Solved Rinning???
K ill send shortly
To start i wlswitched to pla for ease
SlicerTemp of 210
Bed at 63.c but i. Suspect it runs cooler then advertised
General slicers setings ...(mattercontrol slicer)
Layer thicknesses 0.2
First layer 0.35
Perimiters 3
Top solid 0.8
Bottom solid 0.8
Fil density 20%
Retractions 1mm
Max speed 100%
Retraction speed 35mms
Extrusion multiplier 1.0
Infill 60mms.
Inside perimiters 45mms (infill)Perimiters :
Outside perimiters 30mms
Perimiters acceleration 0%
Default acceleration 0% -
; generated by RepRapFirmware Configuration Tool on Thu Sep 06 2018 21:21:12 GMT-0700 (Pacific Daylight Time); General preferences
M83 ; ...but relative extruder moves; Network
M550 Pe3 ; Set machine name
M552 S1 ; Enable network
;*** Access point is configured manually via M587
M586 P0 S1 ; Enable HTTP
M586 P1 S0 ; Disable FTP
M569 P0 S0 ; Drive 0 goes forward
M569 P1 S0 ; Drive 1 goes backwards
M569 P3 S1
; Drive 3 goes backwards;M569 P3 S1 ; Drive 3 (Extruder 0) goes backwards
M350 X16 Y16 Z16 E16 ; Configure microstepping with interpolation
; M92 X79.7 Y320 Z400.4 E415 ; Set steps per mm
M92 X79.2 Y320 Z400.5 E427.8 ; Set steps per mmM566 X1600 Y500 Z24 E300 ; Set maximum instantaneous speed changes (mm/min)
M203 X30000 Y1600 Z300 E1500 ; Set maximum speeds (mm/min)
M201 X1500 Y1500 Z300 E5000 ; Set accelerations (mm/s^2) is 500
M906 x1700 Y1700 Z850 E1100 I30 ; Set motor currents (mA) and motor idle factor in per cent
M84 S300 ; Set idle timeout; Axis Limits
; M208 X-5.5 Y-10 Z0 S1 ; Set axis minima
; M208 X495 Y495 Z460 S0 ; Set axis maximaM208 X0 Y0 Z0 S1 ; Set axis minima
M208 X500 Y500 Z500 S0 ; Set axis maxima; Endstops
M574 X1 Y1 Z1 S1 ; Set endstops controlled by sw. Z control by nozzle triger sw.
; M558 P5 H5 F100 T2000 ; Set Z probe type to capasitive and the dive height + speeds
M558 P5 H5 F100 T4000 ; Set Z probe type to capasitive and the dive height + speeds
G31 P500 X-42 Y-5 Z-0.87 ; Set Z probe trigger value, offset and trigger height - is Nozzle hogerM557 X15:215 Y35:215 S20 ; Define mesh grid
M305 P0 T100000 B4138 R4700 ; Set thermistor + ADC parameters for heater 0
M143 H0 S120 ; Set temperature limit for heater 0 to 80C
M305 P1 x501 R4700 ; Set thermistor + ADC parameters for heater 1
M143 H1 S400 ; Set temperature limit for heater 1 to 400C; M307 H1 A245.3, C121.7, D4.0, S0.5 ; PID
; M106 P0 S1 I0 F500 H T45 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned on
; M106 P1 S0 I0 F500 H-1 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned offM106 P0 S0 I0 F500 H-1 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
M106 P1 S1 I0 F500 H1 T45 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on; Tools
M563 P0 D0 H1 ; Define tool 0
M501 ;pid save to config overide
; Enable Bed Leveling -
@ziggymanpopo said in Rinning???:
M201 X1500 Y1500 Z300 E5000 ; Set accelerations (mm/s^2) is 500I think it may be a combination of the large mismatch in X Y speeds and jerk.
Try
M566 X600 Y600 Z60 E3000 ; Set maximum instantaneous speed changes (mm/min) M203 X12000 Y12000 Z600 E6000 ; Set maximum speeds (mm/min) M201 X600 Y600 Z300 E5000 ; Set accelerations (mm/s^2) is 500 M204 P600 T2000 ; set print and travel move accel
before i make those changes i thought id ask you this i installed a ball screw on the y axes its a 16/10 pitch...dose that impact it at al las far as the spread or figures
my bad for not sayin
The settings I posted should be ok for ball screw axis as well. The rotational inertia of the ball screws may be contributing to the ringing. Either way, the settings I posted may help.
Thank you will reprint the benchy the the rinning stl
The x makes me think that ive got a belt issue
I can say its prety tight and the idler bearing is smooth because thats what i could find and thought the smooth one proably would resonate less ????? -
So much better
It's better now?
Yes much thank you i think i still need to play with the hotend cooling duct. Thank you what do you think about the lines. The x axes belt ?????
80% maybe 90% !!
I would say that it's still likely mechanical in nature. Ball screw has a lot of rotational mass, so trying to get it up to speed and slow down quickly is going to be tricky.
Try
M566 X600 Y400 Z60 E3000 ; Set maximum instantaneous speed changes (mm/min) M203 X12000 Y12000 Z600 E6000 ; Set maximum speeds (mm/min) M201 X600 Y400 Z300 E5000 ; Set accelerations (mm/s^2) is 500 M204 P500 T2000 ; set print and travel move accel
And if the travel moves seem harsh, try reducing M204 T2000 to T1500
One at a time ??
All at once?
Done rerunning cube
Again 50% better again
the tip of the benchy is curling up slightly. Defiferent . Prob... Fan or heat both just askin can play with that later??
I was wondering if you had a fan speed stl. With the changes allready in it.
I could also use one for temp ..i know there are ones on thingavers but dont trust myself to make slicer
Changes on the fly tupe thing beleive that might come in the future ðĪŠ -
The benchy hull curling is a real challenge for cooling. The model is also very small, so it benefits from printing at lower temps. A good fan duct will help a lot.
Sliced gcode files aren't very portable between printers, so be wary of running someone else's gcode. Always best to slice yourself.
For things like variable change test towers you can manually change the parameter while watching the print if you're not comfortable with editing the gcode.
Cura and PrusaSlicer both have options to add a gcode command the layer height that makes it easy.
https://help.prusa3d.com/en/article/insert-pause-or-custom-g-code-at-layer_120490
https://www.youtube.com/watch?v=Wkegh9WRaxs&ab_channel=TechnoGeek3D
