (expected 0x1285, got 0x6aab)
          Nov 03 04:16:06 duet3 DuetControlServer[884]: [warn] Restarting transfer because the Duet received a bad response (data response)
          Nov 03 04:16:07 duet3 DuetControlServer[884]: [warn] Restarting transfer because a bad data response was received (0xffffff7d)
          Nov 03 04:16:08 duet3 DuetControlServer[884]: [warn] Restarting transfer because a bad data response was received (0xffffff61)
          Nov 03 04:16:09 duet3 DuetControlServer[884]: [warn] Restarting transfer because a bad data response was received (0xffffff7d)
          Nov 03 04:16:10 duet3 DuetControlServer[884]: [warn] Restarting transfer because a bad header response was received (0x0000002a)
          Nov 03 04:16:48 duet3 DuetControlServer[884]: [warn] Restarting transfer because a bad data response was received (0xffffff7d)
          Nov 03 04:16:50 duet3 DuetControlServer[884]: [warn] Restarting transfer because a bad data response was received (0x0000fc7d)
          Nov 03 04:16:50 duet3 DuetControlServer[884]: [warn] Controller has been reset
          Nov 03 04:16:50 duet3 DuetControlServer[884]: [info] Aborted job file
          Nov 03 04:16:50 duet3 DuetControlServer[884]: [info] Cancelled printing file 0:/gcodes/Cable chain V-Cast/TBN3D_20x10_Lock_21_pieces.gcode, print time was 0h 11m
            Another failed print.. now i got this error messages...
            this time i was at fw 3.2-beta2
              Can you try reflashing your Pi with the newest DuetPi image? Followed by a sudo apt-update, etc
              https://duet3d.dozuki.com/Wiki/SBC_Setup_for_Duet_3#Section_Step_1_Flash_the_image_file
                @Phaedrux it's an option.. but only 3 days since last time i did that. and that didn't make it any better.,.
                the strange thing here is that it's so random.. been printing the same print times today. ec time it takes 5h to print.. no failure then.. and now when i moved over to print other parts the printer crashed twice during.
                by the error messages its seems like the dcs has com problems with the board.
                but it could be an sd issue so maybe 3th time is the charm for me 🙂
                  Phaedrux Moderator @TBN3DMaker
                  @TBN3DMaker said in Warning: Controller has been rest:
                  Ok, in that case don't bother. I thought maybe it was a very old version.
                  Can you share your config.g so we can see what's in it?
                  Also send M98 P"config.g" to see if there are any syntax errors reported.
                  TBN3DMakerundefined 4 Replies Last reply Reply Quote 0
                    @Phaedrux
                    later.. just crashed the whole system when downgrading to 3.1.1 again..
                    i think i have to fight with bossa to get the fw installed again..
                      @Phaedrux
                      Ended in a fatal error! no connection to the board anymore..
                      is there a fast way to completly remove all of duetpi's software from the rpi without have to do a complere new image burn..
                      dpkg: warning: unable to delete old directory '/opt/dsf/dwc/js': Directory not empty
                      dpkg: warning: unable to delete old directory '/opt/dsf/dwc/fonts': Directory not empty
                      dpkg: warning: unable to delete old directory '/opt/dsf/dwc/css': Directory not empty
                      dpkg: warning: unable to delete old directory '/opt/dsf/dwc': Directory not empty
                      dpkg: warning: downgrading duetsoftwareframework from 3.2.0-beta2 to 3.1.1
                      Preparing to unpack .../5-duetsoftwareframework_3.1.1_armhf.deb ...
                      Unpacking duetsoftwareframework (3.1.1) over (3.2.0-beta2) ...
                      To delete the "dsf" user run as root: userdel --force dsf
                      dpkg: warning: downgrading duetsd from 1.1.0 to 1.0.6
                      Preparing to unpack .../6-duetsd_1.0.6_all.deb ...
                      Unpacking duetsd (1.0.6) over (1.1.0) ...
                      dpkg: warning: unable to delete old directory '/opt/dsf/sd/menu': Directory not empty
                      dpkg: warning: downgrading duetruntime from 3.2.0-beta2 to 3.1.1
                      Preparing to unpack .../7-duetruntime_3.1.1_armhf.deb ...
                      Unpacking duetruntime (3.1.1) over (3.2.0-beta2) ...
                      Setting up duetruntime (3.1.1) ...
                      Setting up duetwebcontrol (3.1.1) ...
                      Setting up duetcontrolserver (3.1.1) ...
                      Installing new version of config file /opt/dsf/conf/config.json ...
                      Setting up duettools (3.1.1) ...
                      Setting up duetwebserver (3.1.0) ...
                      Setting up duetsd (1.0.6) ...
                      Setting up reprapfirmware (3.1.1-1) ...
                      [fatal] Could not connect to Duet (Board is not available (no header))
                      Setting up duetsoftwareframework (3.1.1) ...
                      pi@duet3:~ $
                        [0_1604379065578_TBNconfig.g](Uploading 100%) @Phaedrux said in Warning: Controller has been rest:
                        11/3/2020, 5:49:43 AM M98 P"config.g"
                        HTTP is enabled on port 80
                        FTP is disabled
                        TELNET is disabled
                        Warning: Heater 0 appears to be over-powered. If left on at full power, its temperature is predicted to reach 379C
                        Warning: Heater 1 appears to be over-powered. If left on at full power, its temperature is predicted to reach 606C
                        Warning: Heater 2 appears to be over-powered. If left on at full power, its temperature is predicted to reach 871C[0_1604379029712_config (11).g](Uploading 100%)
                        V-Cast IDEX
                        M98 P"config.g"
                        Status
                        Idle
                        Mode: FFF
                        Tool Position
                        X
                        0.0
                        Y
                        0.0
                        Z
                        0.00
                        U
                        0.0
                        Extruder Drives
                        Drive 0
                        0.0
                        Drive 1
                        0.0
                        Speeds
                        Requested Speed
                        0 mm/s
                        Top Speed
                        0 mm/s
                        Sensors
                        Vin
                        24.2 V
                        V12
                        12.1 V
                        MCU Temperature
                        37.7 C
                        Z-Probe
                        1000
                        Tools
                        Extra
                        Control All
                        Tool Heater Current Active Standby
                        E0
                        T0 - Load Filament Extruder L
                        off 26.1 C
                        0
                        0
                        E1
                        T1 - Load Filament Extruder R
                        off 25.6 C
                        0
                        0
                        Bed Bed
                        off 26.5 C
                        0
                        0
                        Temperature Chart
                        System Directory
                        0:/sys/config.g
                        ; Configuration file for Duet 3 (firmware version 3) TBN3DMaker V-cast IDEX Machine
                        ; generated by RepRapFirmware Configuration Tool v3.1.4 on Fri Oct 09 2020 21:11:10 GMT+0200 (Central European Summer Time)
                        G21 ; Work in millimeters
                        ;M575 P1 B57600 S1 ; PanelDue
                        ;M555 P2 ; Set output to look like Marlin (P2=Marlin P1=RepRapFirmware)
                        M550 P"V-Cast IDEX" ; set printer name
                        M586 P0 S1 ; enable HTTP
                        M586 P1 S0 ; disable FTP
                        M586 P2 S0 ; disable Telnet
                        ;Axis and motor config MAPPING/DRIVERS
                        M584 X0.0 U0.1 Y0.2 Z0.3 E0.4:0.5 ; drive mapping IDEX at DRIVER 0.1
                        M569 P0.0 S0 ; physical drive 0.0 goes Backwards X1 mapped as X0.0
                        M569 P0.1 S0 ; physical drive 0.1 goes Backwards X2 Mapped as U0.1
                        M569 P0.2 S0 ; physical drive 0.2 goes Backwards Y mapped as Y0.2
                        M569 P0.3 S1 ; physical drive 0.3 goes forwards Z mapped as Z0.3
                        M569 P0.4 S0 ; physical drive 0.4 goes forwards Extruder 0 mapped as E0.4
                        M569 P0.5 S0 ; physical drive 0.5 goes forwards Extruder 1 mapped as E0.5
                        ; MICRO STEPPING/E-STEPS/CURRENT
                        M350 X16 Y16 U16 Z16 E16:16 I1 ; configure microstepping with interpolation
                        M906 X800 Y800 U800 Z2000 E800:700 I30 ; set motor currents (mA) and motor idle factor in per cent
                        M92 X80.00 Y80.00 U80.00 Z400.00 E830.00:415.00 ; set steps per mm
                        ; MACHINE LIMITS
                        M201 X500.00 Y500.00 U500.00 Z20.00 E250.00:250.00 ; set accelerations (mm/s^2)
                        M203 X12000.00 Y12000.00 U12000.00 Z800.00 E1200.00:1200.00 ; set maximum speeds (mm/min)
                        M204 P5000 T5000 ;set max travel and print acclerations
                        ;M566 X900.00 Y900.00 U900.00 Z12.00 E120.00:120.00 ; set maximum instantaneous speed changes (mm/min) (JERK speed mm/minute)
                        ;M205 X8 Y8 Z8 U8 E:2.0:2.0
                        ;M205 X8 Y8 Z8 U8 E :2:2
                        ;M208 X-51.8 Y-26.00 U0 Z0 S1 ; set axis min
                        M208 X-51.8 Y0 U10 Z0 S1 ; set axis min
                        M208 X298 Y320 Z300 U361.20 S0
                        ;M208 X-51.80 Y-26.00 Z0 U0 S1 ; Set axes minima
                        ;M208 X310 Y320 Z300 U361.20 S0
                        M84 S30 ; Set idle timeout
                        ;Endstops
                        M574 X1 S1 P"!io0.in" ; configure active-high endstop for low end on X via pin io0.in
                        M574 U2 S1 P"!io1.in" ; configure active-high endstop for low end on U via pin io1.in
                        M574 Y1 S1 P"!io2.in" ; configure active-high endstop for low end on Y via pin io2.in
                        M574 Z1 S2 ; Define Z endstop at a probe
                        ;Z-Probe on IO7 pin
                        M950 S0 C"^io7.out"
                        ;M558 P5 C"io7.in" H2.5 F240 T4000 A5 ; Set Z-Probe to type 5 for fast BLTouch mode, 2.5mm dive at 4mm/s 5 attempts
                        M558 P9 C"^io7.in" H3.5 F240 T4000 A1 S0.1 ; Set Z-Probe to type 5 for fast BLTouch mode, 2.5mm dive at 4mm/s 5 attempts
                        ;G31 P25 X-29.75 Y-14.50 Z3.75 ; Set Z probe trigger value, nozzle offsets, and trigger height
                        G31 P500 X-29.75 Y-14.50 Z3.7 ; Set Z probe trigger value, nozzle offsets, and trigger height
                        ;M557 X25:265 Y25:285 P10 ; Define a 10x10 bed mesh
                        ; Heaters / Fans /Tools
                        ;BED
                        M308 S0 P"temp0" Y"thermistor" T100000 B3950 R2200 A"Bed" ; configure sensor 0 as thermistor on pin temp0
                        ;M307 H0 B1 S1.00 ; enable bang-bang mode for the bed heater and set PWM limit
                        M307 H0 A354.8 C449.0 D2.6 S1.0 V24.2 B0
                        ;EXTRUDER 0 X******
                        ; TOOL E0 X
                        M563 P0 D0 H1 F0 S"E0" ; define tool 0
                        ;HEATER/TEMP
                        M308 S1 P"temp1" Y"thermistor" T100000 B4725 C7.06e-8 A"Extruder L" ; configure sensor 1 as thermistor on pin temp1 (E3D Thermistor)
                        ;M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit
                        ;M307 H1 A577.3 C154.8 D5.6 S1.0 V24.1 B0
                        M307 H1 A581.6 C182.1 D5.2 S1.0 V24.1 B0
                        M143 H1 S300
                        M570 S360 ; Heater fault detection allow 1 minute
                        ;Fans
                        M950 F0 C"out4" Q500 ; create fan 0 on pin out4 and set its frequency
                        M106 P0 C"E0 Part Cooling" S0 H-1 ; set fan 0 name and value. Thermostatic control is turned off
                        M950 F1 C"out7" Q500 ; create fan 1 on pin out7 and set its frequency
                        M106 P1 C"E0 Heat Brake" S1 H1 T45 ; set fan 1 name and value. Thermostatic control is turned on
                        ;EXTRUDER 1 U******
                        ;TOOL 1 U
                        M563 P1 D1 H2 F2 X3 S"E1" ; tool 1 uses extruder 1 and heater 2 and maps X to U, use fan 2 as the print cooling fan
                        ;G10 P1 Y-0.55 Z-0.1 U-5.9 ; set tool 1 axis offsets
                        ;G10 P1 Y-0.54 Z-0.1 U-5.8 ; set tool 1 axis offsets
                        ;G10 P1 Y-0.53 Z-0.1 U-5.8 ; set tool 1 axis offsets
                        ;G10 P1 Y-0.4 Z-0.1 U-5.6 ; set tool 1 axis offsets U/Y Negative number = printhead more towards right/Towards Back of the plate
                        ;G10 P1 Y-0.35 Z-0.1 U-5.55 ; set tool 1 axis offsets U/Y Negative number = printhead more towards right/Towards Back of the plate
                        ;G10 P1 Y-0.42 Z-0.1 U-5.62 ; set tool 1 axis offsets U/Y Negative number = printhead more towards right/Towards Back of the plate
                        G10 P1 Y-0.43 Z-0.07 U-5.62 ; set tool 1 axis offsets U/Y Negative number = printhead more towards right/Towards Back of the plate
                        G10 P1 S0 R0 ; set initial tool 1 active and standby temperatures to 0C
                        ;HEATER/TEMP
                        M308 S2 P"temp2" Y"thermistor" T100000 B4725 C7.06e-8 A"Extruder R" ; configure sensor 2 as thermistor on pin temp2 (E3D Thermistor)
                        M950 H2 C"out2" T2 ; create nozzle heater output on out2 and map it to sensor 2
                        ;M307 H2 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit
                        ;M307 H2 A890.6 C188.9 D6.2 S1.0 V24.1 B0
                        M307 H2 A846.8 C209.8 D5.6 S1.0 V24.1 B0
                        M143 H2 S300
                        ;Fans
                        M950 F2 C"out5" Q500 ; create fan 2 on pin out5 and set its frequency
                        M106 P2 C"E1 Part Cooling" S0 H-1 ; set fan 2 name and value. Thermostatic control is turned off
                        M950 F3 C"out8" Q500 ; create fan 3 on pin out8 and set its frequency
                        M106 P3 C"E1 HeatBreake" S1 H2 T45 ; set fan 3 name and value. Thermostatic control is turned on
                        ; Tools / EXTRUDERS
                        ;m404 N1.75 D0.4
                          @Phaedrux but i managed to reset the fw. and now i'm on standalone mode.. just to see if the problem still exists..
                            That would have been my next suggestion.
