    Inconsistent results with optical encoder wheel filament sensor
    Filament Monitor
    9
    168
    11.4k
    • JohnOCFIIundefined
      JohnOCFII @alankilian
      @alankilian said in Inconsistent results with optical encoder wheel filament sensor:
      Your filament monitor travels inspired me to take the easy route and order the parts for a magnetic filament monitor from filastruder.
      I printed out the case parts, did a tiny bit of scraping with a hobby knife and it's all running perfectly!
      OK, now you are just rubbing it in. 😉
      I'm curious how that filament monitor would perform mounted further ahead of the extruder. They seem to suggest against it. On the other hand, for "filament out" basic switch sensing, the position I have (on the printer frame -- about ~350mm from the extruder) works fine. It is where I've got the optical sensor installed.
      https://imgur.com/a5zaYVI
      Who knows. At the end of all this I might throw in the towel and follow course, assuming the magnetic sensor would be OK on the printer frame.
      alankilianundefined 2 Replies Last reply Reply Quote 0
      • alankilianundefined
        alankilian @JohnOCFII
        @JohnOCFII
        HEY! I still have my old "Filament out" microswitch before the extruder so I can wire that directly to the magnetic movement monitor and have BOTH!
        Thanks for making me look at the documentation again!
        You folks are great.
        Filastruder installation instructions
        After the extruder:
        On systems that use a bowden tube it is also possible to mount the filament monitor after the extruder. In this case filament out will not be detected until the end of the filament is in the extruder. The second two pin header on the PCB is connected a separate filament sensing switch if you want to detect filament out before the extruder, but detect movement after the extruder.
          @JohnOCFII "assuming the magnetic sensor would be OK on the printer frame."
          I can't see where you have your filament monitor mounted right now.
          Assuming your bowden is all tight at both ends, I think it should be possible to mount the monitor back near your spool holder.
          JohnOCFIIundefined 1 Reply Last reply Reply Quote 0
            Yes, it is back by the spool holder: IMG_1983.jpeg
              @JohnOCFII That should work just fine if you decide to go this way.
              JohnOCFIIundefined 1 Reply Last reply Reply Quote 1
                If Tim @Filastruder has any extra bits, I might order one today with the current sale. The regular one is out of stock, but I understand that is just due to the case. My printers are precise enough that I'm sure I could get the case going.
                My Digi-Key order arrived, but work has been too busy this week to open it up or to think about wiring yet.
                  @JohnOCFII The three case parts printed easily at 0.1mm layer height with PLA and printing slowly on my Rostock Max V3.2 with a 0.5 nozzle.
                  The only thing is the pin and guide are slightly too short on the Idler part so the bearing can drop off the filament as it moves "up" in the case.
                  I just installed it bearing-side in and it's fine.
                  If you're able to modify the .step file provided on their github repository, I would go 1mm thicker for these two polygons.
                  I can't figure out how to modify a .step using FreeCAD, but it's supposed to be possible. Maybe I need to spend some YouTube time this afternoon.
                    I checked with FilaStruder, and apparently you got the last one.
                    • cdthomas9undefined
                      cdthomas9
                      Are these discontinued? I'd like to add this to my setup but it's never been back in stock, for months now.
                      alankilianundefined JohnOCFIIundefined 2 Replies Last reply Reply Quote 0
                        alankilian @cdthomas9
                        @cdthomas9 They are trying to figure out how to get the cases made.
                        I don't know what the issue was.
                          JohnOCFII @cdthomas9
                          @cdthomas9 said in Inconsistent results with optical encoder wheel filament sensor:
                          Yes, it is an issue with the cases. I think they switched technologies (SLS to injection molded?) and COVID has somewhat slowed the process, or lowered priority.
                            alankilian
                            @JohnOCFII I sent you a chat message with a contact at Duet3d who might be able to help you with a magnetic filament monitor parts kit.
                            Let me know if you didn't get the message and how to send it to you.
                              Weird -- I get emails for message updates, but not "chat" updates -- so I hadn't seen that message.
                                https://www.digikey.com/en/products/detail/texas-instruments/CD40106BE/376602
                                If you want help wiring it up, let me know.
                                I took the whole week off for Thanksgiving. Time to get back into this.
                                It looks like I connect pin 7 to ground, and pin 14 to 3.3V power.
                                It looks like most of the rest of the pins are paired. I'm not sure if it matters which pairs I use. Looks like I could connect from the optical sensor to Pin 1 (for input) and connect from Pin 2 (for output) to the Duet.
                                Would that be correct?
                                (This from the diagram on page 3) in the PDF below: https://www.ti.com/lit/ds/symlink/cd40106b.pdf?HQS=TI-null-null-digikeymode-df-pf-null-wwe&ts=1606236503315
                                  @JohnOCFII That's all correct.
                                  It doesn't matter which inverter you use. You just need to make sure to use the input of one inverter and the output of the same inverter of course. 🙂
                                  I don't remember what your optical receiver circuit looks like, so you might need either a pull-up or a pull-down on the input to the Schmitt trigger inverter pin #1.
                                  You can connect pin #2 directly to the Duet input pin.
                                    Here are two photos of the optical sensor. Not sure it is clear enough to indicate presence or absence of the pull-up or pull-down resistors.IMG_2055.jpeg
                                      @JohnOCFII
                                      R1 is a 180 Ohm resistor in series with the emitter LED.
                                      R2 is a 2,200 Ohm resistor to pull UP the receiver signal line.
                                      The resistor on the top is a 1,000 Ohm resistor in series with the LED on top. Is that a power-on LED?
                                      So I would just hook it directly to the input of the Schmitt-inverter. No pull-resistors required on the input or the output of the inverter.
                                        @JohnOCFII
                                        The LED is not a power-on LED -- it lights up when the light beam is broken. Interestingly, there is a corresponding e1stop LED on the Duet board as well.
                                        Thanks again on the advice. I'll try to wire this up tomorrow!
                                          @JohnOCFII AH! I tool another look at a larger zoom level and I do see that the LED is connected between positive voltage and the output signal.
                                            JohnOCFII
                                            @alankilian
                                            Progress!
                                            I manually moved the filament back and forth a few times, just to see if I was capture what I expected to capture. Other than the fact that the signal seems inverted -- it definitely looks like the Channel 1 signal is a cleaned up version of Channel 3.
                                            Spacing seems somewhat different too, but I can't imagine that matters in this case. I'll do a test print next.
                                            Here's the very tiny Saleae log file: https://1drv.ms/u/s!ApuOkxTDmZEzgoHeOopsvsFwqzJ2Eck?e=6bpojT
