    Minor firmware release 1.18.2
    Firmware installation
    2.4k
    • Kulitorumundefined
      Kulitorum
      What bugs are fixed? - I really need tool z-offset to work, is that fixed in 1.18.2?
      • brianundefined
        brian
        I tried to upgrade to this firmware release in hopes it might fix my endstop troubles. It installs but when running the SetNetwork command it shows error: M587 unsupported command. So i cant get connected to the web control.
          @brian:
          See https://github.com/dc42/RepRapFirmware/blob/dev/WHATS_NEW.md for what has been fixed.
            @brian:
            That's because you were previously running a 1.19 beta version. You should go back to using the beta if it was working well for you. The bug fixes in version 1.18.2 were already implemented in the 1.19 beta.
            • brianundefined
              brian
              But it wasnt working for me. And with the 1.18.2, it is working! So is there anything i can do to initiate the wifi?
                Which version of DuetWiFiServer are oh running? It should be 1.03-ch to go with main firmware 1.18.2.
                • brianundefined
                  brian
                  yes, 1.03-ch, all three files downloaded from site.
                  duetwebcontrol 1.15a
                  duetwififirmware 1.18.2
                  duetwifiServer 1.05-ch
                  • JohnOCFIIundefined
                    JohnOCFII
                    @dc42:
                    I've just released firmware 1.18.2 (stable) at https://github.com/dc42/RepRapFirmware/releases.
                    Installed over 1.18.1. Did a few simple test prints on my T3P3 Kossel Mini. All seems good.
                    John
                      @brian:
                      I presume you mean 1.03-ch.
                      If you send M122 from a USB host program, what does it show as the wifi status?
                      • brianundefined
                        brian
                        M 122 command; it reads;
                        Network
                        WifiServer is running
                        SPI underruns 0, overruns 0
                        ===Webserver===
                        HTTP sessions: 0 of 8
                          I'm sorry, I forgot that M122 doesn't display WiFi stats in firmware versions prior to 1.19. To get the stats in 1.18 and earlier you need to send M552 S0 from USB to disconnect the network, then send M552 S1 and wait for the connect response.
                          • brianundefined
                            brian
                            it now says; Wifi Server stopped
                              So you need to send M552 S1 to start it.
                              • brianundefined
                                brian
                                says;
                                DuetWifiServer v 1.03(ch fork)
                                wifi vcc 3.14v, host name;
                                duetwwifi, reset reason: Turned on by main processor
                                Wifi is running as an access point with name
                                DuetWiFi
                                • brianundefined
                                  brian
                                  but i cant connect using the ip address or the name duetwifi
                                    If it's running as an added point then it's failed to connect to your WiFi network. You need to connect to it from a smartphone, tablet or laptop instead of to your usual WiFi router, to set up the SSID and password stored in the WiFi module. See https://duet3d.com/wiki/Configuring_RepRapFirmware_for_a_Cartesian_printer#Homing_Z_using_a_Z_probe and start in particular steps 7 to 10.
                                    • brianundefined
                                      brian
                                      Have obtained ip address on cell phone. There is no step for entering the SSID. Unable to make work.
                                      • brianundefined
                                        brian
                                        I think i'll just abort this procedure. I have a ir probe coming tomorrow. If i install that and then change firmware to the 1.19 beta, will i overcome the z endstop issue? Also having difficulty locating that download again. Do you have a link to it?
                                        Thank
                                        • Dougal1957undefined
                                          Dougal1957
                                          Brian
                                          Do you have anyone who lives near you that has the Duet boards that could possibly help you?
                                          Where are you based?
                                          Doug
                                          • brianundefined
                                            brian
                                            I'm in western Canada, not much help in these parts. My z probe arrived so maybe i'll have more success. Now if i can find that link to v 1.19 beta.
