[3.2-beta-3.2] Strange pauses during print
My config: config.g
M350 X16 Y16 Z16 E16:16 I1 ; configure microstepping with interpolation M92 X200.00 Y200.00 Z400.00 E830.00:830.00 ; set steps per mm
I had expected to see a high microstepping value, but that doesn't seem to be the case, unless it's being changed elsewhere? Perhaps in
M98 P"dynamics_normal.g"
? I assume your other speed settings are in there?How fast are you printing in that video? Curious to work out the step rate.
@Phaedrux in dynamics_normal.g I have setting for speed/acceleration:
M913 X100 Y100 Z100 E100 ; set XY motors current to 100% M566 X1200.00 Y1200.00 Z12.00 ; set maximum instantaneous speed changes (mm/min) M203 X18000.00 Y18000.00 Z1800.00 ; set maximum speeds (mm/min) M201 X3500.00 Y3500.00 Z120.00 ; set accelerations (mm/s^2) M593 F36.5
Actual speed is limited there by acceleration below 100mm/s-ish. But I printed much faster that this one without any problems
Also I did not have this pauses with the same config on RRF 3.1.1
And... printed part does not look particularly bad as I would expect in case of some steps skipping etc.
Reason I ask about print speed is because if we have the requested max speed we could work out the step rate based on your steps per mm.
@Phaedrux Max speed I use, is 300mm/s for idle moves, and I have never had any problems with this. 200steps/mm @ 300mm/s (as configured), should result with around 60k steps/s. Nothing very fast. Not sure what this counter actually counts as hiccups.
@BoA said in [3.2-beta-3.2] Strange pauses during print:
Usually when it can't sustain the step rate. It inserts a brief pause to allow catch up. 32000 isn't extreme, but it would be noticeable as you saw.
Can you give this a try?
https://forum.duet3d.com/topic/16291/reprapfirmware-3-2-planned-improvements/57?_=1605641146748
Work out a long move that you can use on your machine to test the step rate. It needs to be long enough that most of the move will be at the requested speed, not doing acceleration or deceleration
Select x256 microstepping
Send M122 to clear the hiccup count
Execute that move
Send M122 to read the hiccup count
Repeat the last 3 steps at different speeds, to find the speed at which the hiccup count increases dramatically. For a 300mm move at x256 microstepping, I reckon that 50 to 100 hiccups is acceptable, more is not.
Use the steps/mm and the speed you measured to work out the step pulse rate.Would be interesting to see the results in 3.2 compared to 3.1.1
@Phaedrux I changed speed limits to 24000mm/min in config and created a simple gcode for a test:
G90 ; use absolute coordinates M83 ; extruder relative mode T0 G28 ; home all without mesh bed level G32 ; gantry leveling M404 N1.75 D0.4 T0 G92 E0.0 G1 X0.0 Y100.0 Z20.0 F12000.0 G1 F24000.0 G1 X0.0 G1 X250.0 G1 X0.0 G1 X250.0 G1 X0.0 G1 X250.0 G1 X0.0 G1 X250.0 G1 X0.0 G1 X250.0 G1 X0.0 T-1
after executing it few times M122 gives hiccups counter 0
Did you see the test procedure in my last post for inducing hiccups?
@Phaedrux OK, so with 256 microstepping, 3200steps/mm I reached 65mm/s with 0 hiccups. Which is 208k steps/s
With 66.6mm/s I had 2 hiccups (at over 210k steps/s).
Far higher than required during printing.
With a single axis active anyway. Will be interesting to see what @DC42 thinks.
@Phaedrux Same results with XY active - moving head diagonally 0,0 to 200,200 and back to 0,0
at 4000mm/min 0 hiccups
And for completness: gcode file I am printing: gravitrax_dual_0.2mm_PETG_MK3S_52m.gcode
Can you try increasing your Z jerk to 60 and reprinting the gcode that was pausing before?
There is an interaction between mesh compensation and low z jerk that can cause pauses in XY movement to allow the slower z axis time to adjust since it's part of the coordinated move. this can be exacerbated by high print speeds.
https://duet3d.dozuki.com/Wiki/Using_mesh_bed_compensation#Section_Troubleshooting
@Phaedrux Just started. But... I do not think this is it. Bed compensation works on all prints same way, as it compensates for the same bed. Also I just printed a square element 140x140mm at 180mm/s + 300mm/s idle without any issues.
Neverthless I just changes Z jerk to 60 and started print that causes pauses... Will let You know in an hour
@Phaedrux As expected, that did not help. A executed M122 during print, and just after the single pause hiccups counter went from 0 to over 16000.
https://drive.google.com/file/d/19Zhcq5f3gCc43F2qHmSnbkO4UZDmZIAL/view?usp=sharing
Pause at 0:52
And more pauses following, but not recorded.
Before this pause, 0 hiccups:=== Platform === Last reset 03:09:09 ago, cause: software Last software reset at 2020-11-18 17:42, reason: User, GCodes spinning, available RAM 99700, slot 0 Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0044a000 BFAR 0x00000000 SP 0xffffffff Task MAIN Error status: 0x04 MCU temperature: min 38.2, current 38.3, max 38.5 Supply voltage: min 24.6, current 24.7, max 24.9, under voltage events: 0, over voltage events: 0, power good: yes 12V rail voltage: min 12.1, current 12.2, max 12.3, under voltage events: 0 Driver 0: position 16847, ok, reads 21772, writes 0 timeouts 0, SG min/max 0/1023 Driver 1: position 17242, ok, reads 21771, writes 0 timeouts 0, SG min/max 0/423 Driver 2: position 2596, ok, reads 21771, writes 0 timeouts 0, SG min/max 0/225 Driver 3: position 0, ok, reads 21771, writes 0 timeouts 0, SG min/max 0/386 Driver 4: position 0, ok, reads 21772, writes 0 timeouts 0, SG min/max 0/320 Driver 5: position 0, standstill, reads 21772, writes 0 timeouts 0, SG min/max not available Date/time: 2020-11-18 20:51:44 Slowest loop: 8.57ms; fastest: 0.14ms
After over 16000 hiccups counted and:
=== Platform === Last reset 00:28:52 ago, cause: software Last software reset at 2020-11-17 17:49, reason: User, GCodes spinning, available RAM 99492, slot 0 Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0044a000 BFAR 0x00000000 SP 0xffffffff Task MAIN Error status: 0x00 MCU temperature: min 38.8, current 39.0, max 39.3 Supply voltage: min 24.6, current 24.8, max 24.9, under voltage events: 0, over voltage events: 0, power good: yes 12V rail voltage: min 12.1, current 12.2, max 12.3, under voltage events: 0 Driver 0: position 27870, standstill, reads 21523, writes 0 timeouts 0, SG min/max 0/1023 Driver 1: position 19411, ok, reads 21523, writes 0 timeouts 0, SG min/max 0/951 Driver 2: position 2030, ok, reads 21523, writes 0 timeouts 0, SG min/max 0/1023 Driver 3: position 0, standstill, reads 21523, writes 0 timeouts 0, SG min/max 0/125 Driver 4: position 0, standstill, reads 21523, writes 0 timeouts 0, SG min/max 0/119 Driver 5: position 0, standstill, reads 21524, writes 0 timeouts 0, SG min/max not available Date/time: 2020-11-17 18:17:57 Slowest loop: 329.89ms; fastest: 0.15ms
Take a look on Slowest loop time. Seems to be much higher after this strange pause.
Thanks for testing. Definitely an exaggerated pause there.
Each time you run M122 it clears the hiccup counter.
@Phaedrux I am aware of that. Just in the middle of print, each m122 reported 0 hiccups, and just after pause over 16000, after another pause (longer one) almost 50000. And other thing is this platform slowest loop significantly higher than normally.
This post is deleted! -
@Phaedrux I just tested this particular print with 3.2beta4, and there ar even more pauses and for longer time, than with 3.2beta3.2
After each pause I gou a hiccups counter from 0 to around 30000. Between pauses hiccups counter is 0 all the time.
As I can not see anything from @dc42 I am guessing he just missed that.
