    End Stop Problems
    22
    4.2k
    • brianundefined
      brian
      I've read it over and over, thx.
      • fcwiltundefined
        fcwilt
        Use an ohm/volt meter or the like to verify the end stop switches are doing what you think they are.
        Use the M119 command from the web interface to verify the state of your end stops.
        Configuring the end stops is one of the easier things to do since you can quickly verify they are correct with the M119 command.
        You just have to take it one step at a time - check you hardware first and then the config.
        • Rlcundefined
          Rlc
          I just replaced my Rumba this weekend… The endstops are not plug and play you have to change the wires. They use the two outer pins on the Duet Wifi. Also be aware that the Z endstop is not used. You have to connect the Z end stop to the E0 Endstop and set the probe type to 4. example "M558 P4 X0 Y0 Z1 F500 T5000 H3" for probing to work correctly.
          Im thinking about writing a guide from what I did but its all slowly fading. May write some stuff down after work.
          ~Roy
            You can use a Z endstop switch connected to the Z endstop connector if you wish, it all depends on whether you have your homing files configured to use a Z probe or an endstop switch for Z homing. See https://duet3d.com/wiki/Configuring_RepRapFirmware_for_a_Cartesian_printer#Homing_Z_using_a_Z_probe and https://duet3d.com/wiki/Configuring_RepRapFirmware_for_a_Cartesian_printer#Homing_Z_without_a_Z_probe.
            • brianundefined
              brian
              If i enter gcode in the console on the paneldue, the z axis stops when endstop is triggered, however if i put same code into the homez.g file the z axes just pushes past the endstop and wont stop powered down.
              • brianundefined
                brian
                @Rlc:
                ~Roy
                Ok thanks i will try changing to the E0 endstop. Yes i have changed the wiring pins as you say. Please do write a guide!
                • brianundefined
                  brian
                  These are the same endstops
                  https://www.bing.com/images/search?view=detailV2&ccid=i5mGSJ61&id=56250BAECF05955774D9E09E268DFBE23FCD6E2B&thid=OIP.i5mGSJ61KzNWaR7gAITkgwEsDn&q=endstops&simid=608009852723005880&selectedIndex=172&ajaxhist=0
                  • brianundefined
                    brian
                    Calvinx, thx for your advise. I had already changed the pins, basically flipping the connectors. If the pins are the same way as rumba then wifi will not connect. I rec'd some new endstops of the same kind and replaced the z one just in case it may have been defective but it doesnt make any difference.
                    I changed the S2 to S0 which then makes the x axis go the wrong way. It also didnt help the z, which still pushes past endstops and keeps going.
                    • brianundefined
                      brian
                      RLC, changed the position of z pin to E0 and the M558 setting in config.g file, and it makes no difference.
                      • brianundefined
                        brian
                        Big thanks to dc42 for taking time to look at my posts. I have gone thru those wiki files several times without success, will try again to see if i missed something or misinterpreted.
                          deckingman
                          @brian:
                          …...............I changed the S2 to S0 which then makes the x axis go the wrong way...............
                          Defining whether switches are active low or active high shouldn't make any difference to the way axes move. It's just the same as using a micro switch and telling the Duet whether it is wired to use the normally open contacts or the normally closed contacts. Did you set S0 in M574 or somewhere else? Also, the S parameter can only be 1 or 0. The Wiki is pretty good but it seems that you've got confused somewhere along the line.
                          Lets take one axis at a time and see if I can make clearer. So for just the X axis you'd have M574 Xnnn Snnn. The nnn after the X tells the machine where abouts on the axis the switch is fitted. The most common configuration is X = 0 as the left hand side and that's where the switch is fitted (low end in the Wiki). So in that case you'd have M574 X1….. You could fit the switch at the other end of the X axis (right hand side) but still have X=0 as being on the left. In which case you'd have M574 X2 (high end in the Wiki). In the case of a high end switch (on the right but X=0 is on the left) when you home the printer, it will move the head to the right until it "sees" the switch. At which point it will know that it is nnn (whatever your axis maximum is set to) mm away from X=0, so when you tell the machine to go to X=0 it will go left by nnn mm from the homing point. That's "high end" and "low end" covered. The only other value you could have after the "X" is 0 (zero) which means there is no switch at all for that axis.
                          Then the nnn after the "S" is either 0 or 1. As explained above, if you had a simple switch which was normally closed but became open when something touches it, it's called "active high" and you use S1. If the switch is normally open but becomes closed (makes a circuit) when something touches it, you use S0. Not all end stop switches are simple micro switches which is why the terms "Active High" and "Active Low" are used instead of "Normally Open" or "Normally Closed"
                          HTH
                          • brianundefined
                            brian
                            deckingman, nicely explained.
                            So i have my endstops set ; M574 X1 Y1 Z1 S1 and the x and y work properly, the z does not. When home z, nothing happens. All axis move properly using the paneldue move command or the web console move commands. Z moves but does not stop at the endstop.
                            With all axis homed or at 0, the z endstop light is on, x and y endstop lights are off. On the board only the z light is on. In the web console head position show at 0.0, In the head movement window show x and y axis homed, z axis not homed.
                            The M119 command shows x y z and z probe at min. stop. Note there is no z probe connected.
                            This is the the config.g file in part;
                            M111 S0 ; Debugging off
                            G21 ; Work in millimetres
                            G90 ; Send absolute coordinates…
                            M555 P2 ; Set firmware compatibility to look like Marlin
                            M208 X200 Y200 Z140 S0 ; Set axis maxima
                            M574 X1 Y1 Z1 S1 ; Define active high microswitches
                            M558 P4 X0 Y0 Z0 H3 F500 T5000 ; Set Z probe type to unmodulated, the axes for which it is used and the probe + travel speeds
                            G31 P500 X0 Y0 Z1.1 ; Set Z probe trigger value, offset and trigger height
                            M557 X25:175 Y25:175 S25 ; Define mesh grid
                            M350 X128 Y128 Z128 E32:32 I0 ; Configure microstepping without interpolation
                            M92 X640 Y640 Z3200 E1000:1000 ; Set steps per mm
                            M566 X900 Y900 Z12 E120:120 ; Set maximum instantaneous speed changes (mm/min)
                            M203 X12000 Y12000 Z1200 E12000:12000 ; Set maximum speeds (mm/min)
                            M201 X1000 Y1000 Z100 E200:200 ; Set accelerations (mm/s^2)
                            M906 X855 Y855 Z855 E1200:1200 I30 ; Set motor currents (mA) and motor idle factor in per cent
                            M84 S30 ; Set idle timeout
                              This is a very common issue and usually means that your homing files are set up to use a Z probe to do Z homing when you are expecting an endstop switch to be used. See https://duet3d.com/wiki/Configuring_RepRapFirmware_for_a_Cartesian_printer#Homing_Z_using_a_Z_probe and the following section on the same page.
                              • brianundefined
                                brian
                                dc42, yes copied and pasted that code, which didn't help at all.
                                however, I uploaded your latest firmware v 1.18.2 and now the z endstop works. thanks very much.
                                unable to connect to wifi tho.
