Duet 3/Rpi + toolboard on 3.2b3 - G29 fails
@oozeBot said in Duet 3/Rpi + toolboard on 3.2b3 - G29 fails:
@dc42 I still have one machine running 3.2b3 if there is anything you or others want me to test on this issue.
I plan on rolling back to 3.2b1, creating a height map, and the moving then back to 3.2b3 for other testing by this afternoon though.
@chrishamm, is there anything else you would like @oozeBot to test?
@dc42 said in Duet 3/Rpi + toolboard on 3.2b3 - G29 fails:
I tried it yesterday and it seems to work but from 3.2b2 instead of 3.2b1 to 3.2b3
@oozeBot Thanks for reporting this issue, I could reproduce it and I'm testing a potential fix for this problem.
@chrishamm great! I didn't get around to rolling this machine back to 3.2b1, so please let me know if you want me to test your fix..
@oozeBot Yes, I am quite sure I could figure out what was going on. Please try out this firmware build with DSF 3.2-b3: https://pkg.duet3d.com/Duet3Firmware_MB6HC.bin You can upload it on the System page and confirm the update prompt.
@chrishamm This appears to be fixed. I just completed a 196 probe mesh without issue. Thanks!
@chrishamm scratch that - while it did complete, DWC is still in a busy state where it will not accept any new commands.
@oozeBot Please try to download and flash that file again - I just updated it once more with my other hotfix. If it remains in the "busy" state with that build, please share the debug log of DCS and I'll see what I can do.
@chrishamm will do it right now.. thanks
it stayed in a busy state. I'll capture the DCS log and upload here soon..
@oozeBot I could just reproduce this problem and will look into it again. To my surprise it worked nicely before with 100 points.
@chrishamm ok, I'll hold off on uploading a log. Please let me know if you have another update to test.
@oozeBot I've updated my experimental Duet 3 MB6HC binary again because I found one more potential problem in it.
@jay_s_uk The same issue will probably affect your Duet 3 Mini 5+ v0.2 as well, so here is another build for you in case you want to test it before the next release.
@chrishamm thanks - I'll try now and report back..
@chrishamm When trying to upgrade the firmware when the board is connected to an SBC, I get this error.
I also got this when I initially upgraded to 3.2beta3 and used the erase method to upgrade the firmware.
I ran the upgrade for the other build you did in standalone mode as I was doing some testing at the time. -
@jay_s_uk I guess you uploaded that file before when DWS was running as root. To fix that, connect to your Pi via SSH and run
sudo chown -R dsf.dsf /opt/dsf
. Then you should be able to upload it again when DWS is running as the regular service.PS: Be aware that you need to delete the new v0.4 IAP binary and rename the v0.2 IAP binary by removing the _v02 suffix from the other filename, else the upgrade will fail on the v0.2 prototype.
@chrishamm first try of 169 point mesh worked! I'm going to reboot and do it again here in just a few minutes..
@chrishamm After rebooting, I cannot get my z-axis to home.. it is not following the macro, which is pasted below. It only touches the probe down once in the middle of the plate on line 20. It skips line 27 and immediately moves to X20 Y20. On line 29, it touches down once or twice and then goes down again without extending the probe - I have moments to pull the plug at this point or else it will crash into the bed.
This is new to the last file you uploaded after a reboot.
; == home the Z axis ================================================ M400 ; wait until idle M280 P0 S160 ; reset BL Touch if move.axes[0].homed == false M98 P"homex.g" if move.axes[1].homed == false M98 P"homey.g" G92 Z0 G1 X132.5 Y0 Z5 F24000 ; move to the front center of the build plate M400 ; wait until idle M561 ; clear any bed transforms M558 F1200 A1 G92 Z333 G30 Z-99999 ; sets z-height relative to print bed M566 Z140.00 M201 Z300.00 M558 F120 A10 M561 G30 Z-99999 G30 P0 X20 Y20 Z-99999 ; probe midway between front and rear belt on left side G30 P1 X284.80 Y20 Z-99999 S2 ; probe midway between front and rear belt on right side M566 Z300.00 M201 Z300.00 G1 X0 Y0 Z10 F24000 ; park the tool M400 ; wait until idle
@oozeBot Okay, I'll test some more conditional G-code tomorrow. Unfortunately your macro is rather difficult to test for me because I don't have two Z motors, so it would help if you could share the debug log again.
@chrishamm I'll get that uploaded here in the next hour or two. FYI - here are my deployprobe.g and retractprobe.g.
deployprobe.g
M280 P0 S10
retractprobe.g
M280 P0 S90
