    Controller board setup for custom 3D printer
    517
    • plasminoundefined
      plasmino @Phaedrux
      I’m using NEMA 23 3Nm powered at 4Arms.
      I’d like to use my existing drivers because they are pretty good and moreover they are powered by an external 36V AC line and the existing 24V line can’t provide enough power.
      @Phaedrux said in Controller board setup for custom 3D printer:
      If you're wanting to use exclusively external motors there is a future Duet 3 planned that would have no internal drivers at all for just this case.
      This seems very interesting, it would be nice to avoid having expansion boards. Can you give me more information?
      Phaedruxundefined Vetiundefined 2 Replies Last reply Reply Quote 0
        Phaedrux Moderator @plasmino
        @plasmino said in Controller board setup for custom 3D printer:
        Not at this time. Look for more info in a month or two maybe.
        In the meantime though, you can use external drivers.
        Can you give some more information on your existing external drivers to see if they would be suitably driven by the Duet?
        • Vetiundefined
          Veti @plasmino
          you can run the duet 3 with up to 32V. If you are fine with that, you could power the motors directly.
          • plasminoundefined
            plasmino
            My external drivers must be powered by AC anywhere from 18 to 36V, step/dir signals can be either differential or common anode/cathode from 3.3 to 28V and they can deliver up to 4Arms phase current. Max microstepping is 1/128.
            I think the step/dir voltage range is not a problem but I’will need expansion boards.
            With the Duet 2 the breakout board would be fine but I can’t use 12/24V endstops and IO.
            The Duet 3 will instead need one 1XD board for esche external driver.
            Am I right?
            @Veti said in Controller board setup for custom 3D printer:
            I have only 24V DC and 36V AC lines, with the AC one being the only one that can deliver enough power to drive the motors. I suppose I can’t power a Duet board with AC power supply.
            • Vetiundefined
              Veti
              can you post the exact motor name?
              plasminoundefined 1 Reply Last reply Reply Quote 0
              • plasminoundefined
                plasmino @Veti
                I don't have access to them right now and I don't remember the exact model number. However they are standard NEMA23 (3Nm, 4Arms max).
                The problem is that I can drain enough power for the motors only from the AC line, with wich I can't power any Duet board I think.
                • Vetiundefined
                  Veti @plasmino
                  again i think you could remove the external stepper motors and power the nema23 motors directly if you are fine with 32V for the nema motors
                  • plasminoundefined
                    plasmino @Veti
                    @Veti
                    Let's say I remove my external drivers and use Duet built-it ones. So I'll need a Duet 3 to deliver 4Arms.
                    I can't power the board with the 24V line because it can't provide enough Amps.
                    I can't power the board with the 36V line because is AC.
                    If I don't go wrong the only option would be to buy another power supply in order to transform 36VAC to 24VDC or 32VDC.
                    Since I already need to buy a new controller board, I'd prefer buying one compatible with my existing system, but if there aren't any other chances I'll consider this option.
                    Moreover, without detracting Duet's TMC5160, I think my steppers are better. Just the size of one of them is half of a Duet board.
                    • Vetiundefined
                      Veti @plasmino
                      that could also mean they are inefficient and need a lot of cooling 🙂
                      anyway here is a link to the external stepper board for the duet 3
                      https://www.duet3d.com/Duet3Expansion1XD
                      • plasminoundefined
                        plasmino @Veti
                        Yes, you're right, indeed their 36VAC line can provide way more power they need.
                        I would need one of those for each eaxis right?
                        • Vetiundefined
                          Veti @plasmino
                          one for each external stepper. a new power supply might be cheaper 🙂
                          • plasminoundefined
                            plasmino @Veti
                            Yes, I agree, I'll keep this option as a backup plan.
                            I'd like to know more about the board mentioned by @Phaedrux, if it's going to be released and purchasable in the next 2/3 months I'll wait for sure.
                              @T3P3Tony might have a better idea on availability.
