    G30, G32 Issues on Duet WiFi CoreXYU with inductive probe
    456
    • vasparshinundefined
      vasparshin
      Having some very strange issues related to Z - probing using a NPN NC inductive probe on a CoreXYU running latest 3.2b4. This is the probe, and probe value reads as either 0 or 1000 when triggered. It is connected to the Duet 2 probe pins.
      When G30 is called, after probing in the middle of the bed the X and Y coordinates are reset to 0.
      When something like G30 P0 X20 Y50 Z-99999 F600 is called, after the probing the machine moves VERY FAST to X0 Y0 afterwards. If several of points are probed in such a way (like with G32), the movements back to 0, 0 are increasingly fast and motors start skipping.
      Have tried various different parameters for CoreXYU to simulate CoreXYUV as well as G1 H parameter change and G30 with different S values but nothing seems to work as it should.
      Below is the config relative parts:
      M569 P0 S0                                             				; physical drive 0 goes forwards - X
      M569 P1 S0                                             				; physical drive 1 goes forwards - Y
      M569 P2 S1                                             				; physical drive 2 goes forwards - Z
      M569 P3 S0                                             				; physical drive 3 goes forwards - E0
      M569 P4 S1                                             				; physical drive 4 goes forwards - E1 (W)
      M569 P6 S1											   				; physical drive 5 goes forwards - U (TMC Chip on Extrudeo Expansion Board)
      M584 X1 Y0 Z2 E3:4 U6                              					; set drive mapping - X and Y switched to allow for correct X direction (depends on how the motors are plugged)
      M350 X16 Y16 Z16 E16:16 U16 I1                        		      	; configure microstepping with interpolation
      M92 X160.00 Y160.00 Z3200.00 E830.00:830.00 U160.00       			; set steps per mm
      M566 X800.00 Y800.00 Z300.00 E1000.00:1000.00  U800.00   			; set maximum instantaneous speed changes (mm/min)
      M203 X5000.00 Y5000.00 Z1400.00 E5000.00:5000.00 U5000.00    		; set maximum speeds (mm/min)
      M201 X500 Y500 Z250 E500:500 U500     								; set accelerations (mm/s^2)
      M906 X1200 Y1200 Z1200 E1000:1000 U1000  I25           	    		; set motor currents (mA) and motor idle factor in per cent
      M84 S30                                                			    ; Set idle timeout
      M669 K5 		      												; select coreXYU mode
      M208 X0 Y0 Z0 U0 S1												; set axis minima
      M208 X160 Y240 Z150 U80  S0									; set axis maxima
      M574 X1 S1 P"xstop"                                   				; configure active-high endstop for low end on X via pin xstop
      M574 Y1 S1 P"ystop"                                    				; configure active-high endstop for low end on Y via pin ystop
      M574 Z1 S2 P"nil"                                            		; configure Z-probe endstop for low end on Z  homing
      M574 U1 S1 P"e0stop"
      ; Filament sensors
      M591 D0 P2 C"duex.e3stop" S1
      M591 D1 P2 C"duex.e4stop" S1
      M558 P5 C"zprobe.in" H5 F600
      G31 P999 X0 Y0 Z0.2                                    		; set Z probe trigger value, offset and trigger height P5
      M557 X0:160 Y15:240 S25                               				; define mesh grid
      M308 S0 P"bedtemp" Y"thermistor" T100000 B4092         				; configure sensor 0 as thermistor on pin bedtemp
      M950 H0 C"bedheat" T0                                  				; create bed heater output on bedheat and map it to sensor 0
      M307 H0 B1 S1.00                                       				; enable bang-bang mode for the bed heater and set PWM limit
      M140 H0                                                				; map heated bed to heater 0
      M143 H0 S120                                           				; set temperature limit for heater 0 to 120C
      M308 S1 P"e0temp" Y"thermistor" T100000 B4725 C7.06e-8 				; configure sensor 1 as thermistor on pin e0temp
      M950 H1 C"e0heat" T1                                   				; create nozzle heater output on e0heat and map it to sensor 1
      M307 H1 B0 S1.00                                       				; disable bang-bang mode for heater  and set PWM limit
      M308 S2 P"e1temp" Y"thermistor" T100000 B4725 C7.06e-8 				; configure sensor 2 as thermistor on pin e1temp
      M950 H2 C"e1heat" T2                                   				; create nozzle heater output on e1heat and map it to sensor 2
      M307 H2 B0 S1.00                                       				; disable bang-bang mode for heater  and set PWM limit
      M308 S3 P"duex.e2temp" Y"thermistor" T100000 B4092     				; configure sensor 3 as thermistor on pin duex.e2temp
      M950 H3 C"duex.e2heat" T3                              				; create chamber heater output on duex.e2heat and map it to sensor 3
      M307 H3 B1 S1.00                                       				; enable bang-bang mode for the chamber heater and set PWM limit
      M141 H3                                                				; map chamber to heater 3
      M950 F0 C"fan0" Q500                                   				; create fan 0 on pin fan0 and set its frequency
      M106 P0 C"E0_Heatsink_Fan" S1 H1 T45                   				; set fan 0 name and value. Thermostatic control is turned on
      M950 F1 C"fan1" Q500                                   				; create fan 1 on pin fan1 and set its frequency
      M106 P1 C"E0_Part_Fan" S1 H-1                          				; set fan 1 name and value. Thermostatic control is turned off
      M950 F2 C"fan2" Q500                                   				; create fan 2 on pin fan2 and set its frequency
      M106 P2 C"E1_Part_Fan" S1 H-1                     				    ; set fan 2 name and value. Thermostatic control is turned on
      M950 F3 C"duex.fan3" Q500                              				; create fan 3 on pin duex.fan3 and set its frequency
      M106 P3 C"E1_Heatsink_Fan" S1 H2 T45                          		; set fan 3 name and value. Thermostatic control is turned off
      M950 F4 C"duex.fan4" Q500                             				; create fan 4 on pin duex.fan4 and set its frequency
      M106 P4 C"Chamber_Fan" S1 H-1                       				; set fan 4 name and value. Thermostatic control is turned on
      M950 F5 C"duex.fan5" Q500                              				; create fan 5 on pin duex.fan5 and set its frequency
      M106 P5 C"Chamber_LED" S1 H-1                             				; set fan 5 name and value. Thermostatic control is turned off
      M950 F6 C"duex.fan6" Q500                              				; create fan 6 on pin duex.fan6 and set its frequency
      M106 P6 C"Electronics_Fan" S1 H-1                                         		; set fan 6 value. Thermostatic control is turned off
      M563 P0 D0 H1 F0                                       				; define tool 0
      G10 P0 X0 Y0 Z0                                        				; set tool 0 axis offsets
      G10 P0 R0 S0                                           				; set initial tool 0 active and standby temperatures to 0C
      M563 P1 D1 H2 F0                                       				; define tool 1
      G10 P1 X20 Y0 Z0                                        				; set tool 1 axis offsets
      G10 P1 R0 S0                                           				; set initial tool 1 active and standby temperatures to 0C
      Any advice would be much appreciated, as I can not seem to find a similar issue on the forums.
      • Vetiundefined
        Veti
        @vasparshin said in G30, G32 Issues on Duet WiFi CoreXYU with inductive probe:
        the offset of X0 Y0 can not be correct for a npn probe. the probe has to have an offset
        also you are probing very fast Switch to P8, but also consider lowering the probing speed.
        can you try with 3.1.1? that is the latest stable.
        vasparshinundefined 1 Reply Last reply Reply Quote 0
          Post your homing files and bed.g as well.
          And the results of M122 and M98 P"config.g"
            vasparshin @Veti
            @Veti
            Thank you for suggestions,
            I have reverted to correct offset (set 0, 0 to see if anything changes), no change.
            Have tried P8 instead of P5 and lowered probing speed, no difference.
            Previously was on 3.0 stable and had the same issue. Might try 3.1.1 if nothing else helps.
            @Phaedrux
            Home X (Y and U is the same code):
            G91               ; relative positioning
            G1 H2 Z5 F6000    ; lift Z relative to current position
            G1 H1 X-235 F1800 ; move quickly to X axis endstop and stop there (first pass)
            G1 X5 F6000       ; go back a few mm
            G1 H1 X-235 F360  ; move slowly to X axis endstop once more (second pass)
            G1 H2 Z-5 F6000   ; lower Z again
            G90               ; absolute positioning
            Home Z - also sets X & Y to 0 afterwards while setting Z correctly
            G1 H1 Y-215 F1800 ; move quickly to Y axis endstop and stop there (first pass)
            G1 Y5 F6000       ; go back a few mm
            G1 H1 Y-215 F360  ; move slowly to Y axis endstop once more (second pass)
            Bed.g is just G29 for now
            M122:
            RepRapFirmware for Duet 2 WiFi/Ethernet version 3.2-beta4 running on Duet WiFi 1.02 or later + DueX2
            Board ID: 08DDM-9FAM2-LW4SD-6J1F8-3SD6P-T3W7X
            Used output buffers: 3 of 24 (13 max)
            Static ram: 24108
            Dynamic ram: 102372 of which 48 recycled
            Never used RAM 3520, free system stack 190 words
            Tasks: NETWORK(ready,176) HEAT(blocked,308) DUEX(blocked,35) MAIN(running,379) IDLE(ready,20)
            Owned mutexes: WiFi(NETWORK)
            Last reset 00:00:19 ago, cause: software
            Last software reset at 2020-12-02 12:14, reason: User, GCodes spinning, available RAM 3444, slot 0
            Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0041f000 BFAR 0xe000ed38 SP 0xffffffff Task MAIN
            Error status: 0x00
            MCU temperature: min 39.9, current 41.1, max 42.7
            Supply voltage: min 24.3, current 24.4, max 24.6, under voltage events: 0, over voltage events: 0, power good: yes
            Driver 0: position 0, standstill, SG min/max not available
            Driver 1: position 0, standstill, SG min/max not available
            Driver 2: position 0, standstill, SG min/max not available
            Driver 3: position 0, standstill, SG min/max not available
            Driver 4: position 0, standstill, SG min/max not available
            Driver 5: position 0, standstill, SG min/max not available
            Driver 6: position 0, standstill, SG min/max not available
            Driver 7: position 0
            Driver 8: position 0
            Driver 9: position 0
            Driver 10: position 0
            Driver 11: position 0
            Date/time: 2020-12-02 12:14:30
            Cache data hit count 29327380
            Slowest loop: 3.32ms; fastest: 0.21ms
            === Storage ===
            Free file entries: 10
            SD card longest read time 1.0ms, write time 0.0ms, max retries 0
            Hiccups: 0(0), FreeDm: 169, MinFreeDm: 169, MaxWait: 0ms
            === MainDDARing ===
            Scheduled moves 0, completed moves 0, StepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1
            === AuxDDARing ===
            Bed heaters = 0 -1 -1 -1, chamberHeaters = 3 -1 -1 -1
            Heater 1 is on, I-accum = 0.0
            Segments left: 0
            Movement lock held by null
            HTTP is idle in state(s) 0
            Telnet is idle in state(s) 0
            File is idle in state(s) 0
            USB is idle in state(s) 0
            Aux is idle in state(s) 0
            Trigger is idle in state(s) 0
            Queue is idle in state(s) 0
            LCD is idle in state(s) 0
            Daemon is idle in state(s) 0
            Code queue is empty.
            === Network ===
            Slowest loop: 16.04ms; fastest: 0.00ms
            HTTP sessions: 1 of 8
            - WiFi -
            Network state is active
            WiFi firmware version 1.25beta0
            WiFi MAC address 60:01:94:73:61:69
            WiFi Vcc 3.33, reset reason Turned on by main processor
            WiFi flash size 4194304, free heap 23408
            WiFi IP address 192.168.31.20
            WiFi signal strength -60dBm, mode 802.11n, reconnections 0, sleep mode modem
            Clock register 00002002
            === Filament sensors ===
            Extruder 0 sensor: ok
            Extruder 1 sensor: ok
            === DueX ===
            Read count 1, 3.09 reads/min
            M98 P"config.g":
            HTTP is enabled on port 80
            FTP is disabled
            TELNET is disabled
            Error: Invalid kinematics matrix
            Error: Invalid use of P parameter
            Trying to figure out why kinematics matrix is invalid now, not sure what P parameter it is - is there a way to get the line number of error?
            M669 gives:
            Kinematics is CoreXYU, matrix:
            1.00 1.00 0 0
            1.00 -1.00 0 1.00
            0 0 1.00 0
            0 0 0 1.00
            Vetiundefined dc42undefined 2 Replies Last reply Reply Quote 0
            • Vetiundefined
              Veti @vasparshin
              no. execute each line with a P in it in the console
                vasparshin
                Can be marked as solved, thanks everyone who tried to help.
                It turned out to be a kinematics related issue - changed the following:
                M669 K5
                to:
                M669 K1 X1:1:0:0 Y1:-1:0:1 Z0:0:1:0 U0:0:0:1						; select coreXY mode with kinematics matrix for coreXYU
                and the issue is now completely solved, homing and mesh bed works as it should (the solution/proper gcode was found here)
                @dc42 if you have time, any idea as to why K5 mode of M669 which is meant for coreXYU gives this weird homing issue? I have tried explicitly changing M669 K1 back to K5 with the same matrix and the issue returned, with K1 it is working normal.
                  dc42 administrators @vasparshin
                  That error means that the matrix was singular, so that it cannot be inverted. A likely reason is that a whole row or column is all zeros. In other words, there was an axis that none of the motors moves, or a motor that moves none of the axes.
                  Did you get that error with just the M669 K5 line, or did you have other parameters on that line, or a second M669 command?
                  EDIT: I have just reproduced this issue. I will log it as a bug to be fixed in the next 3.2beta release.
                    vasparshin @dc42
                    Thank you!
