    PT100 and daughter board issue
    • Ducati87undefined
      Ducati87
      Hello guys, after some prints, the PT100 didn't want to work anymore.
      below are the tests I performed:
      • changed the PT100, nothing changed
      • tried all the 8 ports with a 100ohm resistance in order to understand if the daughterboard works but the value is always 2000.
      I bought the daughter board some weeks ago.
      How can I understand if the board works?
      thank you.
      BoAundefined 1 Reply Last reply Reply Quote 0
      • BoAundefined
        BoA @Ducati87
        @Ducati87 It was working, and it does not work now? Ot it was not working at all ?
        • Ducati87undefined
          Ducati87
          it worked like a charm. After some prints it doesn't work anymore without a reason...Now I have replaced the PT100 with a normal thermistore.
            1. Connect the 100R resistor to one of the inputs, also make sure that you have the 2 jumpers for that input fitted.
            2. If it reads 2000C, send M305 H# (if using RRF2) or M308 S# (if using RRF3) to get the error reason for that sensor, where # is the heater number (RRF2) or sensor number (RRF3).
            3. Post your config.g file and tell us what firmware version you are using.
            • Ducati87undefined
              Ducati87
              config.g:
              ; generated by RepRapFirmware Configuration Tool v3.1.8 on Fri Nov 20 2020 20:14:09 GMT+0100 (Ora standard dell’Europa centrale)
              G90                                                ; send absolute coordinates...
              M83                                                ; ...but relative extruder moves
              M550 P"Hypercube Evolution"                        ; set printer name
              M669 K1                                            ; select CoreXY mode
              M552 S1                                            ; enable network
              M586 P0 S1                                         ; enable HTTP
              M586 P1 S0                                         ; disable FTP
              M586 P2 S0                                         ; disable Telnet
              M569 P0 S1                                         ; physical drive 0 goes forwards
              M569 P1 S1                                         ; physical drive 1 goes forwards
              M569 P2 S0                                         ; physical drive 2 goes forwards
              M569 P3 S1                                         ; physical drive 3 goes forwards
              M569 P4 S0                                         ; physical drive 4 goes forwards
              M584 X0 Y1 Z2:4 E3                                 ; set drive mapping
              M350 X16 Y16 Z16 E16 I1                            ; configure microstepping with interpolation
              M92 X161.12 Y160.37 Z393.18:393.18 E830.00         ; set steps per mm
              M566 X1000.00 Y1000.00 Z15.00 E120.00                ; set maximum instantaneous speed changes (mm/min)
              M203 X6000.00 Y6000.00 Z600.00 E1800.00            ; set maximum speeds (mm/min)
              M201 X1800.00 Y1800.00 Z30.00 E300.00              ; set accelerations (mm/s^2)
              M906 X1000 Y1000 Z1500:Z1500 E1000 I30                    ; set motor currents (mA) and motor idle factor in per cent
              M84 S30                                            ; Set idle timeout
              M208 X0 Y0 Z0 S1                                   ; set axis minima
              M208 X0:300 Y-45:300 Z285 S0                     ; set axis maxima
              M574 X1 S3                                         ; configure sensorless endstop for low end on X
              M574 Y1 S3                                         ; configure sensorless endstop for low end on Y
              M574 Z1 S2                                         ; configure Z-probe endstop for low end on Z
              M950 S0 C"exp.heater3"                             ; create servo pin 0 for BLTouch
              M558 P9 C"^zprobe.in" H3 F420 T9000                ; set Z probe type to bltouch and the dive height + speeds
              G31 P500 X22 Y-37 Z2.520                             ; set Z probe trigger value, offset and trigger height
              M557 X0:250 Y25:230 S40:40                         ; define mesh grid
              M308 S0 P"bedtemp" Y"thermistor" T100000 B3950     ; configure sensor 0 as thermistor on pin bedtemp
              M950 H0 C"bedheat" T0                              ; create bed heater output on bedheat and map it to sensor 0
              M307 H0 B0 S1.00                                   ; disable bang-bang mode for the bed heater and set PWM limit
              M140 H0                                            ; map heated bed to heater 0
              M143 H0 S120                                       ; set temperature limit for heater 0 to 120C
              ;M308 S1 P"e0temp" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 1 as thermistor on pin e0temp
              M308 S1 P"spi.cs2" Y"rtd-max31865"                 ; configure sensor 1 as thermocouple via CS pin spi.cs2
              M950 H1 C"e0heat" T1                               ; create nozzle heater output on e0heat and map it to sensor 1
              M307 H1 B0 S1.00                                   ; disable bang-bang mode for heater  and set PWM limit
              M143 H1 S290                                       ; set temperature limit for heater 1 to 290C
              M950 F0 C"Mat Fan1" Q500                           ; create fan 0 on pin fan0 and set its frequency
              M106 P0 S0 H-1                                 ; set fan 0 value. Thermostatic control is turned off
              M950 F1 C"Hotend Fan" Q500                           ; create fan 1 on pin fan1 and set its frequency
              M106 P1 S1 H1 T45                              ; set fan 1 value. Thermostatic control is turned on
              M950 F2 C"Mat Fan2" Q500                           ; create fan 2 on pin fan2 and set its frequency
              M106 P2 S1 H-1                                 ; set fan 2 value. Thermostatic control is turned off
              M563 P0 S"hotend 0" D0 H1 F0:2                     ; define tool 0
              G10 P0 X0 Y0 Z0                                    ; set tool 0 axis offsets
              G10 P0 R0 S0                                       ; set initial tool 0 active and standby temperatures to 0C
              ; Custom settings
              M404 N1.75 D0.4								        ; Nozzle and filament diameter for monitor
              M200 D1.75 									        ; set all extruder filament diameters to 1.75mm
              M671 X40:280 Y145:145 S10							; Define positions of Z leadscrews or bed levelling screws
              M376 H10											; Set bed compensation taper
              M575 P1 S1 B57600                                  ; enable support for PanelDue
              M501                                               ; load saved parameters from non-volatile memory
              T0                                                 ; select first tool
              M308 S1:
              M308 S1
              Sensor 1 type PT100 (MAX31865) using pin spi.cs2, reading -1.3, last error: success, 2/4 wires, reject 50Hz, reference resistor 400 ohms
              Firmware:
              Board: Duet 2 WiFi (2WiFi)
              Firmware: RepRapFirmware for Duet 2 WiFi/Ethernet 3.1.1 (2020-05-19b2)
              Duet WiFi Server Version: 1.23
              • BoAundefined
                BoA
                I would say pt100 board looks OK, and pt100 sensor itself is faulty (as connected 100R resistor gives You around 0*C reading).
                • Ducati87undefined
                  Ducati87
                  yes now seems to work....I don't know why! Anyway thank you for your support guys!
