Using an electronic switch to select a stepper motor
352
    MortarArt
    I'm considering my options for how to wire up my next printer. I've previously used 3 leadscrews driven by a timing belt and a single stepper, but the cost for this setup is very close to three screws driven directly by three steppers.
    My levelling technique for the belt involved detaching the belt, and turning each screw by hand.
    For the steppers, I intend to wire in a switch so I can turn off the idle current to one motor at a time.
    What I was wondering was if there was a way to do this via some kind switch controlled by a regular Duet2 wifi board?
    undefined 1 Reply Last reply 8 Dec 2020, 02:58 Reply Quote 0
      Veti
      but why would you not want to drive each motor by a stepper.
      you gain so much more. the levelling can be automated.
      https://duet3d.dozuki.com/Wiki/Bed_levelling_using_multiple_independent_Z_motors
      just wire up an additional stepper
      https://duet3d.dozuki.com/Guide/Connecting+External+Drivers/22
      undefined 1 Reply Last reply 29 Nov 2020, 16:20 Reply Quote 1
        MortarArt @Veti
        @Veti for a number of reasons. First off you need an expansion board, which adds costs. Second; I don't really subscribe to auto-levelling. It's simply too unreliable with glass and PVA, which is the cheapest and simplest adhesion method I've come across. Third; manual levelling only needs to be done once in a blue moon with a solid enough printer, and minor adjustments with the method I've described above are very easy.
        undefined undefined ? 3 Replies Last reply 29 Nov 2020, 16:31 Reply Quote 0
          Veti @MortarArt
          @MortarArt said in Using an electronic switch to select a stepper motor:
          this will work
          https://www.thingiverse.com/thing:3303618
          its cheap and reliable and has a high accuracy.
          undefined 1 Reply Last reply 7 Dec 2020, 22:39 Reply Quote 0
            BoA @MortarArt
            This is not true if You use separate motor for each Z - also connected to one stepper driver.
              MortarArt
              Why won't it be repeatable?
              undefined 1 Reply Last reply 7 Dec 2020, 23:07 Reply Quote 0
                MortarArt @Veti
                @Veti said in Using an electronic switch to select a stepper motor:
                this will work
                This is off topic. I don't want ABL. My question was simple.
                  Phaedrux Moderator @MortarArt
                  Because when the motor is de-energized it will snap to the nearest full step which may be in different directions for each motor.
                  I wouldn't want to disconnect the stepper motors while energized and M18 is per axis, not per motors.
                  https://duet3d.dozuki.com/Wiki/Gcode?revisionid=HEAD#Section_M18_Disable_all_stepper_motors
                  Well that may be, but it does exist for this very reason.
                    A Former User @MortarArt
                    you can find step sticks that accept 3.3v so you don't need the official expansion boards, but as detailed already you will need dedicated drivers for each motor to not loose the possition (and if you have the dedicated drivers there is no point in sharing the control signals, and not a requirement to use abl)
                      zapta @MortarArt
                      @MortarArt, do you plan to connect three steppers in series to a single duet driver output?
                      In this case, you one to shut the current of one stepper of the three you just need to short it two coils, letting the current bypassing it.
                      There are issues with connecting/disconnecting coils under power but I think that shorting/unshorting one of the tree in series is safe and doesn't create voltage spikes(?). Others with more experience may comment.
                      Just make sure not to short all three steppers and the same time since it will short the Duet's output and may damager it.
                      You also want to run everything in 24V and limit the speed of your Z.
