    Losing connection with board
    3.9k
    • Cinproundefined
      Cinpro
      I just connected and it forgot that I set it to the dark version of the screen layout. grr
      is the version I just listed not stable, if not which one should I look for?
      Error reason: timeout
      • Cinproundefined
        Cinpro
        @fcwilt:
        I had a similar problem when the signal strength at the printer was low. I setup my nearest AP with a unique SSID and changed the printer setting to use that SSID to be sure the printer was connecting to the that specific AP. Then the signal strength was much better and the problems went away.
        M552? I have that set to what my router gave it as an ID
        • cbusilloundefined
          cbusillo
          No wifi here. I will be changing out the switch next week. I’ll pay attention and see if the disconnects go away. Everything is dhcp and I haven’t had duplicate up issues before.
          • Cinproundefined
            Cinpro
            the router has the Duet listed as a Static address vs DHCP, just looked, its is also the only device that has 3 digits for the last sequence of numbers.
              @Cinpro:
              Firmware Name: RepRapFirmware for Duet Ethernet
              Firmware Electronics: Duet Ethernet 1.0
              Firmware Version: 1.18.1 (2017-04-09)
              Web Interface Version: 1.15a
              Web Interface by Christian Hammacher
              Licensed under the terms of the GPL v3
              Dark theme kindly provided by Fotomas
              Nothing else is close to the number that the router assigned it.
              Can you confirm that you only have one Duet on the network? I had problems connecting to a Duet Ethernet yesterday, until I realised that I had a Duet 0.6 on the same network and they were both using the default MAC address.
              • Cinproundefined
                Cinpro
                I only have one board, and only one is listed on the router info screen. it has My computer, my laptop when its on, my phone and the Duet board. short list so its easy to spot.
                Another oddity showed up this morning, the small print I was doing, a replacement part was nearly finished. I could see the part was on the last few layers. yet the DWC told me I was only 56.6% done. It has been spot on before. Down right scary in how close it has been till this. I will be keeping an eye on it.
                  @Cinpro:
                  That usually means that you have a G1 Z command in your end gcode to raise the print head when the print is complete, and that command is confusing the object height detection. The remedy is to add a comment starting with ;E to that line.
                  • JohnOCFIIundefined
                    JohnOCFII
                    @Cinpro:
                    I keep losing connection with the board. I just get the standard AJAX message and no explanation.
                    Are you connecting using a DNS name, or directly via IP address? I was having similar issues when connecting via a DNS host name, and someone else here suggested I try via IP address, as the mDNS responder might be having issues. I've switched to connecting via IP address only, and have not had an unexplained disconnection since that time.
                    John
                    • Cinproundefined
                      Cinpro
                      @dc42:
                      @Cinpro:
                      I have a G1 E-15 F9000 as the first line in my closing script, I'll add the suggested comment in
                      • Cinproundefined
                        Cinpro
                        @JohnOCFII:
                        @Cinpro:
                        John
                        Using the IP address here
                          @Cinpro:
                          @dc42:
                          @Cinpro:
                          That shouldn't cause any problems, it's when you have a G1 Z line in your closing script that the object height is likely to be read incorrectly, because the firmware looks for the last G1 Z line in the file and assumes that indicates the start of the last layer.
                          • Cinproundefined
                            Cinpro
                            @dc42:
                            @Cinpro:
                            @dc42:
                            @Cinpro:
                            So then might it not be a good idea to but code in the starting script to tell it where it is? Maybe a G30, or do G30 and input that value somehow? Is there something else in my code throwing it off. I used the ones I had for an i3 as a basis. This is my first Delta machine so things might not translate the way I think they do.
                            open script
                            G28 ; home all axes
                            M280 P3 S10 I1 ; DROP PIN
                            M98 Pbed.g
                            close script
                            G1 E-13.0 F9000 ;E
                            G90
                            G0 Z400 F1800
                            M104 S0 ; turn off extruder
                            M140 S0 ; turn off bed
                            M106 S0
                            M84 ; disable motors
                              The line that is confusing the firmware is this one:
                              G0 Z400 F1800
                              If you append ";E" or "; E" (without the quotes) to that line, that should avoid the problem.
