Duet 3 BLTouch probing issues
1.8k
    Vampora
    should i change it back to 3 point to try to figure this out?
      jay_s_uk
      I would change back to 3 points.
      Just make sure they're in the same order as your M671. So front left, front right and rear middle
        Vampora
        with the 3 point i still get this:
        G32
        Leadscrew adjustments made: -5.000 -5.000 -5.000, points used 3, (mean, deviation) before (-5.000, 0.000) after (-0.000, 0.000)
          jay_s_uk
          Can you post your homeall and homez file?
            Vampora
            homez:
            ; homez.g
            ; called to home the Z axis
            G91
            G1 Z5 F800 H2
            G90
            G1 X182 Y118 F2400
            G30
            G1 Z2 F200
            homeall:
            M98 P"homex.g"
            M98 P"homey.g"
            M98 P"homez.g"
              jay_s_uk
              I can't see anything in there that would cause the issue.
              Could you reboot the board and run the probing again?
              Could you also post the updated bed file?
                Vampora
                Updated bed.g:
                M561 ; clear any existing bed transform
                ;G1 Z5 H2
                G28 ; home
                G30 P0 X2 Y2 Z-99999
                G30 P1 X2 Y229 Z-99999
                G30 P2 X240 Y116 Z-99999 S3
                G1 X0 Y0 F5000 ; move the head to the corner (optional)
                  Vampora
                  Rebooted, ran g32:
                  G32
                    jay_s_uk
                    Nothing else I can add on this one.
                    Maybe one for @Phaedrux or @dc42 to comment on?
                      Veti
                      @Vampora said in Duet 3 BLTouch probing issues:
                      G31 X-30 Y0 Z0.75 P25 ; Set the offsets for the bltouch
                      change to P1000
                      P25 could be triggered by interference.
                      undefined 1 Reply Last reply 1 Dec 2020, 15:05 Reply Quote 0
                        Vampora @Veti
                        @Veti said in Duet 3 BLTouch probing issues:
                        change to P1000
                        No change
                        G32
                          Vampora
                          I just want to make sure..... does anyone think it is the bltouch not being v3.1? I'm debating ordering one since I don't have one, but my gut tells me that is not the issue.
                            Veti
                            M558 P9 C"^io7.in" H5 R1 F120 T6000 A5 S0.02 B1 ; Define the bltouch input on io7.in
                            can you change the H5 to H6 and see if the result changes?
                              Vampora
                              I actually just tried bumping it to 10 and this is what I got.
                              It just changes everything to -10 instead of -5
                              M98 P"0:/macros/Probe_Test"
                              G32 bed probe heights: -10.000 -10.000 -10.000 -10.000 -10.000 -10.000 -10.000 -10.000 -10.000 -10.000, mean -10.000, deviation from mean 0.000
                                Veti
                                this suggests there is a problem with your bltouch.
                                how many probing of the bed does it actually do when you run the macro?
                                  Vampora
                                  It does 10
                                    Veti
                                    is there an error in the console?
                                    this suggest that the bltouch is already triggered.
                                    whats the z value in the ui?
                                      Vampora
                                      What I don't understand is the probes work just fine on my other railcores with duet 2 boards.
                                      The first time it probes z it will set the z to 0.75 which is the same as my offset. The next time it probes it will say -4.25, and the 3rd will also say -4.25
                                      When the command is given to raise to Z5 it says 5.75.
                                      Would a video help shed light on it at all?
                                      I usually do get random sporadic errors saying that say:
                                      G29
                                      Error: Z probe was not triggered during probing move
                                        Vampora
                                        This post is deleted!
                                          Veti
                                          this suggests that there is a wiring problem. maybe a bad crimp on the extension cable.
                                          17 out of 62
