    True wifi printing
    Hardware wishlist
    10
    28
    5.3k
    • Whitewolfundefined
      Whitewolf
      Well to me its not duplicating functionality…. Simplify3D already supports this on printers that have built in wifi printing.
      To me i find it more of a pain to save sliced file, open browser tab upload file oopse first layer failed rinse repeat when instead i could just push the print button from Simplify3D. that and its far easier to send prints to multiple printers from simplify3d then to repeat this process for each printer.
      The web panel serves a great purpose for managing the controller/firmware but for prints especially with many machines using simplify3d is just quicker.
      • tomasfundefined
        tomasf
        You could automate it by writing a script and run it as a post-processing script in Simplify3D.
        I wrote a Mac app, launched from an S3D post-processing script, that lets me pick a directory on the Duet to upload to, and presents an option to print after upload. 🙂
        • cbusilloundefined
          cbusillo
          Tomasf… I would love to use that app. I have 3 factory files saved that each represent a printer. The post processing script in each one uploads to the correct queue on Repetier Server and automatically starts the print. I have been looking for a way to duplicate that functionality with the Duet.
          • tomasfundefined
            tomasf
            @cbusillo:
            I uploaded it to GitHub: https://github.com/tomasf/DuetUploader
            It's very much unfinished, but it should work. You can use it like this in your post-processing script in Simplify3D:
            [c]open -a "/Applications/Duet Uploader.app" "[output_filepath]"[/c]
            • cbusilloundefined
              cbusillo
              Super cool. Is there a way via parameters I can tell it which printer to upload to? Maybe I should just open the project 😃
                Whitewolf
                thanks for sharing
                • tomasfundefined
                  tomasf
                  @cbusillo:
                  Yeah, you set the hostname in Preferences 🙂
                  • JohnOCFIIundefined
                    JohnOCFII
                    That looks very useful!
                    • tomasfundefined
                      tomasf
                      Once we start using firmware 1.19 and get FTP support again, perhaps scripting Transmit or something similar will be a better idea than using a dedicated app for uploading.
                        Bear in mind that direct wifi printing comes with security implications. What facilities does S3D provide for authenticating access to the printer over WiFi?
                        • Crash69undefined
                          Crash69
                          I like the idea of some sort of file transfer script to the duet as a S3D post process, mainly to reduce the steps required…
                          I've come from smoothieboard, which at the time had problems with S3D.. so I'm used to annoying steps in the process, the smoothie/s3d issues is now comipletely fixed by the way, but what I used to have to do was:
                          • Slice in S3D, save to temp folder
                          • alt-tab to web site for S3D move cleanup process
                          • upload gcode file from temp folder
                          • Save processed file back to temp folder
                          • alt-tab to octoprint page
                          • Hit print & watch
                          So I'm pretty used to multiple steps. but its better now, with my DUET my process is:
                          • alt-tab to DWC page
                          • Hit print & watch
                          If I could have a S3D post process script that saved the file directly to the DUET, probably via FTP I assume would be easiest.. then it would save having to have a temp folder and the upload step.. it would end up:..
                          • Slice in S3D, (Post process script saves directly to DUET.. with option on what folder it saves to? )
                          • Hit print & watch
                          • cbusilloundefined
                            cbusillo
                            DC42… I have in mind more like the Octo/Repetier method. HTTP upload and control. There is an API key generated to keep it secure
                            • Jackalundefined
                              Jackal
                              @Crash69:
                              • Hit print & watch
                              • Hit print & watch
                              • Hit print & watch
                              In S3D scripts > Post processing
                              curl -d "@[output_filepath]" -X POST [http://xxx.xxx.xxx.xxx/rr_upload?name=gcodes](http://xxx.xxx.xxx.xxx/rr_upload?name=gcodes)[output_filename].gcode
                              It will upload the file upon saving gcode
                              • cbusilloundefined
                                cbusillo
                                @Jackal:
                                Is there a way to start it automatically?
                                • Jackalundefined
                                  Jackal
                                  @cbusillo:
                                  @Jackal:
                                  You mean start printing?
                                  I believe it can be done with the same manner. Will try when I get home.
                                  • robmundefined
                                    robm
                                    @cbusillo:
                                    Upvote. I put a feature request on the Slic3r Github to have a more generic 'send to printer' option like a command line, but emulating OctoPrint to receive gcode for printing might be a faster way to fitting in with more existing systems.
                                    • cbusilloundefined
                                      cbusillo
                                      @Jackal:
                                      Looking forward to this!
                                      • Jackalundefined
                                        Jackal
                                        @cbusillo:
                                        @Jackal:
                                        I am using windows, so not sure if this works for Mac or not.
                                        You will need to download curl and have it in your system path
                                        then put these in Post Processing > Additional terminal commands for post processing (Replace the IP with your Duet IP)
                                        [c]curl –data-binary "@[output_filepath]" -X POST http://192.168.1.###/rr_upload?name=gcodes[output_filename].gcode
                                        curl -G http://192.168.1.###/rr_gcode –data-urlencode "gcode=M32 [output_filename].gcode"[/c]
                                        The file will be uploaded and printed upon saving the g-code
                                        If you want to disable it, add 'rem' before each of the line to skip them
                                        edit: use M32 instead of M23 M24
                                        • tomasfundefined
                                          tomasf
                                          It's probably easier to use [c]M32[/c] instead of [c]M23[/c] + [c]M24[/c].
                                          • Jackalundefined
                                            Jackal
                                            @tomasf:
                                            Thanks for the heads up, I just put in the first one I found on the wiki
