    Nozzle to high when printing BLTouch
    Beta Firmware
    571
    • jaskoundefined
      jasko
      I have issue that when I do z probe in home all when i go to G1 Z0 nozzle is 1mm away from build plate, so when print starts it is 1mm higher than it should have. I have done Z probe calibration many times. Mesh bed compensation also. Baby stepping does not work also I put even -0.5 but nothing happens, but it triggers some error that printer is out of limits... Any advice would be great. I am using latest beta firmware.
      homeall.g config.g
      • Vetiundefined
        Veti
        if you know that its off by 1mm increase the G31 z offset by 1mm
        • jaskoundefined
          jasko
          Tried that but noting happens, its like this offset is ignored.
          • Vetiundefined
            Veti @jasko
            @jasko
            maybe you set the offset accidentally in
            M558
            M558 P9 X0 Y0 Z0.5 H5 F120 T6000 ; Set Z Probe to type Switch or Digital output where Z probe connector is used. Used for z only.
            x y z should not be part of the M558 command
            also you should adjust your config properly for dual y setup.
            see
            https://duet3d.dozuki.com/Wiki/Bed_levelling_using_multiple_independent_Z_motors#Section_In_RepRapFirmware_Num_3
            M574 Z2 S1 P"io4.in" ; configure active-high endstop for high end on Z via pin io4.in
            are you really using a z endstop switch?
            G1 H1 X-10 Y-10 u-10 F360 ; move slowly to X and Y axis endstops once more (second pass)
            G92 Y0 ;set current position of y axis to 0
            dont do the G92 Y0 in homing
            jaskoundefined 1 Reply Last reply Reply Quote 0
            • DIY-O-Sphereundefined
              DIY-O-Sphere
              At the end of your config you read the stored values. (M501)
              Please check config-override.g
              (UTC+1)
              • jaskoundefined
                jasko @Veti
                @Veti said in Nozzle to high when printing BLTouch:
                I have removed it but nothing changes. 😞
                I'll make those changes for y axis for now it works.
                Should I eliminate z endstop switch? Can i use it for homing but instead of z probe homing? But I would still like to use mesh bed compensation?
                • jaskoundefined
                  jasko @DIY-O-Sphere
                  @DIY-O-Sphere Those are for headed bed, PID tuning.
                  • Vetiundefined
                    Veti
                    post the output of G31 send in the console
                    • jaskoundefined
                      jasko
                      This is result of G31:
                      Z probe 0: current reading 0, threshold 500, trigger height 0.700, offsets X0.0 Y0.0
                      This is from config.g:
                      G31 P25 X-38.2 Y-11 Z1.447							   ; Set Z probe trigger value, offset and trigger height
                        M950 S0 C"io7.out"                                  ; disable heater on PWM channel for BLTouch
                        M558 P9 C"io7.in" H5 F100 T3000                     ; disable Z probe but set dive height, probe speed and travel speed
                        M557 X50:840 Y50:1050 S100                         ;defining mesh probe grid
                        The order of these commands is the problem. You have two instances of M558 and the G31 must come after M558.
                        Change it to this:
                        • jaskoundefined
                          jasko @Phaedrux
                          @Phaedrux Thank you this worked.
