    Update to 3.2beta3 failed
    Beta Firmware
    870
    • chrishammundefined
      chrishamm administrators @Lucas
      @Lucas https://duet3d.dozuki.com/Wiki/Getting_Started_With_Duet_3#Section_Updating_Duet_3_main_board_firmware
      Duet software engineer
        Phaedrux Moderator @chrishamm
        @chrishamm I think he's got 3.2beta3 on the duet and on the Pi, but no communication between them.
        @Lucas Can you test continuity of your ribbon cable?
        How do you have the Pi and Duet powered?
        • Lucasundefined
          Lucas
          @Phaedrux the Pi is powered by the Duet via the ribbon cable and the duet is powered by a 24V power supply on the "Power In" connector.
          I flashed the Duet to the version 3.1.1 and flashed the Pi again too and now it's working. I'll stay on the stable version for now.
          I don't really know why the communication was broken because both the Duet and the Pi seemed to work fine on their own.
          Anyway, thanks everyone for your help!
            Phaedrux Moderator @Lucas
            @Lucas said in Update to 3.2beta3 failed:
            Pi3 or Pi4? Any peripherals? It's probably a good idea to power both the duet and Pi separately.
            https://duet3d.dozuki.com/Wiki/Duet_3_Mainboard_6HC_Hardware_Overview#Section_5V
            Lucasundefined 1 Reply Last reply Reply Quote 0
            • Lucasundefined
              Lucas @Phaedrux
              @Phaedrux It's a Pi3 and the only peripheral is the official raspberry camera. I didn't knew it's recommended to power them separately, I'll change my wiring. Thanks for the information!
                @Lucas It was originally hoped that powering the SBC from the duet would be possible, and with the Pi3 it usually is, provided there are no high powered peripherals, but the pi4 uses more power than the pi3. And once you add a peripheral like a usb powered display all bets are off.
                It would be worth testing with them powered separately at any rate.
                • Lucasundefined
                  Lucas
                  As @Phaedrux suggested I changed my setup to power the Pi separately and as expected it was still working perfectly.
                  And then I saw that @dc42 released the version 3.2beta3.2 of ReprapFirmware and that one of the purpose of this release is to address communication issues with an attached single board computer. So I decided to give a new shot to the 3.2beta3 and... I encountered the same issue that the one described in my first post 😕
                  The upgrade is stuck on "Sending update request to DCS..." for 25 minutes now and DuetWebControl is displaying this message: "Please wait while updates are being installed...". Usually this process takes a few seconds and I'm pretty sure that if I stop the upgrade I'll have the same communication problem as before.
                  Here are the upgrade logs:
                  sudo apt-get upgrade
                  Reading package lists... Done
                  Building dependency tree
                  Reading state information... Done
                  Calculating upgrade... Done
                  The following packages will be upgraded:
                    duetcontrolserver duetruntime duetsd duetsoftwareframework duettools duetwebcontrol duetwebserver reprapfirmware
                  8 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
                  Need to get 33.9 MB of archives.
                  After this operation, 0 B of additional disk space will be used.
                  Do you want to continue? [Y/n]
                  Get:1 https://pkg.duet3d.com unstable/armv7 armhf duetsoftwareframework armhf 3.2.0-beta3 [2,034 B]
                  Get:2 https://pkg.duet3d.com unstable/armv7 armhf duetsd all 1.1.0 [2,102 B]
                  Get:3 https://pkg.duet3d.com unstable/armv7 armhf duettools armhf 3.2.0-beta3 [62.2 kB]
                  Get:4 https://pkg.duet3d.com unstable/armv7 armhf duetcontrolserver armhf 3.2.0-beta3 [226 kB]
                  Get:5 https://pkg.duet3d.com unstable/armv7 armhf duetruntime armhf 3.2.0-beta3 [28.9 MB]
                  Get:6 https://pkg.duet3d.com unstable/armv7 armhf duetwebserver armhf 3.2.0-beta3 [83.9 kB]
                  Get:7 https://pkg.duet3d.com unstable/armv7 armhf duetwebcontrol all 3.2.0-beta3 [3,507 kB]
                  Get:8 https://pkg.duet3d.com unstable/armv7 armhf reprapfirmware all 3.2.0-beta3-2 [1,157 kB]
                  Fetched 33.9 MB in 10s (3,450 kB/s)
                  Reading changelogs... Done
                  (Reading database ... 57772 files and directories currently installed.)
                  Preparing to unpack .../0-duetsoftwareframework_3.2.0-beta3_armhf.deb ...
                  Unpacking duetsoftwareframework (3.2.0-beta3) over (3.1.1) ...
                  Preparing to unpack .../1-duetsd_1.1.0_all.deb ...
                  Unpacking duetsd (1.1.0) over (1.0.6) ...
                  Preparing to unpack .../2-duettools_3.2.0-beta3_armhf.deb ...
                  Unpacking duettools (3.2.0-beta3) over (3.1.1) ...
                  Preparing to unpack .../3-duetcontrolserver_3.2.0-beta3_armhf.deb ...
                  Unpacking duetcontrolserver (3.2.0-beta3) over (3.1.1) ...
                  Preparing to unpack .../4-duetruntime_3.2.0-beta3_armhf.deb ...
                  Unpacking duetruntime (3.2.0-beta3) over (3.1.1) ...
                  Preparing to unpack .../5-duetwebserver_3.2.0-beta3_armhf.deb ...
                  Unpacking duetwebserver (3.2.0-beta3) over (3.1.0) ...
                  Preparing to unpack .../6-duetwebcontrol_3.2.0-beta3_all.deb ...
                  Unpacking duetwebcontrol (3.2.0-beta3) over (3.1.1) ...
                  Preparing to unpack .../7-reprapfirmware_3.2.0-beta3-2_all.deb ...
                  Unpacking reprapfirmware (3.2.0-beta3-2) over (3.1.1-1) ...
                  Setting up duetruntime (3.2.0-beta3) ...
                  Setting up duetcontrolserver (3.2.0-beta3) ...
                  Installing new version of config file /opt/dsf/conf/config.json ...
                  Creating group dsf with gid 995.
                  Creating user dsf (n/a) with uid 995 and gid 995.
                  Setting up duettools (3.2.0-beta3) ...
                  Setting up duetwebserver (3.2.0-beta3) ...
                  Setting up duetsoftwareframework (3.2.0-beta3) ...
                  To modify config files consider adding yourself to the dsf groupd: # usermod -a -G dsf <username>
                  Setting up duetwebcontrol (3.2.0-beta3) ...
                  Setting up duetsd (1.1.0) ...
                  Setting up reprapfirmware (3.2.0-beta3-2) ...
                  So before I reboot and flash everything again, do you want me to try something or get some logs?
                    Once you update your Pi to 3.2-b3.2, you should be able to connect to RRF 3.1.1. But it's quite odd that you cannot connect to it any more when you update the firmware on the board via DSF. Can you attempt to flash the b3.2 binary manually via bossa and check if it boots then? Does the diag LED pulse once the new firmware binary is installed?
                    • Lucasundefined
                      Lucas @chrishamm
                      @chrishamm Hi, I flashed the Duet to version b3.2 via bossa, the dial LED was pulsing but the communication between the Duet and the Pi was still broken. So I flashed version 3.1.1 to the Duet and now the communication works again even if the Pi is still on version 3.2-b3.2.
                        @Lucas Can you please run sudo journalctl -u duetcontrolserver -e over SSH or from a local terminal when the latest firmware is installed and check what error is reported? It sounds really strange that it works with 3.1.1 but not with 3.2.0-b3.2.
                        • Lucasundefined
                          Lucas @chrishamm
                          @chrishamm Here is the result of "sudo journalctl -u duetcontrolserver -e" after I tried again to upgrade to 3.2b3.2:
                          -- Logs begin at Sat 2020-11-14 23:00:45 CET, end at Sat 2020-11-14 23:05:01 CET. --
                          Nov 14 23:00:49 duet3 systemd[1]: Started Duet Control Server.
                          Nov 14 23:00:52 duet3 DuetControlServer[388]: Duet Control Server v3.1.1
                          Nov 14 23:00:52 duet3 DuetControlServer[388]: Written by Christian Hammacher for Duet3D
                          Nov 14 23:00:52 duet3 DuetControlServer[388]: Licensed under the terms of the GNU Public License Version 3
                          Nov 14 23:00:53 duet3 DuetControlServer[388]: [info] Settings loaded
                          Nov 14 23:00:53 duet3 DuetControlServer[388]: [info] Environment initialized
                          Nov 14 23:00:53 duet3 DuetControlServer[388]: [info] Connection to Duet established
                          Nov 14 23:00:54 duet3 DuetControlServer[388]: [info] IPC socket created at /var/run/dsf/dcs.sock
                          Nov 14 23:01:32 duet3 DuetControlServer[388]: [info] System time has been changed
                          Nov 14 23:02:22 duet3 systemd[1]: Stopping Duet Control Server...
                          Nov 14 23:02:22 duet3 DuetControlServer[388]: [warn] Received SIGTERM, shutting down...
                          Nov 14 23:02:22 duet3 systemd[1]: duetcontrolserver.service: Main process exited, code=exited, status=143/n/a
                          Nov 14 23:02:22 duet3 systemd[1]: duetcontrolserver.service: Failed with result 'exit-code'.
                          Nov 14 23:02:22 duet3 systemd[1]: Stopped Duet Control Server.
                          Nov 14 23:02:42 duet3 systemd[1]: Started Duet Control Server.
                          Nov 14 23:02:42 duet3 DuetControlServer[1132]: Duet Control Server v3.2.0-beta3
                          Nov 14 23:02:42 duet3 DuetControlServer[1132]: Written by Christian Hammacher for Duet3D
                          Nov 14 23:02:42 duet3 DuetControlServer[1132]: Licensed under the terms of the GNU Public License Version 3
                          Nov 14 23:02:43 duet3 DuetControlServer[1132]: [info] Settings loaded
                          Nov 14 23:02:44 duet3 DuetControlServer[1132]: [info] Environment initialized
                          Nov 14 23:02:44 duet3 DuetControlServer[1132]: [warn] Downgrading protocol version 3 to 2
                          Nov 14 23:02:44 duet3 DuetControlServer[1132]: [warn] Incompatible firmware, please upgrade as soon as possible
                          Nov 14 23:02:44 duet3 DuetControlServer[1132]: [info] Connection to Duet established
                          Nov 14 23:02:44 duet3 DuetControlServer[1132]: [info] IPC socket created at /var/run/dsf/dcs.sock
                          Nov 14 23:02:45 duet3 DuetControlServer[1132]: [error] Failed to merge JSON: {"key":"spindles","flags":"d99vn","result":[{"active":0,"current":0,"frequency":0,"max":10000.0000000,"tool":-1},{"active":0,"current":0,"frequency":0,"max":100
                          Nov 14 23:02:45 duet3 DuetControlServer[1132]:    System.Text.Json.JsonException: Failed to deserialize property [Spindle].Max (type Int32) from JSON 10000.0000000
                          Nov 14 23:02:45 duet3 DuetControlServer[1132]:  ---> System.Text.Json.JsonException: The JSON value could not be converted to System.Int32. Path: $ | LineNumber: 0 | BytePositionInLine: 13.
                          Nov 14 23:02:45 duet3 DuetControlServer[1132]:  ---> System.FormatException: Either the JSON value is not in a supported format, or is out of bounds for an Int32.
                          Nov 14 23:02:45 duet3 DuetControlServer[1132]:    at System.Text.Json.Utf8JsonReader.GetInt32()
                          Nov 14 23:02:45 duet3 DuetControlServer[1132]:    at System.Text.Json.Serialization.Converters.JsonConverterInt32.Read(Utf8JsonReader& reader, Type typeToConvert, JsonSerializerOptions options)
                          Nov 14 23:02:45 duet3 DuetControlServer[1132]:    at System.Text.Json.JsonPropertyInfoNotNullable`4.OnRead(ReadStack& state, Utf8JsonReader& reader)
                          Nov 14 23:02:45 duet3 DuetControlServer[1132]:    at System.Text.Json.JsonPropertyInfo.Read(JsonTokenType tokenType, ReadStack& state, Utf8JsonReader& reader)
                          Nov 14 23:02:45 duet3 DuetControlServer[1132]:    at System.Text.Json.JsonSerializer.ReadCore(JsonSerializerOptions options, Utf8JsonReader& reader, ReadStack& readStack)
                          Nov 14 23:02:45 duet3 DuetControlServer[1132]:    --- End of inner exception stack trace ---
                          Nov 14 23:02:45 duet3 DuetControlServer[1132]:    at System.Text.Json.ThrowHelper.ReThrowWithPath(ReadStack& readStack, Utf8JsonReader& reader, Exception ex)
                          Nov 14 23:02:45 duet3 DuetControlServer[1132]:    at System.Text.Json.JsonSerializer.ReadCore(Type returnType, JsonSerializerOptions options, Utf8JsonReader& reader)
                          Nov 14 23:02:45 duet3 DuetControlServer[1132]:    at System.Text.Json.JsonSerializer.Deserialize(String json, Type returnType, JsonSerializerOptions options)
                          Nov 14 23:02:45 duet3 DuetControlServer[1132]:    at DuetAPI.ObjectModel.ModelObject.UpdateFromJson(JsonElement jsonElement, Boolean ignoreSbcProperties) in /home/christian/Duet3D/DuetSoftwareFramework/src/DuetAPI/ObjectModel/Base/ModelO
                          Nov 14 23:02:45 duet3 DuetControlServer[1132]:    at DuetAPI.ObjectModel.ModelCollectionHelper.UpdateFromJson(IList list, Type itemType, JsonElement jsonElement, Boolean ignoreSbcProperties) in /home/christian/Duet3D/DuetSoftwareFramewor
                          Nov 14 23:02:45 duet3 DuetControlServer[1132]:    at DuetAPI.ObjectModel.ObjectModel.InternalUpdateFromModel(String key, JsonElement jsonElement, Boolean ignoreSbcProperties) in /home/christian/Duet3D/DuetSoftwareFramework/src/DuetAPI/Ob
                          Nov 14 23:02:45 duet3 DuetControlServer[1132]:    at DuetAPI.ObjectModel.ObjectModel.UpdateFromFirmwareModel(String key, JsonElement jsonElement) in /home/christian/Duet3D/DuetSoftwareFramework/src/DuetAPI/ObjectModel/ObjectModel.cs:line
                          Nov 14 23:02:45 duet3 DuetControlServer[1132]:    at DuetControlServer.Model.Updater.Run() in /home/christian/Duet3D/DuetSoftwareFramework/src/DuetControlServer/Model/Updater.cs:line 212
                          Nov 14 23:02:50 duet3 DuetControlServer[1132]: [info] Flashing IAP binary
                          Nov 14 23:02:51 duet3 DuetControlServer[1132]: [info] Flashing RepRapFirmware
                          Nov 14 23:02:57 duet3 DuetControlServer[1132]: [info] Verifying checksum
                          Nov 14 23:02:59 duet3 DuetControlServer[1132]: [info] Firmware update successful
                          Nov 14 23:03:00 duet3 DuetControlServer[1132]: [warn] Lost connection to Duet (Timeout while waiting for transfer ready pin)
                          And for information it worked great with versions 3.2b1 and 3.2b2
                            Very strange. I suspect you have a microSD card in the Duet that prevents the SBC from connecting. If that is not the case, can you connect once again via YAT with 3.2.0-b3.2 installed and post the output of M122?
                            • Lucasundefined
                              Lucas
                              Yes I do have a SD card on the Duet, am I not supposed to?
                              • Lucasundefined
                                Lucas
                                I removed the SD card on the duet and rebooted and now the communication works even with version 3.2b3.2
                                Thank you @chrishamm for your help!
                                  jay_s_uk @Lucas
                                  @Lucas no. The SD card is the indicator for whether the duet is in standalone mode or not.
                                  SD card = standalone
                                  No SD card = SBC mode
                                  • Lucasundefined
                                    Lucas @jay_s_uk
                                    @jay_s_uk Okay thanks I didn't know. I had this SD card on the Duet since the beginning without any trouble and I forget about it.
                                    Anyway I removed it and it works great now 🙂
