    ToolBoard: 2 wires fan, heater fault and how to extrude ?
    5.4k
    • Pseud3mysundefined
      Pseud3mys
      I have:
      Error: M997: In-application programming binary "Duet3_SDiap_MB6HC.bin" not found
      but there is not this file in the repository ? (git hub )
      • Vetiundefined
        Veti
        find that file here
        https://github.com/Duet3D/RepRapFirmware/releases/tag/3.0
        Pseud3mysundefined 1 Reply Last reply Reply Quote 0
          Pseud3mys @Veti
          This post is deleted!
            Pseud3mys
            M122 B121 command (for the tool board):
            02/12/2020 à 19:29:11 M122 B121
            Diagnostics for board 121:
            Duet TOOL1LC firmware version 3.2-beta4 (2020-11-26)
            Bootloader ID: not available
            Never used RAM 4700, free system stack 96 words
            HEAT 42 CanAsync 88 CanRecv 82 TMC 48 MAIN 341 AIN 64
            Last reset 00:03:22 ago, cause: software
            Last software reset data not available
            Driver 0: position 0, 80.0 steps/mm, standstill, SG min/max 0/0, read errors 0, write errors 1, ifcnt 19, reads 35710, writes 9, timeouts 0, DMA errors 0
            Moves scheduled 0, completed 0, in progress 0, hiccups 0
            No step interrupt scheduled
            VIN: 12.2V
            MCU temperature: min 22.6C, current 25.2C, max 25.2C
            Ticks since heat task active 46, ADC conversions started 202540, completed 202539, timed out 0
            Last sensors broadcast 0x00000000 found 0 50 ticks ago, loop time 0
            CAN messages queued 16, send timeouts 0, received 1906, lost 0, free buffers 36
              Pseud3mys
              and for the mainboard:
              02/12/2020 à 19:34:16 M122
              RepRapFirmware for Duet 3 MB6HC version 3.2-beta4 running on Duet 3 MB6HC v1.01 or later (standalone mode)
              Board ID: 08DJM-956BA-NA3TJ-6J1D2-3SD6M-9B9LT
              Used output buffers: 1 of 40 (12 max)
              Static ram: 123212
              Dynamic ram: 168576 of which 752 recycled
              Never used RAM 99652, free system stack 200 words
              Tasks: NETWORK(ready,171) ETHERNET(blocked,110) HEAT(blocked,317) CanReceiv(blocked,852) CanSender(blocked,371) CanClock(blocked,356) TMC(blocked,54) MAIN(running,1127) IDLE(ready,19)
              Owned mutexes:
              Last reset 00:00:46 ago, cause: software
              Last software reset details not available
              Error status: 0x00
              MCU temperature: min 37.9, current 39.0, max 39.3
              Supply voltage: min 12.2, current 12.2, max 12.3, under voltage events: 0, over voltage events: 0, power good: yes
              12V rail voltage: min 11.4, current 11.4, max 11.5, under voltage events: 0
              Driver 0: position 0, standstill, reads 35416, writes 14 timeouts 0, SG min/max 0/0
              Driver 1: position 0, standstill, reads 35417, writes 14 timeouts 0, SG min/max 0/0
              Driver 2: position 0, standstill, reads 35418, writes 14 timeouts 0, SG min/max 0/0
              Driver 3: position 0, standstill, reads 35422, writes 11 timeouts 0, SG min/max 0/0
              Driver 4: position 0, standstill, reads 35423, writes 11 timeouts 0, SG min/max 0/0
              Driver 5: position 0, standstill, reads 35424, writes 11 timeouts 0, SG min/max 0/0
              Date/time: 2020-12-02 19:34:15
              Slowest loop: 5.81ms; fastest: 0.15ms
              === Storage ===
              Free file entries: 10
              SD card longest read time 2.4ms, write time 0.0ms, max retries 0
              === MainDDARing ===
              Scheduled moves 0, completed moves 0, StepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1
              === AuxDDARing ===
              Segments left: 0
              Movement lock held by null
              HTTP is idle in state(s) 0
              Telnet is idle in state(s) 0
              File is idle in state(s) 0
              USB is idle in state(s) 0
              Aux is idle in state(s) 0
              Trigger is idle in state(s) 0
              Queue is idle in state(s) 0
              LCD is idle in state(s) 0
              SBC is idle in state(s) 0
              Daemon is idle in state(s) 0
              Aux2 is idle in state(s) 0
              Code queue is empty.
              === Network ===
              Slowest loop: 15.69ms; fastest: 0.03ms
              HTTP sessions: 1 of 8
              • Ethernet -
                State: active
                Error counts: 0 0 0 0 0
                === CAN ===
                Messages queued 171, send timeouts 0, received 896, lost 0, longest wait 2ms for reply type 6031, free buffers 47
              • Vetiundefined
                Veti
                duet 3 is also updated?
                any info on the heating now?
                  Pseud3mys @Veti
                  @Veti still no error, but now it show "fault" 1 second and after the web interface lost the board (2000°C and offline), but the M115 command still return that the can bus is connected
                    Pseud3mys
                    02/12/2020 à 19:42:27 M122 B122
                    Diagnostics for board 122:
                    HEAT 42 CanAsync 88 CanRecv 82 TMC 48 MAIN 341 AIN 70
                    Last reset 00:01:20 ago, cause: software
                    Last software reset at 2020-12-02 19:41, reason: HardFault, available RAM 4360, slot 0
                    Software reset code 0x0060 ICSR 0x00000003 SP 0x200011c0 Task
                    Stack: 20001014 00000011 0001d3e3 00000000 20000928 0001757d 000184fe 01000000 000202a8 000203a2 20001210 200032d8 00000020 00017d11 20004668 00000000 20001300 000086e5 000202a8 20004678 000203a2 4200af00 a5a5a5a5 a5a5a5a5 a5a5a5a5 a5a5a5a5 a5a5a5a5
                    Driver 0: position 0, 80.0 steps/mm, standstill, SG min/max 0/0, read errors 0, write errors 1, ifcnt 19, reads 40161, writes 9, timeouts 0, DMA errors 0
                    VIN: 12.3V
                    MCU temperature: min 30.8C, current 30.8C, max 30.9C
                    Ticks since heat task active 127, ADC conversions started 80370, completed 80369, timed out 0
                    Last sensors broadcast 0x00000000 found 0 131 ticks ago, loop time 0
                    CAN messages queued 22, send timeouts 0, received 732, lost 0, free buffers 36
                    it seem than the borad restart..
                    • Vetiundefined
                      Veti
                      same thing happens on the first board?
                        Pseud3mys @Veti
                        @Veti yes, even with no heater connected
                        • Vetiundefined
                          Veti
                          ok this is one for dc42 what the hardfault means.
                            Pseud3mys
                            but when there are no target temperature this not happen.
                            I checked, the board reset.
                            I would also like to add than I didn't load filament, I put the temperature by hand.
                              Pseud3mys @Veti
                              @Veti said in ToolBoard: 2 wires fan, heater fault and how to extrude ?:
                              sorry, I didn't understand ? what is dc42 ?
                              • Vetiundefined
                                Veti
                                just for testing execute
                                M307 H2 A597.2 C231.1 D12.5 S1.00 B0
                                and try heating again
                                Pseud3mysundefined Vetiundefined 2 Replies Last reply Reply Quote 0
                                  Pseud3mys @Veti
                                  @Veti
                                  raise this:
                                  02/12/2020 à 19:50:36 M307 H1 A597.2 C231.1 D12.5 S1.00 B0
                                  Warning: M307: Heater 1 appears to be over-powered. If left on at full power, its temperature is predicted to reach 622C
                                  • Vetiundefined
                                    Veti @Veti
                                    the question would be. who is @dc42
                                    https://forum.duet3d.com/user/dc42
                                    but can you heat afterwards? i thought you are trying heater 2
                                      Pseud3mys @Veti
                                      @Veti ah okay.
                                      I tried, heater keep running a little bit longer but the same issues appear.
                                        Pseud3mys
                                        @dc42 Hello, I have a fault with my heater (on Tool 1LC), with no error message. After a fews seconds when I start to heat, the heater pass in fault statement and in beta4 the tool board reset one second after the fault statement.
                                        Can you help me ?
                                          What does your heater graph look like when you get the fault?
                                          What shows up in the gcode console?
                                          Pseud3mysundefined 2 Replies Last reply Reply Quote 0
                                            Pseud3mys @Phaedrux
                                            The graph start just ascend (like 10/20°c) and then the heater change to fault state and the graph start slowly getting down.
                                            And I have nothing on the console, no error just the heater with "fault" under it.
