    ToolBoard: 2 wires fan, heater fault and how to extrude ?
    5.4k
    • Pseud3mysundefined
      Pseud3mys @Veti
      • Vetiundefined
        Veti
        you power down the system after the firmware update?
        also power the normal M122 output
        Pseud3mysundefined 1 Reply Last reply Reply Quote 0
          Pseud3mys @Veti
          @Veti yes, what is the M122 output ?
          • Vetiundefined
            Veti
            i meant provide the m122 output
              Pseud3mys @Veti
              @Veti said in ToolBoard: 2 wires fan, heater fault and how to extrude ?:
              it was not this ?
              @Pseud3mys said in ToolBoard: 2 wires fan, heater fault and how to extrude ?:
              • Vetiundefined
                Veti
                no just send M122. that will provide the output for the duet 3
                  Pseud3mys @Veti
                  @Veti ah okay, the popup say "response too long, see console"
                  02/12/2020 à 19:08:20 M122
                  RepRapFirmware for Duet 3 MB6HC version 3.1.1 running on Duet 3 MB6HC v1.01 or later (standalone mode)
                  Board ID: 08DJM-956BA-NA3TJ-6J1D2-3SD6M-9B9LT
                  Used output buffers: 1 of 40 (23 max)
                  Static ram: 154604
                  Dynamic ram: 162588 of which 36 recycled
                  Exception stack ram used: 224
                  Never used ram: 75764
                  Tasks: NETWORK(ready,292) ETHERNET(blocked,436) HEAT(blocked,1248) CanReceiv(suspended,3404) CanSender(suspended,1488) CanClock(blocked,1436) TMC(blocked,204) MAIN(running,4520) IDLE(ready,76)
                  Owned mutexes: LwipCore(NETWORK)
                  Last reset 00:00:54 ago, cause: software
                  Last software reset at 2020-12-02 19:07, reason: User, spinning module GCodes, available RAM 75728 bytes (slot 2)
                  Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0444a000 BFAR 0x00000000 SP 0xffffffff Task MAIN
                  Error status: 0
                  MCU temperature: min 36.6, current 37.0, max 37.6
                  Supply voltage: min 12.2, current 12.3, max 12.3, under voltage events: 0, over voltage events: 0, power good: yes
                  12V rail voltage: min 11.4, current 11.4, max 11.5, under voltage events: 0
                  Driver 0: standstill, reads 6703, writes 0 timeouts 0, SG min/max not available
                  Driver 1: standstill, reads 6704, writes 0 timeouts 0, SG min/max not available
                  Driver 2: standstill, reads 6702, writes 0 timeouts 0, SG min/max not available
                  Driver 3: standstill, reads 6702, writes 0 timeouts 0, SG min/max not available
                  Driver 4: standstill, reads 6702, writes 0 timeouts 0, SG min/max not available
                  Driver 5: standstill, reads 6701, writes 0 timeouts 0, SG min/max not available
                  Date/time: 2020-12-02 19:08:18
                  Slowest loop: 6.33ms; fastest: 0.22ms
                  === Storage ===
                  Free file entries: 10
                  SD card longest read time 2.2ms, write time 0.0ms, max retries 0
                  === MainDDARing ===
                  Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1
                  === AuxDDARing ===
                  Segments left: 0
                  Movement lock held by null
                  HTTP is idle in state(s) 0
                  Telnet is idle in state(s) 0
                  File is idle in state(s) 0
                  USB is idle in state(s) 0
                  Aux is idle in state(s) 0
                  Trigger is idle in state(s) 0
                  Queue is idle in state(s) 0
                  LCD is idle in state(s) 0
                  SBC is idle in state(s) 0
                  Daemon is idle in state(s) 0
                  Aux2 is idle in state(s) 0
                  Code queue is empty.
                  === Network ===
                  Slowest loop: 5.59ms; fastest: 0.03ms
                  HTTP sessions: 1 of 8
                  • Ethernet -
                    State: active
                    Error counts: 0 0 0 0 0
                    === CAN ===
                    Messages sent 59, longest wait 0ms for type 0
                    === Linux interface ===
                    State: 0, failed transfers: 0
                    Last transfer: 54276ms ago
                    RX/TX seq numbers: 0/1
                    SPI underruns 0, overruns 0
                    Number of disconnects: 0
                    Buffer RX/TX: 0/0-0
                  • Vetiundefined
                    Veti
                    hmm can communication seems to be working.
                    can you update to the latest beta as the diagnostic has been improved.
                      Pseud3mys @Veti
                      @Veti can we update duet with M997 ?
                        Pseud3mys
                        I have:
                        Error: M997: In-application programming binary "Duet3_SDiap_MB6HC.bin" not found
                        but there is not this file in the repository ? (git hub )
                        • Vetiundefined
                          Veti
                          find that file here
                          https://github.com/Duet3D/RepRapFirmware/releases/tag/3.0
                            Pseud3mys @Veti
                            This post is deleted!
                              Pseud3mys
                              M122 B121 command (for the tool board):
                              02/12/2020 à 19:29:11 M122 B121
                              Diagnostics for board 121:
                              Duet TOOL1LC firmware version 3.2-beta4 (2020-11-26)
                              Bootloader ID: not available
                              Never used RAM 4700, free system stack 96 words
                              HEAT 42 CanAsync 88 CanRecv 82 TMC 48 MAIN 341 AIN 64
                              Last reset 00:03:22 ago, cause: software
                              Last software reset data not available
                              Driver 0: position 0, 80.0 steps/mm, standstill, SG min/max 0/0, read errors 0, write errors 1, ifcnt 19, reads 35710, writes 9, timeouts 0, DMA errors 0
                              Moves scheduled 0, completed 0, in progress 0, hiccups 0
                              No step interrupt scheduled
                              VIN: 12.2V
                              MCU temperature: min 22.6C, current 25.2C, max 25.2C
                              Ticks since heat task active 46, ADC conversions started 202540, completed 202539, timed out 0
                              Last sensors broadcast 0x00000000 found 0 50 ticks ago, loop time 0
                              CAN messages queued 16, send timeouts 0, received 1906, lost 0, free buffers 36
                                Pseud3mys
                                and for the mainboard:
                                02/12/2020 à 19:34:16 M122
                                RepRapFirmware for Duet 3 MB6HC version 3.2-beta4 running on Duet 3 MB6HC v1.01 or later (standalone mode)
                                Used output buffers: 1 of 40 (12 max)
                                Static ram: 123212
                                Dynamic ram: 168576 of which 752 recycled
                                Never used RAM 99652, free system stack 200 words
                                Tasks: NETWORK(ready,171) ETHERNET(blocked,110) HEAT(blocked,317) CanReceiv(blocked,852) CanSender(blocked,371) CanClock(blocked,356) TMC(blocked,54) MAIN(running,1127) IDLE(ready,19)
                                Owned mutexes:
                                Last reset 00:00:46 ago, cause: software
                                Last software reset details not available
                                Error status: 0x00
                                MCU temperature: min 37.9, current 39.0, max 39.3
                                Supply voltage: min 12.2, current 12.2, max 12.3, under voltage events: 0, over voltage events: 0, power good: yes
                                Driver 0: position 0, standstill, reads 35416, writes 14 timeouts 0, SG min/max 0/0
                                Driver 1: position 0, standstill, reads 35417, writes 14 timeouts 0, SG min/max 0/0
                                Driver 2: position 0, standstill, reads 35418, writes 14 timeouts 0, SG min/max 0/0
                                Driver 3: position 0, standstill, reads 35422, writes 11 timeouts 0, SG min/max 0/0
                                Driver 4: position 0, standstill, reads 35423, writes 11 timeouts 0, SG min/max 0/0
                                Driver 5: position 0, standstill, reads 35424, writes 11 timeouts 0, SG min/max 0/0
                                Date/time: 2020-12-02 19:34:15
                                Slowest loop: 5.81ms; fastest: 0.15ms
                                === Storage ===
                                SD card longest read time 2.4ms, write time 0.0ms, max retries 0
                                === MainDDARing ===
                                Scheduled moves 0, completed moves 0, StepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1
                                === AuxDDARing ===
                                Segments left: 0
                                === Network ===
                                Slowest loop: 15.69ms; fastest: 0.03ms
                                • Ethernet -
                                  State: active
                                  === CAN ===
                                  Messages queued 171, send timeouts 0, received 896, lost 0, longest wait 2ms for reply type 6031, free buffers 47
                                • Vetiundefined
                                  Veti
                                  duet 3 is also updated?
                                  any info on the heating now?
                                    Pseud3mys @Veti
                                    @Veti still no error, but now it show "fault" 1 second and after the web interface lost the board (2000°C and offline), but the M115 command still return that the can bus is connected
                                      Pseud3mys
                                      02/12/2020 à 19:42:27 M122 B122
                                      Diagnostics for board 122:
                                      HEAT 42 CanAsync 88 CanRecv 82 TMC 48 MAIN 341 AIN 70
                                      Last reset 00:01:20 ago, cause: software
                                      Last software reset at 2020-12-02 19:41, reason: HardFault, available RAM 4360, slot 0
                                      Software reset code 0x0060 ICSR 0x00000003 SP 0x200011c0 Task
                                      Stack: 20001014 00000011 0001d3e3 00000000 20000928 0001757d 000184fe 01000000 000202a8 000203a2 20001210 200032d8 00000020 00017d11 20004668 00000000 20001300 000086e5 000202a8 20004678 000203a2 4200af00 a5a5a5a5 a5a5a5a5 a5a5a5a5 a5a5a5a5 a5a5a5a5
                                      Driver 0: position 0, 80.0 steps/mm, standstill, SG min/max 0/0, read errors 0, write errors 1, ifcnt 19, reads 40161, writes 9, timeouts 0, DMA errors 0
                                      VIN: 12.3V
                                      MCU temperature: min 30.8C, current 30.8C, max 30.9C
                                      Ticks since heat task active 127, ADC conversions started 80370, completed 80369, timed out 0
                                      Last sensors broadcast 0x00000000 found 0 131 ticks ago, loop time 0
                                      CAN messages queued 22, send timeouts 0, received 732, lost 0, free buffers 36
                                      it seem than the borad restart..
                                      • Vetiundefined
                                        Veti
                                        same thing happens on the first board?
                                          Pseud3mys @Veti
                                          @Veti yes, even with no heater connected
                                          • Vetiundefined
                                            Veti
                                            ok this is one for dc42 what the hardfault means.
