    Newbie: New Install on Ender 5 Plus---Willing to PAY$$$
    7.2k
    • shattyundefined
      shatty @Veti
      @Veti Thats because I hit stop
      Not the motors are moving away from endstops with hitting the positive values. Z still fighting each other. They are in series config because there are 2 on 1 driver
      • shattyundefined
        shatty
        Paneldue5i is connected with ribbon cable only. How can it be wrong?
        • Vetiundefined
          Veti @shatty
          @shatty said in Newbie: New Install on Ender 5 Plus---Willing to PAY$$:
          that mean you have to reverse the wiring of one of your stepper motors
          shattyundefined 1 Reply Last reply Reply Quote 0
          • shattyundefined
            shatty @Veti
            @Veti
            OK. TY. Hopefully I can gain progress now.
            • shattyundefined
              shatty @shatty
              @shatty
              Z wired right. Only thing is...small little problem....THE WIRE IS CUT!!! THRU 3 OF THE 4 WIRES ON ONE OF THE Z STEPPERS!!!!!
              • shattyundefined
                shatty
                Luckily MicroCenter doesnt sell them. F me. They sell a bunch of Creality replacement parts. 10 min from me. Amazon it is. Ugh
                I could repair it but its a new machine and i dont want to.
                • Vetiundefined
                  Veti @shatty
                  @shatty
                  where is the wire cut?
                  • shattyundefined
                    shatty @Veti
                    @Veti Dead center LOL.
                    I wish they has a motor upgrade pack for this printer instead of buying them individually. I want .9 motors
                    I can have the new wires here by tomorrow, Sunday
                    • shattyundefined
                      shatty
                      Also, anyway of using the stock screen with the new Beta RR firmware? I saw it now supports 2 other screens. I dont know what chipset the stock screen has
                      • Vetiundefined
                        Veti
                        do you have Heat-shrink tubing? or a solder iron.
                        fixing cut wiring is not that difficult
                        • shattyundefined
                          shatty @Veti
                          @Veti said in Newbie: New Install on Ender 5 Plus---Willing to PAY$$:
                          Yes of course....Im in IT.
                          I would rather buy new cables with the 4 pin already on them.
                          • shattyundefined
                            shatty
                            They also have jacketed wire but not terminated. Better protection.
                            • shattyundefined
                              shatty
                              Im just gunna repair it. Not in the mood to change shit around. Let u know what happens tom night. Thanks for the help
                              • shattyundefined
                                shatty
                                Well guess what...............HOMING WORKS!!!! Went to the endstops and stopped! Question...Z axis...positive value is up or down? Z positive and the bed moves down. I have a feeling its supposed to be reversed. I repaired the wire on one of the Z stepper wires.
                                • shattyundefined
                                  shatty
                                  And the BLT is making the bed stop moving up so that works. Now I guess I have to do a test print and adjust the distance from the nozzle to the bed, make sure the BLT is working on leveling, extruder speed, and manual bed leveling before I use the BLT
                                  • Vetiundefined
                                    Veti @shatty
                                    when the bed is at the bltouch trigger that is z=0 the further the bed moves away from the bltouch, z increases.
                                    so for the ender 5 plus i think going down is positive
                                    • shattyundefined
                                      shatty @Veti
                                      OK so its correct then. Whats my next step? BLT distance ? Extruder motor speed and stuff? I have a Micro Swiss direct drive all metal installed. I was reading the directions and they said 1 or 2 things have to be changed. As far as leveling, manual first then use the BLT? I guess use the wheel adjustments in each corner? How do I know when its correct? Should I use a level? Any way for the machine to tell me?
                                      • Vetiundefined
                                        Veti @shatty
                                        @shatty
                                        yes calibrate the z probe.
                                        https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe#Section_Calibrate_the_Z_probe_trigger_height
                                        then do a mesh bed leveling and look at the bed. (post a picture)
                                        then calibrate your e steps
                                        https://duet3d.dozuki.com/Guide/Ender+3+Pro+and+Duet+Maestro+Guide+Part+4:+Calibration/40#s165
                                        then pid tune your bed and hotend.
                                        https://duet3d.dozuki.com/Wiki/Tuning_the_heater_temperature_control
                                        then print a benchy and asses.
                                        shattyundefined Vetiundefined 3 Replies Last reply Reply Quote 0
                                        • shattyundefined
                                          shatty @Veti
                                          This post is deleted!
                                          • shattyundefined
                                            shatty
                                            All the steppers are quiet except the 2 Zs. Normal?
