Duet 3 BLTouch probing issues
1.8k
    Veti
    @Vampora said in Duet 3 BLTouch probing issues:
    G31 X-30 Y0 Z0.75 P25 ; Set the offsets for the bltouch
    change to P1000
    P25 could be triggered by interference.
    undefined 1 Reply Last reply 1 Dec 2020, 15:05 Reply Quote 0
      Vampora @Veti
      @Veti said in Duet 3 BLTouch probing issues:
      change to P1000
      No change
      G32
      Leadscrew adjustments made: -5.000 -5.000 -5.000, points used 3, (mean, deviation) before (-5.000, 0.000) after (-0.000, 0.000)
        Vampora
        I just want to make sure..... does anyone think it is the bltouch not being v3.1? I'm debating ordering one since I don't have one, but my gut tells me that is not the issue.
          Veti
          M558 P9 C"^io7.in" H5 R1 F120 T6000 A5 S0.02 B1 ; Define the bltouch input on io7.in
          can you change the H5 to H6 and see if the result changes?
            Vampora
            I actually just tried bumping it to 10 and this is what I got.
            It just changes everything to -10 instead of -5
            M98 P"0:/macros/Probe_Test"
            G32 bed probe heights: -10.000 -10.000 -10.000 -10.000 -10.000 -10.000 -10.000 -10.000 -10.000 -10.000, mean -10.000, deviation from mean 0.000
              Veti
              this suggests there is a problem with your bltouch.
              how many probing of the bed does it actually do when you run the macro?
                Vampora
                It does 10
                  Veti
                  is there an error in the console?
                  this suggest that the bltouch is already triggered.
                  whats the z value in the ui?
                    Vampora
                    What I don't understand is the probes work just fine on my other railcores with duet 2 boards.
                    The first time it probes z it will set the z to 0.75 which is the same as my offset. The next time it probes it will say -4.25, and the 3rd will also say -4.25
                    When the command is given to raise to Z5 it says 5.75.
                    Would a video help shed light on it at all?
                    I usually do get random sporadic errors saying that say:
                    G29
                    Error: Z probe was not triggered during probing move
                      Vampora
                      This post is deleted!
                        Veti
                        this suggests that there is a wiring problem. maybe a bad crimp on the extension cable.
                          Vampora
                          ill post a video of what it does on zhome
                          https://youtu.be/T1yf528Uigg
                            Vampora
                            Im uploading a video of what the probe does as well on that side. I don't know it looks normal to me.
                            https://youtu.be/OrtBIjhiNEY
                              Vampora
                              if we do think it is the wiring though i can swap it out. I'm starting to wonder if i shouldn't just go a different probe route and do away with the bltouch all together.
                                Veti
                                can your remove the A5 and try again
                                  Vampora
                                  Same thing other than it is only probing once now instead of multiple times in each spot.
                                  undefined 1 Reply Last reply 1 Dec 2020, 18:26 Reply Quote 0
                                    Veti @Vampora
                                    @Vampora
                                    to me it sound like a problem with the bltouch, but non i have seen before.
                                    is there a different probe you can test? like a capacitive sensor or something?
                                      Vampora
                                      i have an IR sensor i could pull off another printer if need be. That is it otherwise they are all BLtouches.
                                        Vampora
                                        want me to pull it and try to set it up?
                                          Veti
                                          unless someone else has another idea, i would try the ir probe.
                                          26 out of 62
