    Garbage on LCD screen
    289
    • NTX9undefined
      NTX9
      My M3D Quad is showing garbage on the screen. Essentially there appears to be Chinese characters over the normal text.
      I have two machines so I have tested the screen and the SD card on machine 2 and both seem to work fine. The problem seems to be on the Duet Maestro Board.
      I suspect that I managed to mess up the firmware. But this mainboard also seems to have issues with connecting to my local network.
      Any suggestions would be highly appreciated.
      M3D Quad
        Can you send M122 in the gcode console and post the results?
        Have your menu files been corrupted or moved?
        Is the wiring to the LCD damaged or partially disconnected?
        • NTX9undefined
          NTX9
          I tried different wires with no change. I also connected this screen to my other machine and it worked fine.
          I also swapped the SD card and it works fine on the other machine.
          I am having trouble connecting to network but will try the M122 if I get a connection.
            A Former User @NTX9
            @NTX9 said in Garbage on LCD screen:
            usb?
            • NTX9undefined
              NTX9
              M122
              RepRapFirmware for Duet 2 Maestro version 2.02RC5(RTOS) running on Duet Maestro 1.0
              Board ID: 08DAM-9F9GA-J24TD-6J1F2-3SN6S-T50GV
              Used output buffers: 3 of 20 (13 max)
              Static ram: 21236
              Dynamic ram: 97780 of which 0 recycled
              Exception stack ram used: 220
              Never used ram: 11836
              Tasks: NETWORK(ready,456) HEAT(blocked,952) MAIN(running,3792) IDLE(ready,200)
              Owned mutexes:
              Last reset 00:08:34 ago, cause: power up
              Last software reset at 2020-09-15 19:45, reason: User, spinning module GCodes, available RAM 18408 bytes (slot 1)
              Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0400f000 BFAR 0xe000ed38 SP 0xffffffff Task 0x4e49414d
              Error status: 0
              Free file entries: 10
              SD card 0 detected, interface speed: 15.0MBytes/sec
              MCU temperature: min 19.1, current 26.5, max 26.8
              Supply voltage: min 24.0, current 24.0, max 24.1, under voltage events: 0, over voltage events: 0, power good: yes
              Driver 0: standstill, read errors 0, write errors 0, ifcount 9, reads 20542, timeouts 0
              Driver 1: standstill, read errors 0, write errors 0, ifcount 9, reads 20542, timeouts 0
              Driver 2: standstill, read errors 0, write errors 0, ifcount 9, reads 20542, timeouts 0
              Driver 3: standstill, read errors 0, write errors 0, ifcount 9, reads 20542, timeouts 0
              Driver 4: standstill, read errors 0, write errors 0, ifcount 9, reads 20542, timeouts 0
              Driver 5: ok, read errors 0, write errors 0, ifcount 0, reads 0, timeouts 20551
              Driver 6: ok, read errors 0, write errors 0, ifcount 0, reads 0, timeouts 20550
              Date/time: 2020-11-23 10:51:24
              Slowest loop: 4581229.00ms; fastest: 0.12ms
              I2C nak errors 0, send timeouts 0, receive timeouts 0, finishTimeouts 0
              Hiccups: 0, StepErrors: 0, LaErrors: 0, FreeDm: 240, MinFreeDm: 240, MaxWait: 0ms, Underruns: 0, 0
              Bed compensation in use: none
              Bed heaters = 0, chamberHeaters = -1 -1
              Heater 0 is on, I-accum = 0.0
              Heater 1 is on, I-accum = 0.0
              Segments left: 0
              Movement lock held by null
              http is idle in state(s) 0
              telnet is idle in state(s) 0
              file is idle in state(s) 0
              serial is idle in state(s) 0
              aux is idle in state(s) 0
              daemon is idle in state(s) 0
              queue is idle in state(s) 0
              lcd is idle in state(s) 0
              Code queue is empty.
              === Network ===
              Slowest loop: 4581228.50ms; fastest: 0.02ms
              HTTP sessions: 1 of 8
              Interface state 5, link 100Mbps full duplex
                Phaedrux Moderator @NTX9
                Update your firmware to 2.05.1 for starters.
                Upload that zip file as is without extract it first to the system tab in DWC.
                NTX9undefined 1 Reply Last reply Reply Quote 0
                • NTX9undefined
                  NTX9
                  Some of the error messages are due to me disconnecting the Extruder motor and hotend from the machine in case there is a problem somewhere in the wiring.
                  • NTX9undefined
                    NTX9 @Phaedrux
                    @Phaedrux
                    You ROCK! That did the trick.
                    The firmware I tried to flash yesterday was not current.
