Duet 3 BLTouch probing issues
lol it might be time to try to hire someone to do this for me. I never had issues before, but this thing is just kicking my butt.
Am I allowed to commission someone on here? Or put a bounty up? For real though I am debating it at this point.
You can do what you like, but the the paid help is the same as the free help.
I've looked at your config and you've already gone through any changes I would have made with the others.
I would suggest that the main issue is that it's an older version knock off BLTouch.
Can you send M98 P"config.g" and M122 please?
The only other thing I can think of would be to cut the trace on the BLtouch since it's one of the older ones.
And To try a different io port if you haven't already.
@Phaedrux said in Duet 3 BLTouch probing issues:
M98 P"config.g"
M98 P"config.g"
Warning: M307: Heater 0 appears to be over-powered. If left on at full power, its temperature is predicted to reach 265CM122
RepRapFirmware for Duet 3 MB6HC version 3.1.1 running on Duet 3 MB6HC v1.01 or later (SBC mode)
Board ID: 08DJM-956BA-NA3TN-6JTD0-3SS6J-1V92V
Used output buffers: 1 of 40 (11 max)
Static ram: 154604
Dynamic ram: 163268 of which 76 recycled
Exception stack ram used: 224
Never used ram: 75044
Tasks: NETWORK(ready,1980) HEAT(blocked,1188) CanReceiv(suspended,3820) CanSender(suspended,1488) CanClock(blocked,1436) TMC(blocked,204) MAIN(running,4944) IDLE(ready,76)
Owned mutexes:
Last reset 00:01:39 ago, cause: software
Last software reset at 2020-12-01 21:44, reason: User, spinning module LinuxInterface, available RAM 74660 bytes (slot 0)
Software reset code 0x0010 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0444a000 BFAR 0x00000000 SP 0xffffffff Task MAIN
Error status: 0
MCU temperature: min 41.9, current 42.1, max 42.4
Supply voltage: min 24.1, current 24.1, max 24.1, under voltage events: 0, over voltage events: 0, power good: yes
12V rail voltage: min 12.1, current 12.1, max 12.2, under voltage events: 0
Driver 0: standstill, reads 32230, writes 17 timeouts 0, SG min/max 0/0
Driver 1: standstill, reads 32230, writes 17 timeouts 0, SG min/max 0/0
Driver 2: standstill, reads 32236, writes 11 timeouts 0, SG min/max 0/0
Driver 3: standstill, reads 32231, writes 17 timeouts 0, SG min/max 0/0
Driver 4: standstill, reads 32231, writes 17 timeouts 0, SG min/max 0/0
Driver 5: standstill, reads 32238, writes 11 timeouts 0, SG min/max 0/0
Date/time: 2020-12-01 21:46:18
Slowest loop: 4.37ms; fastest: 0.14ms
=== Storage ===
Free file entries: 10
=== MainDDARing ===
Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1
=== AuxDDARing ===
Segments left: 0
Movement lock held by null
HTTP* is ready with "M122" in state(s) 0
Telnet is idle in state(s) 0
File is idle in state(s) 0
USB is idle in state(s) 0
Aux is idle in state(s) 0
Queue is idle in state(s) 0
LCD is idle in state(s) 0
SBC is idle in state(s) 0
Daemon* is idle in state(s) 0
Aux2 is idle in state(s) 0
Code queue is empty.
=== Network ===
Slowest loop: 1.01ms; fastest: 0.01ms
HTTP sessions: 0 of 8- Ethernet -
State: disabled
Error counts: 0 0 0 0 0
=== Filament sensors ===
Extruder 0 sensor: no data received
=== CAN ===
Messages sent 364, longest wait 1ms for type 6018
=== Linux interface ===
State: 0, failed transfers: 0
Last transfer: 16ms ago
RX/TX seq numbers: 2874/2876
SPI underruns 0, overruns 0
Number of disconnects: 1
Buffer RX/TX: 0/0-0
=== Duet Control Server ===
Duet Control Server v3.1.1
Trigger:
Finishing macro config.g, started by system
Next stack level
Code buffer space: 4096
Full transfers per second: 31.39 - Ethernet -
Ill cut the trace and see what happens.
I think I missed this my first look through, but are you using an expansion board for your Z motors?
You will need to take a look at this:
Endstop switches and Z probes connected to the main board cannot control motors on an expansion board. This is planned to be fixed in release 3.3.0.
If you use a Z probe then the Z motors must be connected to the main board. This is planned to be fixed in release 3.3.0.If that's the case, then I suggest you move the extruders to the expansion and move the Z axis to the main board.
I am using the expansion for the Z yes. I will take a look at that and swap them.
Ah yes i see what you mean. I'll get back to you.
That was it! OMG Thank You!
wait does that mean that now that my extruders are on the expansion the filament runouts wont work? thats fine i guess, but just so i dont go searching for a reason why if they dont
@Vampora they should work in 3.2 beta 4
@Phaedrux Gotcha.
