    Newbie: New Install on Ender 5 Plus---Willing to PAY$$$
    7.2k
    • Vetiundefined
      Veti @shatty
      @shatty said in Newbie: New Install on Ender 5 Plus---Willing to PAY$$:
      TS is fine.
      i beg to differ. The bad command 55 at the end is an indication.
      shattyundefined 1 Reply Last reply Reply Quote 0
      • shattyundefined
        shatty @Veti
        @Veti Thats because I hit stop
        Not the motors are moving away from endstops with hitting the positive values. Z still fighting each other. They are in series config because there are 2 on 1 driver
        • shattyundefined
          shatty
          Paneldue5i is connected with ribbon cable only. How can it be wrong?
          • Vetiundefined
            Veti @shatty
            that mean you have to reverse the wiring of one of your stepper motors
            • shattyundefined
              shatty @Veti
              @Veti
              OK. TY. Hopefully I can gain progress now.
              • shattyundefined
                shatty @shatty
                @shatty
                Z wired right. Only thing is...small little problem....THE WIRE IS CUT!!! THRU 3 OF THE 4 WIRES ON ONE OF THE Z STEPPERS!!!!!
                • shattyundefined
                  shatty
                  Luckily MicroCenter doesnt sell them. F me. They sell a bunch of Creality replacement parts. 10 min from me. Amazon it is. Ugh
                  I could repair it but its a new machine and i dont want to.
                  • Vetiundefined
                    Veti @shatty
                    @shatty
                    where is the wire cut?
                    • shattyundefined
                      shatty @Veti
                      @Veti Dead center LOL.
                      I wish they has a motor upgrade pack for this printer instead of buying them individually. I want .9 motors
                      I can have the new wires here by tomorrow, Sunday
                      • shattyundefined
                        shatty
                        Also, anyway of using the stock screen with the new Beta RR firmware? I saw it now supports 2 other screens. I dont know what chipset the stock screen has
                        • Vetiundefined
                          Veti
                          do you have Heat-shrink tubing? or a solder iron.
                          fixing cut wiring is not that difficult
                          • shattyundefined
                            shatty @Veti
                            @Veti said in Newbie: New Install on Ender 5 Plus---Willing to PAY$$:
                            Yes of course....Im in IT.
                            I would rather buy new cables with the 4 pin already on them.
                            • shattyundefined
                              shatty
                              They also have jacketed wire but not terminated. Better protection.
                              • shattyundefined
                                shatty
                                Im just gunna repair it. Not in the mood to change shit around. Let u know what happens tom night. Thanks for the help
                                • shattyundefined
                                  shatty
                                  Well guess what...............HOMING WORKS!!!! Went to the endstops and stopped! Question...Z axis...positive value is up or down? Z positive and the bed moves down. I have a feeling its supposed to be reversed. I repaired the wire on one of the Z stepper wires.
                                  • shattyundefined
                                    shatty
                                    And the BLT is making the bed stop moving up so that works. Now I guess I have to do a test print and adjust the distance from the nozzle to the bed, make sure the BLT is working on leveling, extruder speed, and manual bed leveling before I use the BLT
                                    • Vetiundefined
                                      Veti @shatty
                                      when the bed is at the bltouch trigger that is z=0 the further the bed moves away from the bltouch, z increases.
                                      so for the ender 5 plus i think going down is positive
                                      • shattyundefined
                                        shatty @Veti
                                        OK so its correct then. Whats my next step? BLT distance ? Extruder motor speed and stuff? I have a Micro Swiss direct drive all metal installed. I was reading the directions and they said 1 or 2 things have to be changed. As far as leveling, manual first then use the BLT? I guess use the wheel adjustments in each corner? How do I know when its correct? Should I use a level? Any way for the machine to tell me?
                                        • Vetiundefined
                                          Veti @shatty
                                          @shatty
                                          yes calibrate the z probe.
                                          https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe#Section_Calibrate_the_Z_probe_trigger_height
                                          then do a mesh bed leveling and look at the bed. (post a picture)
                                          then calibrate your e steps
                                          https://duet3d.dozuki.com/Guide/Ender+3+Pro+and+Duet+Maestro+Guide+Part+4:+Calibration/40#s165
                                          then pid tune your bed and hotend.
                                          https://duet3d.dozuki.com/Wiki/Tuning_the_heater_temperature_control
                                          then print a benchy and asses.
                                          shattyundefined Vetiundefined 3 Replies Last reply Reply Quote 0
                                          • shattyundefined
                                            shatty @Veti
                                            This post is deleted!
