basic fan control issue
369
    RyanP
    I have two 5015 part cooling fans for my single hot end. I have them attached to F0 and F1. My understanding is that I should have the following in my config.g
    ;Fans
    M106 P0 S0 I0 F500 H-1
    M106 P1 S0 I0 F500 H-1
    ;Tool
    M563 P0 D0 H1 F0:1
    When I do this, my visible fans in DWC start a Fan2 and beyond, never showing Fan 0 or Fan 1....and Tool Fan is not there either.
    In one of my other printers (using a Maestro) I can see the following:
    When I adjust either of these up or down, my part cooling fan turns on and off, as desired.
    On my Wifi, with the same Gcode for fans and tools I get nothing:
    I can't pull any more hair out....
    CR10S, August 2018
    Anycubic Photon S December 2019
    Ender 5 Feb 2020
    Ender 5 Plus May 2020
    Anycubic Photon Mono X Nov 2020
    https://3dimensiongames.com/
      Veti
      which firmware version are both running?
      undefined 1 Reply Last reply 5 Dec 2020, 04:10 Reply Quote 0
        RyanP
        Definitely something wrong. Found a previous working SD card back up and the Fans and Tools sections were very vanilla:
        ;Fans
        M106 P2 S1 I0 F500 H1:0 T45 ; set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on
        Fan 0 and Tool fan are somehow disabled.
        With the same gcode script for Fans and Tools on my other printer, I can see Tool fan and Fan 0. Same script.
        Could my DWC get corrupt?
        CR10S, August 2018
        Ender 5 Feb 2020
          RyanP @Veti
          @Veti
          Both running 2.05
          CR10S, August 2018
          Ender 5 Feb 2020
            Veti
            do a M98 P"config.g" and see if your config has problems
            undefined 1 Reply Last reply 5 Dec 2020, 04:24 Reply Quote 0
              RyanP
              Well. My DWC was old. I just uploaded the latest release. Fan 0 showed up.
              So I update my config.g with
              ;Fans
              M106 P1 S0 I0 F500 H-1 ; set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
              M563 P0 D0 H1 F0:1 ; define tool 0
              And all of a sudden, both Fan 0 and Fan 1 showed up. Still no tool fan, but at least I have what I need.
              CR10S, August 2018
              Ender 5 Feb 2020
                RyanP @Veti
                @Veti
                Ran. From Console.
                M98 P"config.g"
                HTTP is enabled on port 80
                FTP is disabled
                TELNET is disabled
                CR10S, August 2018
                Ender 5 Feb 2020
                  Veti
                  maybe its time to update to 3.1.1 for you.
                    RyanP
                    In the new year. Too much printing to do before Christmas and I don't want to miss a 0 or a 1 somewhere in the conversion and slow my printing schedule down.
                    CR10S, August 2018
                    Ender 5 Feb 2020
                    7 out of 9
