A solution to shutdown Duet and SBC
@PCR said in A solution to shutdown Duet and SBC:
Have you seen execonmcode?
Yes and used it too.
The problem with that IMO is that all is ok until the next firmware update.
When it happened to me it caused major problems with the Duet firmware operation. Then you have to disable it and wait for the updated version - and RRF is changing all the time. -
execonmcode would be a great solution if it became a built in plugin and therefore updated everytime.
....but you would still have to hold the power button for 30+ seconds on start up until the SBC boots and has read the config.g file that contains the M80 command to latch the power relay or SSR.
@chas2706 said in A solution to shutdown Duet and SBC:
you never know, wilriker might just get around to it when the dust settles and the plugin interface is released along with RRF 3.2
anyways, without having seen the elaborate design, can't help think the arduino is a bit overkill and having the SSR latch before the pi has booted could be solved with a pull up resistor?
@bearer said in A solution to shutdown Duet and SBC:
You got me re-visiting execonmcode and wondering why I stopped using it.
The answer is easy. It is not a solution to enable remote shutdown of the whole system.
shutdownsbc.service will shut down the SBC but then you cant power off the duet because you no longer connected!
So my solution involving a £2.50 arduino uno surely cannot be overkill? -
I'd be interested in checking this out
I guess I don't see why the duet can't turn the ssr of itself after having asked the pi to turn off. any feedback the arduino get, the duet could get, or a simple G4 would do the trick to let the pi shutdown with a minimum of grace
so it might not be overkill in terms of $, but added complexity imho (without having seen it ofc..)
so it might not be overkill in terms of $, but added complexity imho (without having seen it ofc..)Don't get what you saying. How can you shut the rest of the system down after SBC is down? You no longer have connection or control. You could send a G4 delay but then the pi is in shutdown process and duet has no control, the pi is dead. The pi needs to shut down first, then duet. Pi can't shut down duet after it is shut down itself and you now have no control over duet????
If the Duet can't keep a command or two in its pipeline then there is no need to turn the pi off-off*, enough to save whatever state you wanna keep and go read-only before telling the Duet to pull the ssr low, or move the ssr to the Pi. But you've made your point, not gonna beat a dead horse.
*)it will poweroff when duet power off the psu, being in a clean state already. if holding a physical button for 30 seconds was the problem to solve then it follows there is no need for a 5v stand-by supply (or it could be powered down along with Vin as it serves no purpose after the Pi is done.
If the Duet can't keep a command or two in its pipeline then there is no need to turn the pi off-off, enough to save whatever state you wanna keep and go read-only before telling the Duet to pull the ssr low, or move the ssr to the Pi. But you've made your point, not gonna beat a dead horse.
My last word.... If you need a complete power down, In your senario you power down the duet and leave the pi shutdown but not powered off. No point beating a dead horse!
@chas2706 I would be interested, could you please upload your code?
