    True wifi printing
    Hardware wishlist
    10
    28
    5.4k
    • tomasfundefined
      tomasf
      @cbusillo:
      Super cool. Is there a way via parameters I can tell it which printer to upload to? Maybe I should just open the project 😃
      Yeah, you set the hostname in Preferences 🙂
      • JohnOCFIIundefined
        JohnOCFII
        That looks very useful!
        • tomasfundefined
          tomasf
          Once we start using firmware 1.19 and get FTP support again, perhaps scripting Transmit or something similar will be a better idea than using a dedicated app for uploading.
            Bear in mind that direct wifi printing comes with security implications. What facilities does S3D provide for authenticating access to the printer over WiFi?
            • Crash69undefined
              Crash69
              I like the idea of some sort of file transfer script to the duet as a S3D post process, mainly to reduce the steps required…
              I've come from smoothieboard, which at the time had problems with S3D.. so I'm used to annoying steps in the process, the smoothie/s3d issues is now comipletely fixed by the way, but what I used to have to do was:
              • Slice in S3D, save to temp folder
              • alt-tab to web site for S3D move cleanup process
              • upload gcode file from temp folder
              • Save processed file back to temp folder
              • alt-tab to octoprint page
              • Hit print & watch
              So I'm pretty used to multiple steps. but its better now, with my DUET my process is:
              • alt-tab to DWC page
              • Hit print & watch
              If I could have a S3D post process script that saved the file directly to the DUET, probably via FTP I assume would be easiest.. then it would save having to have a temp folder and the upload step.. it would end up:..
              • Slice in S3D, (Post process script saves directly to DUET.. with option on what folder it saves to? )
              • Hit print & watch
              • cbusilloundefined
                cbusillo
                DC42… I have in mind more like the Octo/Repetier method. HTTP upload and control. There is an API key generated to keep it secure
                • Jackalundefined
                  Jackal
                  @Crash69:
                  • Hit print & watch
                  • Hit print & watch
                  • Hit print & watch
                  In S3D scripts > Post processing
                  curl -d "@[output_filepath]" -X POST [http://xxx.xxx.xxx.xxx/rr_upload?name=gcodes](http://xxx.xxx.xxx.xxx/rr_upload?name=gcodes)[output_filename].gcode
                  It will upload the file upon saving gcode
                  • cbusilloundefined
                    cbusillo
                    @Jackal:
                    Is there a way to start it automatically?
                    • Jackalundefined
                      Jackal
                      @cbusillo:
                      @Jackal:
                      You mean start printing?
                      I believe it can be done with the same manner. Will try when I get home.
                      • robmundefined
                        robm
                        @cbusillo:
                        Upvote. I put a feature request on the Slic3r Github to have a more generic 'send to printer' option like a command line, but emulating OctoPrint to receive gcode for printing might be a faster way to fitting in with more existing systems.
                        • cbusilloundefined
                          cbusillo
                          @Jackal:
                          Looking forward to this!
                          • Jackalundefined
                            Jackal
                            @cbusillo:
                            @Jackal:
                            I am using windows, so not sure if this works for Mac or not.
                            You will need to download curl and have it in your system path
                            then put these in Post Processing > Additional terminal commands for post processing (Replace the IP with your Duet IP)
                            [c]curl –data-binary "@[output_filepath]" -X POST http://192.168.1.###/rr_upload?name=gcodes[output_filename].gcode
                            curl -G http://192.168.1.###/rr_gcode –data-urlencode "gcode=M32 [output_filename].gcode"[/c]
                            The file will be uploaded and printed upon saving the g-code
                            If you want to disable it, add 'rem' before each of the line to skip them
                            edit: use M32 instead of M23 M24
                            • tomasfundefined
                              tomasf
                              It's probably easier to use [c]M32[/c] instead of [c]M23[/c] + [c]M24[/c].
                              • Jackalundefined
                                Jackal
                                @tomasf:
                                Thanks for the heads up, I just put in the first one I found on the wiki
                                • cbusilloundefined
                                  cbusillo
                                  You are my hero! Works perfectly. I need to work on my upload speed or at least get it to do the upload in the background. a 30MB files takes a couple minutes to upload.
                                  • fulgundefined
                                    fulg
                                    @Jackal:
                                    Note that this will only work if you have previously connected to DWC via your browser first. If you didn't connect to DWC since the last reset of your Duet, the first call to curl will silently fail with HTTP error 500, and the second one will start printing the old version of your gcode file if one was already there. If not, then nothing will happen.
                                    So there is no perfect solution yet… I wish we had an API key like octoprint so uploads would be secure and accepted with a single curl command.
                                    Cheers,
                                    Ben.
                                    EDIT: You can mitigate this somewhat by issuing an M30 beforehand to delete the existing file on the Duet, so if the upload fails then it won't try to print an outdated file. So the full block becomes:
                                    [c]curl -G http://192.168.1.###/rr_gcode –data-urlencode "gcode=M30 [output_filename].gcode"
                                    [/c]
                                    VORON V2 CoreXY + Duet3 Mini5+ Ethernet v1.0 with Mini2+ expansion, VORON V0 CoreXY + Duet2 Maestro
                                    • cbusilloundefined
                                      cbusillo
                                      Is there a way for it to work on files with spaces in them? I know the easy answer is to save without spaces, but sometimes I forget 😃
                                      Good call on the delete statement first!
