    Vertical Line on X Axis
    LPC
    835
    • Vetiundefined
      Veti
      it its at a very specific place, it might be mechanical
      since its at both sides at the exact same spot, its a good bet.
      ak10ngundefined 1 Reply Last reply Reply Quote 0
      • ak10ngundefined
        ak10ng @Veti
        @Veti if mechanical issue, it can be happen if I use marlin firmware. But no issue if using marlin firmware.
        engikeneerundefined 1 Reply Last reply Reply Quote 0
        • engikeneerundefined
          engikeneer @ak10ng
          @ak10ng is it happening at layer change points or where there are 'kinks' in the model. If so, I'd say look at pressure advance and retraction. Your RRF one definitely has some bulging at the corners suggesting that you don't have enough pressure advance. https://duet3d.dozuki.com/Wiki/Pressure_advance
          Equally, if those are the start/end points for the perimeters/infill, changing retraction will impact. Are you using firmware retraction? And are you using Z-hop?
          With both retraction and PA, you may have to double-check your extruder motor settings in case they start limiting the motion (though from a quick glance they look okay).
          It's hard to see from your photos, but the marlin one also looks to have some kind of feature at the same locations (though not very clear and could be lighting...). Have you got a link to the part stl?
          i3 clone with a bunch of mods
          • ak10ngundefined
            ak10ng
            This is my gcode that problem.
            led-docking1mmA.gcode
            This is for rotate model led-docking1mmV.gcode
            And this is my stl led-docking.stl .
            I'm not using PA and not using Z hop.
              jay_s_uk
              Which build are you using?
              • ak10ngundefined
                ak10ng @jay_s_uk
                @jay_s_uk I'm using led-docking1mmA.gcode with problem vertical line.
                  jay_s_uk @ak10ng
                  @ak10ng of LPC RRF.
                  Post you M122
                  • ak10ngundefined
                    ak10ng @jay_s_uk
                    @jay_s_uk this is
                    M122
                    RepRapFirmware for LPC176x based Boards (biquskr_1.4) version 3.2-beta3.2_1 running on LPC176x at 120Mhz
                    Used output buffers: 3 of 16 (16 max)
                    Static ram: 4940
                    Dynamic Memory (RTOS Heap 5): 1704 free, 1664 never used
                    Never used RAM 80, free system stack 22 words
                    Tasks: NETWORK(ready,190) HEAT(blocked,338) MAIN(running,359) IDLE(ready,20)
                    Owned mutexes: WiFi(NETWORK)
                    Last reset 00:13:55 ago, cause: [software]
                    Last software reset at 2020-12-03 17:33, reason: User, GCodes spinning, available RAM 80, slot 1
                    Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00425000 BFAR 0xe000ed38 SP 0xffffffff Task MAIN
                    Error status: 0x00
                    Supply voltage: under voltage events: 0
                    Driver 0: position 44480
                    Driver 1: position 44000
                    Driver 2: position 2040
                    Driver 3: position 0
                    Driver 4: position 0
                    Driver 5: position 0
                    Driver 6: position 0
                    Date/time: 2020-12-03 17:47:57
                    Slowest loop: 158.95ms; fastest: 0.10ms
                    Step timer: target 805563946 count 835910751 delta -30346806 late 0
                    USBSerial connected 0
                    ADC not ready 2 ADC error threshold 10 ADC Init 1
                    Ints: 14260; Calls 14254; fast: 2uS; slow 7uS adj 2689 bad 0 big delta 67
                    PWM Channels
                    Delta 375088068 Start -1 End -1
                    === Storage ===
                    Free file entries: 4
                    SD card 0 detected
                    SD card longest read time 46.2ms, write time 93.9ms, max retries 0
                    Hiccups: 0, FreeDm: 100, MinFreeDm: 98, MaxWait: 132327ms
                    === DDARing ===
                    Scheduled moves 319, completed moves 319, StepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1
                    Bed heaters = 0, chamberHeaters = -1
                    Heater 1 is on, I-accum = 0.0
                    Segments left: 0
                    Movement lock held by null
                    HTTP is idle in state(s) 0
                    File is idle in state(s) 0
                    USB is idle in state(s) 0
                    Aux is idle in state(s) 0
                    Trigger is idle in state(s) 0
                    Queue is idle in state(s) 0
                    Daemon is idle in state(s) 0
                    Code queue is empty.
                    === Network ===
                    Slowest loop: 229.91ms; fastest: 0.00ms
                    Responder states: HTTP(2) HTTP(0)
                    HTTP sessions: 1 of 2
                    • WiFi -
                      Network state is active
                      WiFi firmware version 1.23L263-302
                      WiFi MAC address d8:f1:5b:10:fe:c2
                      WiFi Vcc 64.00, reset reason Turned on by main processor
                      WiFi flash size 4194304, free heap 37712
                      WiFi IP address 192.168.254.111
                      WiFi signal strength -78dBm, reconnections 0, sleep mode modem
                      Clock register ffffffff
                      Socket states: 4 0
                      jay_s_uk
                      Have you tried printing the same gcode on version 3.1.1?
                      • ak10ngundefined
                        ak10ng @jay_s_uk
                        @jay_s_uk this problem on version 3.1.1, I'm just wanna try using this new FW.
                        • ak10ngundefined
                          ak10ng
                          Vertical line gone after using FW Ver 3.2-beta3.2_1. Thanks all. And no jerk again from home to start point.
