    First Layer and Extrusion Problems
    5.6k
      A Former User @fcwilt
      @fcwilt
      who said you are not probing the centre of the bed?
      • fcwiltundefined
        fcwilt @A Former User
        @CaLviNx said in First Layer and Extrusion Problems:
        @fcwilt
        Your example stated that you were positioning the nozzle at the center of the bed, not the probe.
          @fcwilt
          With the nozzle you usually have a probe yes? So you place the nozzle/probe at the "centre" ready to probe
          I incorrectly assumed that you would manage make that mental connection between nozzle and or probe on your own, apologies for my incorrect assumption
          • fcwiltundefined
            With most probes it will not be possible to place both the nozzle and the probe at the center of the bed at the same time.
            Your example stated you were positioning the nozzle at the center of the bed.
            At the position, with most probes, you are not going to be probing the center of the bed.
              @fcwilt
              My probe offset is Y0, X-7 on a 500x500mm bed that as near as dammit the centre, centre enough that I wouldn't be pedantic enough to worry about it, and anyway it was just a "generic" term "nozzle" my home.x, home.y & bed.g are suitably adjusted to pedantically place the probe to the bed centre.... with most probes you ARE going to be probing the centre, it is just that the NOZZLE wont be in the centre.
              And the key word is "most" precision piezo springs to mind......
              • fcwiltundefined
                You posted an example that stated "nozzle". I therefore assumed you meant "nozzle".
                I cannot read your mind and can only go by what you posted.
                When trying to help a beginner learn how to do things I think it best to be clear in what you are telling them to do.
                Telling them to center the nozzle when you mean probe is not my idea of being clear.
                Frederikundefined A Former User? 2 Replies Last reply Reply Quote 0
                • Frederikundefined
                  Frederik
                  so, i tried this bed.g:
                  G30 P0 X330 Y250 Z-99999     ; Probe near the front left lead-screw
                  G30 P1 X165 Y0 Z-99999       ; Probe near the rear lead screw
                  G30 P2 X0 Y250 Z-99999 S3    ; Probe near the front right lead-screw
                  G30 P0 X330 Y250 Z-99999     ; Probe near the front left lead-screw (Second Pass)
                  G30 P1 X165 Y0 Z-99999       ; Probe near the rear lead screw (Second Pass)
                  G30 P2 X0 Y250 Z-99999 S3    ; Probe near the front right lead-screw (Second Pass)
                  G91                          ; Switch to relative positioning moves
                  G1 H2 Z5 F8000               ; Drop the Z axis (the bed) by 5mm relative to its current position
                  G90                          ; Revert back to absolute positioning moves
                  G1 X160 Y155 F8000           ; Position the nozzle at the centre of the bed
                  G30                          ; Probe and set the height as probed
                  G29 S1 P"heightmap.csv"      ; Load the height map
                  • Vetiundefined
                    Veti
                    again its not a good idea to do more than it is intended in the bed.g and other config files.
                    just create a macro that does
                    G32
                    G32
                    G28 Z
                    Frederikundefined 1 Reply Last reply Reply Quote 0
                    • Frederikundefined
                      Frederik
                      To my setup:
                      At the moment I use the Bltouch, but I could change the sensor to a capacitive on for testing purposes.
                      • Frederikundefined
                        Frederik @fcwilt
                        @fcwilt you are right, I meant probe. It's all a bit confusing in the beginning 🙂
                        • Frederikundefined
                          Frederik @Veti
                          @Veti what do you mean with the macros. Do you have for every command an extra makro?
                            @fcwilt said in First Layer and Extrusion Problems:
                            and still you are pedantically grasping at straws......
                            if we got it work and being within 10mm of the bed centre, i would call that a result...... and besides the point there is still NO NEED to add a macro to send the "probe/nozzle" to the centre of the bed when you can 100% do it from the home files.
                            telling a beginner to add unnecessary files in not that helpful..
                              A Former User
                              An operational homeall.g to place the head/probe/nozzle (whatever you pedantically wish to call it) in the centre of the bed with NO NEED for a macro
                              ; homeall.g
                              ; called to home all axes
                              G1 H2 Z5 F6000          ; Drop the Z axis (the bed) by 5mm relative to it's current position
                              G1 H1 X-350 F6000       ; Fast travel the X axis close to it's endstop & stop
                              G1 H2 Z-5 F6000         ; Raise the Z axis (the bed) by 5mm relative to it's current position
                              G1 H0 X175 F6000        ; Fast Travel the X axis to the centre of the bed
                              G1 H1 Y-350 F6000       ; Fast travel the Y axis close to it's endstop & stop
                              G1 H0 Y170 F6000        ; Fast Travel the Y axis to the centre of the bed
                              G30                     ; Raise the Z axis (the bed) and stop when probe is triggered and set Z to the trigger height
                              • fcwiltundefined
                                Not completely true.
                                There are other times when you need to set the Z=0 datum such as when creating a height map or loading it.
                                It is important to use the same probe point. The macro I use insures that the same point is used in every case. There is no chance for a typo or my faulty memory to cause a problem.
                                • fcwiltundefined
                                  fcwilt @Frederik
                                  @Frederik said in First Layer and Extrusion Problems:
                                  I understand which is why I strive to be as clear as I can and not say things that are potentially confusing or abiguous - and yet it still happens.
                                    @fcwilt
                                    Sorry but if you are using x3 leadsrews it would naturally be good practice to be initiating the bed.g file after homing and then applying the correction and after that correction has been applied you would have the head/probe/nozzle RE-Probe in the centre to re-establish the datum before printing commences.
                                      A Former User
                                      For example everything gets done at once
                                      ; bed.g
                                      G28                         ; Home all
                                      G30 P0 X2 Y-2 Z-99999       ; Probe near the front left lead-screw
                                      G30 P1 X152 Y278 Z-99999    ; Probe near the rear lead screw
                                      G30 P2 X290 Y-2 Z-99999 S3  ; Probe near the front right lead-screw
                                      G30 P0 X2 Y-2 Z-99999       ; Probe near the front left lead-screw (Second Pass)
                                      G30 P1 X152 Y278 Z-99999    ; Probe near the rear lead screw (Second Pass)
                                      G30 P2 X290 Y-2 Z-99999 S3  ; Probe near the front right lead-screw (Second Pass)
                                      • fcwiltundefined
                                        Yes if you do everything in bed.g you are having the probe point only specified in that one location.
                                        But not everyone does it that way. I certainly don't.
                                        My bed.g file only auto-levels the bed and sets the Z=0 datum.
                                        But there are other times when setting the Z=0 datum is important.
                                        For example I have more than one height map that is loaded depending on the state of a fan name that I am current using in lieu of variables.
                                        The macro that loads the height map uses a few others macros. One configures the probe, one positions the probe to bed center, one does the probing.
                                        To position the probe to bed center I don't have to remember the correct XY values I simply call the macro and it does the math and positions the probe.
                                          @fcwilt
                                          so does that one above......................
                                          • fcwiltundefined
                                            @fcwilt
                                            But if you have to set the Z=0 datum somewhere else you have to remember to use those same values.
