    No Connection to DCS After Update to 3.2beta4
    Firmware installation
    1.2k
    • Vetiundefined
      Veti @Frederik
      @Frederik
      yes if the firmware is erased, the diag led should be on constant
      • Vetiundefined
        Veti @Veti
        some people have had to use up to 18 different cable until they found one that worked.
        Frederikundefined 1 Reply Last reply Reply Quote 0
        • Frederikundefined
          Frederik @Veti
          @Veti you are joking, right ?!? 18 Cables....holy...i cant find what the meaning of the static diage led is ?
          • Vetiundefined
            Veti
            see
            https://duet3d.dozuki.com/Wiki/What_to_do_if_your_Duet_won't_respond
            If the firmware has been erased the DIAG LED will be on permanently.
            • Frederikundefined
              Frederik @Veti
              @Veti Thank You SOooooooOO much for your tip with the usb cable....i tried a 10 year old usb2 dvd cable (with dual A Plugs on one side). After connecting the second the firmware flashed perfektly on the first try ;).
              I would be so lost without you guys and this forum 🙂
              Have a nice Day !
              Frederikundefined 1 Reply Last reply Reply Quote 2
              • Frederikundefined
                Frederik @Frederik
                @Frederikfor information purposes:
                The cable that did NOT work: brand new Ugreen with 3Meters in lenght.
                The cable THAT worked: 10 Year old usb2.0 with dual USB-A Plug on one side.
                Like the on the external dvd or harddrives. Lenght ~ 40cm
                • Frederikundefined
                  Frederik
                  So, the cable worked. The firmware flash over bossa worked. Also verifying. I did 2 times exact what's mentioned in the getti g startet wiki. I loaded the additional files, flashed a new copy of duet pi desktop on the 16gb card. After that I copied my .g files in the /sys folder on the boot partition together with the 3.1.1 firmware .bin.
                  After that, I Did all the steps like network, keyboard layout etc. Without any errors.
                  Even the update at the end + restart showed no errors. Only in the dcs log is constantly starting and stoping with the meassage:
                  No connection to duet3
                  Should I do a standalone firmware reset and after that reconnecting the pi?
                  It seems that the reset button did not reset the board, even if I hold it like 10 seconds
                  Phaedruxundefined chrishammundefined 2 Replies Last reply Reply Quote 0
                  • Frederikundefined
                    Frederik
                    I do all the actual test without Vin.
                    Only connection over usb and wlan
                      Phaedrux Moderator @Frederik
                      @Frederik said in No Connection to DCS After Update to 3.2beta4:
                      Yes I would set it up in standalone to confirm that the Duet is working correctly otherwise and see what firmware version is flashed.
                      • Frederikundefined
                        Frederik @Phaedrux
                        @Phaedrux Thanks. I will test that later.
                        • chrishammundefined
                          chrishamm administrators @Frederik
                          @Frederik You did not mention that you changed the package feed from stable to unstable which is a required step if you want to use DSF 3.2-b4 as well. If you don't do that, you'll get the error message you mentioned.
                          See here for further information.
                          Duet software engineer
                          • Frederikundefined
                            Frederik @chrishamm
                            @chrishammyes, i have the unstable all the time.
                            After i changed to the standalone mode, made the specific sd card + filestrukture, the board accepted the firmware and the diag led is now out . after that i startet a complete new installation with the pi.
                            this time everything works fine..
                            The new Visualizer is amazing 🙂
                            Tomorrow i will install and test the new DuetLapse .
                            But that way did not work at first with the sbc attached.
                            Thanks for all your help
                            Regards
                            Frederik
