    Weird Laser Mode
    Laser Cutters
    3.4k
    • pauleddundefined
      pauledd @pauledd
      @pauledd said in Weird Laser Mode:
      Still I dont know how to focus my laser while it is moving could be
      a little bit tricky
      I found a way to do it without moving it, assigning laser pin to a free fan pin and control it via M106 command:
      ### DOES NOT WORK ###
      ; disable Laser Mode
      M451
      ; assign laser pin to a free fan Number
      M950 F2 C"!exp.heater3" Q1000
      ; enable laser with 1/255th power
      M106 P2 S1
      ; do the focusing stuff
      ; disable laser
      M106 P2 S0
      ; free heater3 again for use in laser mode
      M950 F2 C"nil"
      Just found out something is wrong again, after setting "M106 P2 S1" the heater3 pwm goes to 0,491V but it should read 0,02V...
      Also the voltage does not change from pwm 1 to 25.
      At 26 I then read 0,5V, at 27 0,52V and so on up to 254.
      I dont get it, I'll give up for now, using my function generator... 😂
      ----- human being without Windows™ ------
      Phaedruxundefined 3 Replies Last reply Reply Quote 0
        Phaedrux Moderator @pauledd
        M541
        Do you mean M451?
        pauleddundefined 1 Reply Last reply Reply Quote 0
        • pauleddundefined
          pauledd @Phaedrux
          @Phaedrux said in Weird Laser Mode:
          Do you mean M451?
          Yes 😊
            Does that make a difference to your attempt?
            • pauleddundefined
              pauledd
              No, the command was just there IN CASE I still have the laser mode enabled.
              If laser mode was not enabled the wrong command would have no effect anyway...
                I wonder if this is because S1 is the same as S255?
                S1 or S0 for on and off, or S0.1 to S1 in decimal values to act as a percentage, or 2-255 as an 8bit value.
                I wonder if it would behave differently if it was configured as a servo i/o pin and controlled with M42 instead.
                https://duet3d.dozuki.com/Wiki/Gcode?revisionid=HEAD#Section_M42_Switch_I_O_pin
                pauleddundefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
                • pauleddundefined
                  pauledd @Phaedrux
                  That is definitely worth a try, I'll test that tomorrow, thanks.
                    exp.heater3
                    I'm not sure if it would matter either but there are other expansion heater pins to try. I don't know if all are created equal.
                    • pauleddundefined
                      pauledd
                      I tried exp.heater3 as servo pin and I detached my laser inverter logic just to be sure this is not another error source...
                      from a fresh booted Duet...
                      ; initial voltage 3.276V on exp.heater3
                      M950 P0 C"exp.heater3" Q1000 ; voltage now at 0.0005V
                      M42 P0 S1 ; 3.310V  ??? WTF
                      M42 P0 S2 ; 0.0274V check!
                      M42 P0 S3 ; 0.0402V check!
                      M42 P0 S4 ; 0.0529V check!
                      M42 P0 S5 ; 0.0658V check!
                      M42 P0 S128 ; 1.656V check!
                      M42 P0 S253 ; 3.274V check!
                      M42 P0 S254 ; 3.287V check!
                      M42 P0 S255 ; 3.302V check!
                      So, except M42 P0 S1, which is exactly what I want... everything else seems to work.
                      The same strange behavior happens if I reverse the logic:
                      M950 P0 C"!exp.heater3" Q1000 ; voltage now at 3.302V
                      M42 P0 S1 ; 0.0005V  ??? WTF
                      M42 P0 S2 ; 3.274V check!
                      M42 P0 S3 ; 3.262V check!
                      M42 P0 S4 ; 3.248V  check!
                      M42 P0 S5 ; 3.240V check!
                      M42 P0 S128 ; 1.646V check!
                      M42 P0 S253 ; 0.0267V check!
                      M42 P0 S254 ; 0.0138V check!
                      M42 P0 S255 ; 0.0005V check!
                      • pauleddundefined
                        pauledd @Phaedrux
                        The problem is, my laser pcb pinout has been designed according to
                        which involves exp.heater3
                          Phaedrux Moderator @Phaedrux
                          S1 or S0 for on and off, or S0.1 to S1.0 in decimal values to act as a percentage
                          It's exactly as I said. S1 is full on. As you see from your voltage?
                          • pauleddundefined
                            pauledd
                            Thanks, I again missed that, so I will mark S1 & S0 as NOT PWM in my brain. 😬
                            I was irritated because I worked with the M3 S1 command over a year and that did not set the laser to FULL power, insead it used 1/255th PWM...
                            So then PWM value 2 is the lowest possible setting for my laser... I think I can live with that.
                            Phaedruxundefined dc42undefined 2 Replies Last reply Reply Quote 1
                              Possibly. I'm not sure how many decimal places you could get. Try 0.01.
                              • g0rgundefined
                                g0rg
                                my laser mode worked correctly just once until i moved it to the enclosure 😣
                                I dont understand where or what could i missed.
                                Now the laser is always ON with 3.6 volt on heater3 pin
                                btw, i use the same added small board and my version is rrf3 on duet2 wifi.
                                here is my config.g
                                ; Configuration file for Duet
                                ; WorkBee Firmware Version 1.0.7
                                ; Configure Connection - ENABLE ONLY ONE OF THE BELOW THREE
                                ;M552 S1 ; Enable Wifi Network
                                ;M552 S2 ; Enable Access Point Mode
                                ;M552 S1 P192.168.2.14 ; Enable Ethernet - Change IP Address to suit
                                M552 S1 ;
                                ; DO NOT CHANGE ANY OF SETTINGS BELOW
                                ; TO MAKE A CHANGE, COPY THE LINE OF CODE, PASTE IT INTO customconfig.g. THE CHANGE CAN THEN BE MADE IN customconfig.g
                                ; ANY ADDITIONAL SETTINGS SHOULD BE PUT IN customconfig.g
                                ;M453 				; Put the machine into CNC Modes
                                M452 C"!exp.heater3" R255 F9000	S1	; enable LASER mode
                                M575 P1 S1 B57600 ; PanelDue for RRF3
                                M550 PWorkBee CNC Machine 	; Set machine name
                                G90 				; Set absolute coordinates
                                M586 P0 S1 			; Enable HTTP
                                M586 P1 S0 			; Disable FTP
                                M586 P2 S0 			; Disable Telnet
                                ; Configure Drives
                                M569 P0 S0 			; Drive 0 goes forwards
                                M569 P1 S0 			; Drive 1 goes forwards
                                M569 P2 S0 			; Drive 2 goes forwards
                                M569 P3 S0 			; Drive 3 goes forwards
                                M584 X0 Y1:3 Z4 U3 P3 		; Apply drive mapping to axes
                                ; Configure Axes
                                M92 X400 Y400 Z400 U400 	; Set steps per mm
                                M350 X16 Y16 Z16 U16 I1 	; Configure microstepping
                                M566 X100 Y1000 Z1000 U1000 	; Set maximum instantaneous speed changes (mm/min)
                                M203 X4000 Y4000 Z2000 U4000	; Set maximum speeds (mm/min)
                                M201 X120 Y120 Z150 U120	; Set accelerations (mm/s^2)
                                M906 X2100 Y2100 Z2100 U2100 I50 ; Set motor currents (mA)
                                ; Configure Axis Limits
                                M208 X0 Y0 Z0 S1		; Set axis minima
                                M208 X1300 Y1270 Z85 U1270 S0 	; Set axis maxima
                                ; Configure Endstops
                                M574 X2 S1 P"xstop"   ; X min active high endstop switch
                                M574 Y1 S1 P"ystop"   ; Y min active high endstop switch
                                M574 Z2 S1 P"zstop"   ; Z min active high endstop switch
                                M574 U1 S1 P"e0stop"  ; U max active high endstop switch
                                ; Other Settings
                                M140 H-1 			; Disable heated bed
                                M564 S1 H0 			; Disable jog commands when not homed
                                M911 S21.0 R23 P"G91 G1 Z3 F1000" ; Configure power loss resume
                                M501 				; Load Stored Parameters
                                M98 Pcustomconfig.g 		; Execute custom config settings
                                any idea ?
                                Duet 2 wifi , Ooznest Worbee CNC 1510 , Neje Laser 20w. Ruida 100w Co2 Laser 6090. Some homemade laser cnc grbl 1515.
                                • pauleddundefined
                                  pauledd @g0rg
                                  @g0rg Can you double check that you attached the small board to the correct pins?
                                  I had the same case were the laser was always on until I noticed that the pin-socket that goes into duets expansion header was attached with a offset by one pin...
                                  g0rgundefined 1 Reply Last reply Reply Quote 1
                                  • g0rgundefined
                                    g0rg @pauledd
                                    @pauledd From my understanding:
                                    if i remove the small board, is it normal to measure 3.7v between gnd and pin8 ?
                                    That's actually what i have , with or without the board pinned in place.Screenshot_7.jpg
                                    pauleddundefined dc42undefined 2 Replies Last reply Reply Quote 0
                                      dc42 administrators @pauledd
                                      If you are using 255 as the maximum then the lowest is about 1.001. If you use 1.0 as the maximum then you can go as low as you like, within the limits of the resolution of the PWM generator.
                                      • pauleddundefined
                                        pauledd @g0rg
                                        @g0rg said in Weird Laser Mode:
                                        Well, I would expect 3.3V, I dont know why you read 3.7V ?
                                        Yes on the bare pin I would expect High level right after boot, and the attached board should invert the logic to 0V until you issue your laser commands.
                                        Thats the problem I had:
                                          dc42 administrators @g0rg
                                          It should be 3.3V.
                                          • g0rgundefined
                                            g0rg @pauledd
                                            @pauledd You got it ! Same idiot issue. I put the board on the right pins and it works now.
                                            Sometimes more than 2 eyes and a good reactive forum helps.
                                            Thank you very much guys !
