paneldue 7i extrusion multiplier
hello,
I am currently building a clay printer. when printing clay it is important to change the extrusion on the fly, I have a paneldue 7I attached. I would like to change the extrusion in the print menu. there are now two options to change fan and speed, I am not using a fan so is it possible to change that button to extrusion multiplier?
Thanks
@mitchel-kraai But there is already... just under temperatures You have "Extruder %" and a button with a number for each tool
@BoA yeah I see the "extruder%" but no button behind it.
You do not have buttons here?
@BoA no I dont have those buttons, could it be that I do not have it because of the disabled heater on the nozzle (clay printer)?
Which version of PanelDue firmware are you using?
@dc42 the firmware on there is 1.23.2
You may get better results with the new PanelDue firmware, 3.2.x. Note, it only works with RRF 3.1.1 and later.
What firmware is your Duet running?
