Printing too high.
Maybe if have to compare to how it sounded before but that doesn't sound too bad to me.
You can try reducing the motor current a bit. Try 600 or 700 instead of 800.
@Phaedrux it was silent before this sounds like back emf or something
@evilfknpotato reduced current to 600 and still the same
is it worth upgrading to v3.0?
@evilfknpotato said in Printing too high.:
I wouldn't think it would make a difference but I also wouldn't have thought moving from 2.0 to 2.05 would have changed anything either.
Going to rrf3 would require changes to your config file. If you wanted to test it you should back up your current config files and then generate a new config from the online tool for rrf3 to test with.
@Phaedrux exactly my thoughts but something must have changed, voltages?
try changing the M569
M569 P0 S1 D3 V40 ; physical drive 0 goes backwards
M569 P1 S1 D3 V40; physical drive 1 goes backwards
M569 P2 S0 D3 V40; physical drive 2 goes forwards
M569 P3 S1 D3 V40 ; physical drive 3 goes backwardsprint the output of
M569 P0 afterwards -
@Veti you sir are very helpful, that worked like a treat, what did this do?
@Veti M569 P0
Drive 0 runs forwards, active low enable, step timing fast, mode stealthChop, ccr 0x00053, toff 3, tblank 0, hstart/hend/hdec 5/0/0, tpwmthrs 40 (234.4 mm/sec) -
in newer version of the firmware the switchover from stealthchop to spreadcycle was implemented.
spreadcycle is louder
above like 10mm it will switch to spreadcycle by default.
this increases the limit.
however stealthchop is weaker, so it might cause layer shifts.
if your extruder is skipping, i would suggest that you switch that over to spreadcycle
by just changing
M569 P3 S1 D2 -
